Mục tiêu
Cấu hình router để kiểm tra các traffic hướng ra và tự động mở ra các ACCESS-LIST pinhole.
Mô hình
Hướng dẫn
Cấu hình tham khảo
Bước 1: Cấu hình cơ bản: địa chỉ IP, định tuyến OSPF, NAT PAT
Router R4
interface Loopback0
ip address 150.1.4.4 255.255.255.0
interface FastEthernet0/0
ip address 155.1.45.4 255.255.255.0
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.0.0.4 255.255.255.0
ip nat inside
duplex auto
speed auto
router ospf 1
log-adjacency-changes
network 150.1.4.0 0.0.0.255 area 0
network 155.1.45.0 0.0.0.255 area 0
ip classless
ip http server
ip nat inside source list 1 interface Loopback0 overload
access-list 1 permit 10.0.0.0 0.0.0.255
control-plane
logging synchronous
line aux 0
login
Router R5
ip address 155.1.45.5 255.255.255.0
duplex auto
speed auto
ip address 150.1.5.5 255.255.255.0
duplex auto
speed auto
no keepalive
router ospf 1
network 150.1.5.0 0.0.0.255 area 0
ip classless
ip http server
no ip http secure-server
control-plane
line aux 0
privilege level 15
no login
Router R1
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.0.4
line aux 0
privilege level 15
no login
Bước 2: Cấu hình access-list INBOUND và inspection rule INSPECT trên router R4
ip access-list extended INBOUND
permit ospf any any
deny ip any any log
ip inspect name INSPECT ftp
ip inspect name INSPECT icmp router-traffic
ip inspect name INSPECT tcp router-traffic
Apply access-list INBOUND (hướng in) và inspection rule INSPECT (hướng out) trên interface Fa0/0 của R4.
ip access-group INBOUND in
ip inspect INSPECT out
Bước 3: Kiểm tra
R4#sh ip inspect config
Session audit trail is disabled
Session alert is enabled
one-minute (sampling period) thresholds are [400:500] connections
max-incomplete sessions thresholds are [400:500]
max-incomplete tcp connections per host is 50. Block-time 0 minute.
tcp synwait-time is 30 sec -- tcp finwait-time is 5 sec
tcp idle-time is 3600 sec -- udp idle-time is 30 sec
dns-timeout is 5 sec
Inspection Rule Configuration
Inspection name INSPECT
ftp alert is on audit-trail is off timeout 3600
icmp alert is on audit-trail is off timeout 10
inspection of router local traffic is enabled
tcp alert is on audit-trail is off timeout 3600
R1#telnet 150.1.5.5
Trying 150.1.5.5 ... Open
R5>
R4#show ip inspect sessions
Established Sessions
Session 650FF88C (10.0.0.1:54327)=>(150.1.5.5:23) tcp SIS_OPEN
Session 650FFB04 (150.1.4.4:40087)=>(150.1.5.5:179) tcp SIS_OPEN
R4#ping 150.1.5.5
Sending 5, 100-byte ICMP Echos to 150.1.5.5, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 44/44/48 ms
R4#telnet 150.1.5.5
R5>exit
[Connection to 150.1.5.5 closed by foreign host]
R5#conf t
R5(config)#ftp-server enable
R5(config)#ftp-server topdir flash:
R5(config)#do copy start flash:
Destination filename [r5-confg]? test.txt
Erase flash: before copying? [confirm]n
Verifying checksum... OK (0x10CB)
1668 bytes copied in 0.292 secs (5712 bytes/sec)
R1#copy ftp://150.1.5.5/test.txt null:
Accessing ftp://150.1.5.5/test.txt...
Loading test.txt !
[OK - 1668/4096 bytes]1668 bytes copied in 4.652 secs (359 bytes/sec)
Mô hình
- Cấu hình router (định tuyến, NAT, …) giống như bài LAB 2 ‘Lọc traffic với reflexive access-list’.
- Tạo luật kiểm tra (inspection rule) tên là INSPECT để cho phép các giao thức dựa trên TCP.
- Ngoài ra, cho phép FTP được thực hiện thông qua Firewall.
- Tiếp theo, cấu hình luật này cho phép ICMP và kiểm tra các traffic TCP/ICMP do router tạo ra.
- Tạo access-list INBOUND và cho phép OSPF. Chặn và ghi lại tất cả các traffic khác.
- Apply access-list INBOUND trên cổng Fa0/0 theo hướng vào (in).
- Apply luật kiểm tra trên cổng Fa0/0 theo hướng ra.
Cấu hình tham khảo
Router R4
interface Loopback0
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
router ospf 1
ip classless
ip http server
control-plane
logging synchronous
line aux 0
login
Router R5
duplex auto
speed auto
duplex auto
speed auto
no keepalive
router ospf 1
ip classless
ip http server
control-plane
line aux 0
privilege level 15
no login
Router R1
duplex auto
speed auto
ip classless
line aux 0
privilege level 15
no login
permit ospf any any
deny ip any any log
Bước 3: Kiểm tra
R1#telnet 150.1.5.5
R5>
R4#ping 150.1.5.5
R4#telnet 150.1.5.5
R5>exit
R5#conf t
Loading test.txt !
