Thực hành bài Lab cấu hình Windows server 2003 làm CA Server
Mô hình như sau:
Các thiết bị bao gồm: 2 Router 2800, 1 Switch 3550, 1 Windows server 2003
Client 1:
Router#config terminal
Router(config)#hostname client1
Client1(config)# interface f0/1
Client1(config-if)# ip address 172.30.2.2 255.255.255.0
Client1(config-if)# no shut
Client1(config-if)# exit
Client1(config-if)# ip address 192.168.1.2 255.255.255.0
# cấu hình domain name cho Router
Client1(config)# ip domain-name cisco.com
Client1(config)# ip host caserver 172.30.1.2
# cấu hình trustpoint
Client1(config)# crypto ca trustpoint CA
Client1(ca-trustpoint)# enrollment url http://172.30.1.2/certsrv/mscep/mscep.dll
Client1(ca-trustpoint)# subject-name cn=client1@vnpro.org
Client1(ca-trustpoint)# exit
Client1(config)# crypto ca authenticate CA
#cấu hình VPN
Client1(config)# crypto isakmp policy 10
Client1(config-isakmp)# hash md5
Client1(config-isakmp)# exit
Client1(config)# crypto ipsec transform-set myset esp-des esp-md5-hmac
Client1(config-crypto-trans)# exit
Client1(config)# crypto map mymap 10 ipsec-isakmp
Client1(config-crypto-map)# set peer 172.30.3.2
Client1(config-crypto-map)# set transform-set myset
Client1(config-crypto-map)# match address 101
Client1(config-crypto-map)# exit
Client1(config)# access-list 101 permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
# áp crypto map vào cổng
Client1(config-if)# crypto map mymap
Client1(config)#
Client 2:
Client2(config)# interface f0/1
Client2(config-if)# ip address 172.30.3.2 255.255.255.0
Client2(config-if)# no shut
Client2(config-if)# exit
Client2(config-if)# ip address 192.168.2.2 255.255.255.0
Client2(config)# ip domain-name cisco.com
Client2(config)# ip host caserver 172.30.1.2
Client2(config)# crypto ca trustpoint CA
Client2(ca-trustpoint)# enrollment url http://172.30.1.2/certsrv/mscep/mscep.dll
Client2(ca-trustpoint)# subject-name cn=client1@vnpro.org
Client2(ca-trustpoint)# exit
Client2(config)# crypto ca authenticate CA
#cấu hình VPN
Client2(config)# crypto isakmp policy 10
Client2(config-isakmp)# hash md5
Client2(config-isakmp)# exit
Client2(config)# crypto ipsec transform-set myset esp-des esp-md5-hmac
Client2(config-crypto-trans)# exit
Client2(config)# crypto map mymap 10 ipsec-isakmp
Client2(config-crypto-map)# set peer 172.30.2.2
Client2(config-crypto-map)# set transform-set myset
Client2(config-crypto-map)# match address 101
Client2(config-crypto-map)# exit
Client2(config)# access-list 101 permit ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
Client2(config-if)# crypto map mymap
Client2(config)#
Cấu hình CAServer :
Các bước cấu hình Windows server 2003 làm CA
để xây dựng 1 CA ta làm như sau:
Bước1: cài đặt dịch vụ IIS
Để cài được dịch vụ CA tr ên windowns server 2003 ta cần có IIS :
1. vào start--> control panel-->add or remove programs
2. Trong add or remove programs, nhấn add/remove windowns components
3. nhấn vào application server (nhưng không tích vào ô chọn)
à chọn detail
4. Tích vào Internet Information Service (IIS)
5. Nhấn Next à finish để hoàn thành cài đặt
Bước 2: cài đặt dịch vụ CA
1. vào start-->control panel--> add or remove program
2. trong mục add or remove program, nhấn add/remove windowns components
3. Tích vào o certificates services
4. lúc này nhận được thong báo về việc không thay đổi tên máy tính
à chọn yes
5. Trong CA type --> chọn Stand-alone root CA -->next
6. Trong mục Common name for this CA, nhấp vào tên máy tính đang cài đặt
giả sử đang cài trên máy C0111
7. Để mặc định nơi lưu trữ database và log file của CA à nhấn Next
8. sau khi nhấn Next ta nhận được thông báo phải dừng Internet Information Service à chọn Yes
9. sau khi nhấn Yes xuất hiện yêu cầu File I386 à chọn thư mục có chứa file I386 à OK
10. Trong quá trình hoàn thành cài đặt, nhận được thông báoà chọn Yes
11. Nhấn finish để hoàn thành cài đặt
Bước 3: để hoàn thành được CA, ta cài thêm phần SCEP
2. sau đó click Next à chọn use the local system account
3,Nhấn Next à và bỏ chọn require SCEP challenge Phrase to enroll
4. Nhấn Next à chọn Yes và điền thông tin
KIểm tra hoạt động:
Thực hiện đối với client1 :
Client1# show run
Current configuration : 3484 bytes
! Last configuration change at 17:39:57 UTC Tue Apr 1 2008
version 12.4
hostname client1
no aaa new-model
ip cef
ip domain name cisco.com
multilink bundle-name authenticated
voice-card 0
no dspfarm
crypto pki trustpoint CA
enrollment mode ra
enrollment url http://172.30.1.2:80/certsrv/mscep/mscep.dll
subject-name cn=client2@vnpro.org
revocation-check none
crypto pki certificate chain CA
certificate ca 2AE3AB73C8740484449E6747E831C315
quit
hash md5
set peer 172.30.3.2
match address 150
interface FastEthernet0/0
duplex auto
speed auto
interface FastEthernet0/1
duplex auto
speed auto
crypto map mymap
ip route 0.0.0.0 0.0.0.0 172.30.2.1
ip http server
no ip http secure-server
access-list 150 permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
Thực hiện đối với client2
Client2# show run
Current configuration : 5774 bytes
! Last configuration change at 17:23:41 UTC Tue Apr 1 2008
version 12.4
hostname client2
no aaa new-model
ip cef
enrollment mode ra
certificate 618FFBFC000000000004
quit
quit
hash md5
set peer 172.30.2.2
match address 150
duplex auto
speed auto
duplex auto
speed auto
crypto map mymap
interface Serial0/1/0
shutdown
no fair-queue
clock rate 2000000
ip route 0.0.0.0 0.0.0.0 172.30.3.1
ip http server
access-list 150 permit ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
scheduler allocate 20000 1000
client2# show crypto ca certificates
Certificate
Status: Available
Certificate Serial Number: 618FFBFC000000000004
Certificate Usage: General Purpose
Issuer:
cn=CA
Subject:
hostname=client2.cisco.com
CRL Distribution Points:
Validity Date:
start date: 10:10:13 UTC Apr 1 2008
end date: 10:20:13 UTC Apr 1 2009
Associated Trustpoints: CA
CA Certificate
Status: Available
Certificate Serial Number: 2AE3AB73C8740484449E6747E831C315
Certificate Usage: Signature
Issuer:
cn=CA
Subject:
cn=CA
Validity Date:
start date: 10:07:30 UTC Apr 1 2008
end date: 10:17:09 UTC Apr 1 2013
Thực hiện Ping từ PC 2 đến PC 1:
kết quả là 2 PC đã kết nối được với nhau.
Mô hình như sau:
Client 1:
#cấu hình VPN
Client1(config)#
Client 2:
#cấu hình VPN
Client2(config)#
Cấu hình CAServer :
à chọn detail
à chọn yes
KIểm tra hoạt động:
Client1# show run
version 12.4
hostname client1
no aaa new-model
ip cef
voice-card 0
no dspfarm
enrollment mode ra
quit
hash md5
set peer 172.30.3.2
match address 150
duplex auto
speed auto
duplex auto
speed auto
crypto map mymap
ip http server
Client2# show run
version 12.4
hostname client2
no aaa new-model
ip cef
enrollment mode ra
quit
quit
hash md5
set peer 172.30.2.2
match address 150
duplex auto
speed auto
duplex auto
speed auto
crypto map mymap
shutdown
no fair-queue
clock rate 2000000
ip http server
Certificate
Status: Available
Issuer:
cn=CA
Subject:
Validity Date:
CA Certificate
Status: Available
Issuer:
cn=CA
Subject:
cn=CA
Validity Date:
