Câu hỏi thường gặp khi đi phỏng vấn làm Network Engineer :)
  • Câu hỏi thường gặp khi đi phỏng vấn làm Network Engineer :)
    Dear các anh em,
    Vô tình lên mạng thấy được 1 bài viết rất hay về phỏng vấn khi đi phỏng vấn làm Network Engineer nên muốn chia sẻ cùng các anh em
    TIPS for PREPARING FOR THE INTERVIEW
    1. Study- Before you go to you Interview, open the books up and give yourself a general review of networking.
    2. Update your Resume - Read your resume and update it. The last thing you need when you are putting your best face forward is to have a resume that is full of grammatical errors.
    3. Watch out for Social Networks - Many employers are getting very smart and will search on your name. Be sure if they find your facebook or myspace page there isn't anything there that you wouldn't want them to see.
    4. Google yourself - Search for yourself on Google and see what you find. You would be amazed an what might pop up. Make sure nothing derogatory shows up.
    5. Get Certified- One of the best things to do to prove you know what your talking about is a certification. This gives a new employer an easy way to understand your knowledge level.
    Preparing for NETWORK ENGINEER INTERVIEW QUESTIONS
    1. IP Addressing- Make sure you know subnetting (without a subnet calculator!). Know the value of every bit in each each Octet. Know subnet masks and what their slashed notation is and CIDR
    2. Memorize administrative distances of all routing protocols.
    3. Review the simple stuff, like 3way handshakes in tcp, setting up hrsp, ip helpers, and vlans.
    4. Review Spanning Tree - Know what a root bridge is, know what VTP does
    5. Review VLANs and be able to explain what a vlan is.
    Employers know you can look things up in a pinch but what do you know off the top of your head that you can hit the ground running and fix a problem if it arises. Or if they send you out to a remote location to setup a router, with no internet, can you get the thing online and working?
    Put yourself in their shoes, what will they need from you? Review the job description and target those things specific to the job your interviewing for.
    SAMPLE INTERVIEW QUESTIONS FOR NETWORK ENGINEERS
    1. What is thesubnet mask10.2.1.3/22?
    2. What is the administrative distance of EIGRP, eBGP, iBGP?
    3. What is your favorite routing Protocol?
    4. In EIGRP, what is a Stuck in Active route?
    5. In OSPF, what is a totaly stubby area? What does Area Zero do?
    6. Which internal routing protocol would use if you needed to route between Cisco and non-Cisco equipment?
    7. Explain what a 3-way handshake is in TCP?
    8. What is a VLAN trunking protocol?
    9. What is the different between 802.1q and ISL?
    10. Explain what is an Ether-Channel?
    11. What do you need to do to setup a VTP domain?
    12. What is Spanning Tree used for?
    13. What is a root bridge and why do you need one?
    14. What is needed on a router interface to allow DHCP to function on a subnet?
    15. Describe what a statefulfirewallis?
    16. What is HSRP? Is this an open standard?
    17. In a PIX/ASA, what are security levels used for?
    18. What two things are needed in aPIX/ASA firewallto allow traffic to pass from a higher security level to a lower security level?
    19. In IPSec VPNs, what is diffe helman? What is it used for?
    20. In an IPSec tunnel, what is main mode?
    Read The Original Article Here...http://www.routerfreak.com/network-e...iew-questions/
    Thêm 1 lý do anh em chọn học ở Vnpro là hoàn toàn chính xác
