Phân phối cáp Alantek cat5e, alantek cat6, alantek Rg6Công Ty CP Giải Pháp Mạng Viễn Thông Hồng Quang
HQTELECOM
Trụ Sở HN : Số 1/18 Ngõ 233 Xuân Thủy, Q. Cầu Giấy, Hà Nội
VPGD HCM : Lầu 7, Tòa nhà ILC – 134 Bạch Đằng – Q.Tân Bình, HCM
LIÊN HỆ:
Hotline 0949.903.303
VUI LÒNG GỌI ĐỂ CÓ GIÁ TỐT NHẤT !!
1 Alantek cat3 25-pair UTP (put-up 500m) 301-100253-0000
2 Alantek cat3 50-pair UTP (put-up 500m) 301-100503-0000
3 Alantek cat3 100-pair UTP (put-up 500m) 301-101003-0000
4 Alantek cat5 25-pair UTP (put-up 500m) 301-100255-0000
5 Alantek cat5e 25-pair UTP (put-up 500m) 301-10025E-0000
CATEGORY 5E CABLE
1 Alantek Cat5e UTP 4-pair 301-10008E-00GY
2 Alantek Cat5e FTP 4-pair 301-10F08E-00GY
JACK CAT5E
1 Alantek Cat5e UTP Jacks LF 302-202LF1-00BL
2 Alantek Cat5e UTP Jacks LF 302-202LF1-00BU
3 Alantek Cat5e UTP Jacks LF 302-202LF1-00IV
4 Alantek Cat5e UTP Jacks LF 302-202LF1-00RD
5 Alantek Cat5e UTP Jacks LF 302-202LF1-00WH
6 Alantek Cat5e UTP Jacks LF 302-202LF1-00YL
7 Alantek Cat5e UTP Jacks 302-202018-WHAB
8 Alantek cat5e Shield Jacks 302-202101-00AB
RJ45 PLUG
1 Alantek Cat5e RJ45 plugs 302-203005-0050
2 Alantek cat5e RJ45 Shielded plugs 302-203101-0050
FACEPLATE
1 Alantek Faceplate UK 1 Port 302-203221-SHWH
2 Alantek Faceplate UK 1 Port (New P/N) 302-2B3221-SHWH
3 Alantek Faceplate UK 2 Port 302-203222-SHWH
4 Alantek Faceplate UK 2 Port (New P/N) 302-2B3222-SHWH
5 Alantek Faceplate UK 4 port w/ shutter 302-203224-SHWH
6 Alantek Faceplate US 2 port 302-203202-00WH
7 Alantek Faceplate US 4 port 302-203204-00WH
8 Alantek Faceplate US 2 port w/ Shutter ( HCN) 302-203202-SHWH
9 Alantek Faceplate US 4 port c/w Shutter 302-203204-SHWH
MOUNT BOX
1 Alantek shuttered mount box 2port 302-203212-SHWH
PARCH PANEL CAT5E
1 Alantek Cat5e blank panel 24 port 302-201BLN-24BL
2 Alantek Cat5e Patch Panel UTP 24-port 302-201001-2400
3 Alantek Cat5e Patch Panel UTP 48-port 302-201002-48AB
RUBBER BOOT
1 Alantek RJ45 Rubber Boot, 302-091100-00BL
2 Alantek RJ45 Rubber Boot, 302-091100-00BU
3 Alantek RJ45 Rubber Boot, 302-091100-00GN
4 Alantek RJ45 Rubber Boot, 302-091100-00RD
5 Alantek RJ45 Rubber Boot, 302-091100-00WH
6 Alantek RJ45 Rubber Boot, 302-091100-00YL
PATCH CABLE CAT5E
1 Alantek Cat5e UTP patch cable, stranded, 301-100P8E-DSYL
2 Alantek Cat5e UTP patch cable, stranded, 301-100P8E-DSBU
3 Alantek Cat5e UTP patch cable, stranded, 301-100P8E-DSRD
4 Alantek Cat5e UTP patch cable, stranded, 301-100P8E-DSGN
PATCH CORD CAT5E
1 Alantek cat5e UTP Moulded P/cord 7ft, 302-4MU07E-FDBU
2 Alantek cat5e UTP Moulded P/cord 7ft, 302-4MU07E-FDYL
3 Alantek cat5e UTP Moulded P/cord 7ft, 302-4MU07E-FDRD
4 Alantek cat5e UTP Moulded P/cord 10ft, 302-4MU10E-FDBU
5 Alantek cat5e UTP Moulded P/cord 10ft, 302-4MU10E-FDYL
6 Alantek cat5e UTP Moulded P/cord 10ft,302-4MU10E-FDRD
7 Alantek cat5e UTP Moulded P/cord 17ft,302-4MU17E-FDBU
8 Alantek cat5e UTP Moulded P/cord 17ft,302-4MU17E-FDYL
CATEGORY 6 CABLING SOLUTION
CATEGORY 6 CABLE
1 Alantek Cat6 cable 4-pair 301-6008LG-00GY
2 Alantek Cat6 FTP 4 Pair Cable 301-60F8LG-00GY
JACK CAT6
1 Alantek Cat6 UTP Dual IDC Jack, white 302-202618-WHAB
PATCH CORD CAT6
1 Alantek Cat6 Moulded UTP P/cord 4FT 302-4MU046-FTWH
2 Alantek Cat6 Moulded UTP P/cord 7FT,302-4MU076-FTWH
3 Alantek Cat6 Moulded UTP P/cord 7FT,302-4MU076-FTBU
4 Alantek Cat6 Moulded UTP P/cord 7FT,302-4MU076-FTYL
5 Alantek Cat6 Moulded UTP P/cord 7FT, 302-4MU076-FTRD
6 Alantek Cat6 Moulded UTP P/cord 10FT 302-4MU106-FTWH
7 Alantek Cat6 Moulded UTP P/cord 10FT, 302-4MU106-FTBU
8 Alantek Cat6 Moulded UTP P/cord 10FT, 302-4MU106-FTRD
9 Alantek Cat6 Moulded UTP P/cord 10FT, 302-4MU106-FTYL
PATCH PANEL CAT6
1 Alantek Cat6 Patch panel 24 port 302-201601-24AB
MALE/FEMALE CONNECTOR
1 AMP Champ Connector (Female) 50 pin 0-0229913-1
2 AMP Champ Connector (Male) 50 pin 0-0229912-1
WIRING KIT & CONNECTING BLOCK
Alantek Wiring Kit 100 pair w/ leg Cat5 302-5110FT-L100
Alantek Connecting Block 4 pair Cat5 302-511LR4-0000
Alantek Connecting Block 4 pair Cat3 302-311LR4-000
BROADBAND CABLE SOLUTION
COAXIAL CABLE
15 Alantek AC540 with messenger 301-0AC540-0000
16 Alantek AC540 no messenger 301-0AC540-00NM
17 Alantek AC540 with Flooding Compound no messenger 301-0AC540-0FNM
COAXIAL CABLE (NEW PART NUMBER)
1 Alantek RG-59 Standard Shield Coaxial 301-RG5900-SSBK-1223
2 Alantek RG-59 Standard Shield Coaxial w/ Flooding Compound 301-RG590F-SSBK-1223
3 Alantek RG-11 Standard Shield Coaxial 301-RG1100-SSBK-2223
4 Alantek RG-11 Standard Shield Coaxial w/ Flooding Compound 301-RG110F-SSBK-2223
5 Alantek RG11 Standard shield with messenger 301-RG110M-SSBK-2223
6 Alantek RG11 Tri- Shield Coaxial with messenger 301-RG110M-3SBK-2223
7 Alantek RG11 Tri- Shield Coaxial no messenger 301-RG1100-3SBK-2223
8 Alantek RG11 Quad-shield coxial cable 301-RG1100-QSBK-2223
9 Alantek RG-6 Standard Shield Coaxial, Black 301-RG0600-SSBK-1223
10 Alantek RG-6 Standard Shield Coaxial, White 301-RG0600-SSBK-1223
12 Alantek RG-6 Tri-Shield Coaxial White 301-RG0600-3SWH-1223
13 Alantek RG6 Quad-shield coaxial cable 301-RG0600-QSBK-1223
14 Alantek RG-6 Standard Shield Coaxial c/w Flooding compound 301-RG060F-SSBK-1223
SPLITTER
TAP & SPLITTER
1 Alantek Splitter Indoor 2 way 308-IS5172-0000
2 Alantek Splitter Indoor 3 way 308-IS5173-0000
3 Alantek Splitter Indoor 4 way 308-IS5174-0000
4 Alantek Splitter Indoor 6 way 308-IS5176-0000
5 Alantek Splitter Indoor 8 way 308-IS5178-0000
6 Alantek Splitter Indoor 10 way 308-IS5150-0000
7 Alantek Splitter Indoor 12 way 308-IS5152-0000
8 Alantek Splitter Indoor 14 way 308-IS5154-0000
9 Alantek Splitter Indoor 16 way 308-IS5156-0000
10 Alantek TV Jack & Faceplate Indoor 308-TV8520-0000
11 Feedthru540 3CN-7043FT-0540
12 Alantek Tap off indoor 1 way (XX: 08,12,16,20,24 dB) 308-IT5271-00XX
13 Alantek Tap off indoor 2 way (XX: 06,08,10,12,14,16,20,24 dB) 308-IT5272-00XX
14 Alantek Tap off indoor 4 way (XX: 12,14,16,20,24 dB) 308-IT5274-00XX
15 Alantek Tap off indoor 6 way (XX: 14,17,20,23 dB) 308-IT5276-00XX
16 Alantek Tap off indoor 8 way (XX: 14,17,20,23,26,29 dB) 308-IT5278-00XX
F-CONNECTOR
1 Alantek RG6 BNC connector 3CN-MSC006-1000
2 Alantek RG59 BNC connector 3CN-MSC059-1000
3 Alantek F-Connector RG6 3CN-F303CS-RG06
4 Alantek F-Connector RG11 3CN-F352GS-RG11
5 Alantek RG6 F Crimp Connector w/ silicon and "O" Ring 3CN-0FY024-RG06
6 Alantek RG6 F-Compression 3CN-0FY040-RG06
7 Alantek RG11 F-Compression 3CN-0FY048-RG11
8 Alantek BNC Crimp Type for RG6 Centre Conductor diameter 1.02MM Brass 3CN-0FY079-RG06
9 Alantek BNC Crimp Type for RG59 Centre Conductor 3CN-0FY079-RG59
TOOLS
1 Alantek Aluminum pipe cable's tool 302-0FY106-AC00
2 Alantek tools for RG6 & RG11 Crimping Connector 302-0FY036-0000
3 Alantek tools for RG6, RG11 & RG59 Compression Connector 302-0FY050-0000
AMPLIFIERS & COMBINER (OLD PART NO)
1 Alantek Amplifier Inddor 2 way 308-N2228X-21MX
2 Alantek Passive Combiner 16 way 308-PCB016-0000
AMPLIFIERS & COMBINER (NEW PART NO)
1 Alantek Amplifier Inddor 2 way 308-4086H1-B300
2 Alantek Passive Combiner 16 way 308-DTC016-0000
MODULATORS
1 Alantek Agile Modulator 308-AM8600-0000
FIBER OPTIC SOLUTION
1 Alantek 4-core outdoor cable 306-DDE604-DUCT
2 Alantek 8-core outdoor cable 306-DDE608-DUCT
3 Alantek 4C FO 62.5um Outdoor Amored (2km/rl) 306-STA604-Y000
4 Alantek 8C FO 62.5um Outdoor Amored (2km/rl) 306-STA608-Y000
5 Alantek 4C FO 50um Outdoor Amored (2km/rl) 306-STA504-Y000
6 Alantek M-Mode 62.5/125 Indoor Fiber 2C 306-662002-0030
7 Alantek M-Mode 62.5/125 Indoor Fiber 4C 306-663004-0000
PATCH CORD MM 62.5/125
1 Alantek M-Mode 62.5/125um Patch Cord SC/MTRJ 3m 306-62028M-0030
2 Alantek M-Mode 62.5/125um Patch Cord SC/LC 3m 306-62027M-0030
3 Alantek M-Mode 62.5/125um Patch Cord SC/SC 3m 306-62022M-0030
4 Alantek M-Mode 62.5/125um Patch Cord ST/SC 3m 306-62012M-0030
5 Alantek M-Mode 62.5/125um Patch Cord ST/SC 5m 306-62012M-0050
6 Alantek M-Mode 62.5/125um Patch Cord ST/ST 3m 306-62011M-0030
7 Alantek M-Mode 62.5/125um Patch Cord ST/LC 3m 306-62017M-0030
8 Alantek M-Mode 62.5/125um Patch Cord ST/MTRJ 3m 306-62018M-0030
9 Alantek M-Mode 62.5/125um Patch Cord LC/LC 3m 306-62077M-0030
10 Alantek M-Mode 62.5/125um Patch Cord LC/MTRJ 3m 306-62078M-0030
PATCH CORD MM 50/125
1 Alantek M-Mode 50/125um, Patch Cord ST/MTRJ 3m 306-52018M-0030
2 Alantek M-Mode 50/125um, Patch Cord ST/LC 3m 306-52017M-0030
3 Alantek M-Mode 50/125um, Patch Cord SC/SC 3m 306-52022M-0030
4 Alantek M-Mode 50/125um, Patch Cord SC/LC 3m 306-52027M-0030
5 Alantek M-Mode 50/125um, Patch Cord SC/MTRJ 3m 306-52028M-0030
6 Alantek M-Mode 50/125um, Patch Cord LC/LC 3m 306-52077M-0030
7 Alantek M-Mode Patch Cord FC-FC 4m 306-62033M-0040
8 Alantek M-Mode Patch Cord FC-FC 20m 306-62033M-0200
FO CONNECTOR
1 Alantek M-Mode connector LC 306-083217-30MM
2 Alantek M-Mode connector SC 306-083212-93MM
3 Alantek M-Mode connector SC 306-083211-M2BG
4 Alantek M-Mode connector ST 306-083211-93MM
5 Alantek M-Mode connector ST 306-083211-M2BL
6 Alantek S-Mode connector SC 306-083212-M2BU
7 Alantek S-Mode connector SC 306-083212-S2BU
8 Alantek S-Mode connector ST 306-083211-93SM
9 Alantek S-Mode connector ST 306-083211-00SM
10 Alantek M-Mode male connector MTRJ 306-083218-00MM
11 Alantek Adapter MM SC 306-083272-BGMM
12 Alantek Adapter MM Duplex LC 306-083287-BGMM
RACKMOUNT/WALLMOUNT
1 Alantek Rackmount fiber enclosures, SC 12 port 306-8R0012-MM02
2 Alantek Rackmount fiber enclosures, SC 24 port 306-8R0024-MM02
3 Alantek Rackmount fiber enclosures, ST 12 port 306-8R0012-MM01
4 Alantek Patch Panel SM Duplex LC full loaded, 24 port 306-8R0012-SM07
5 Alantek Patch Panel MM Duplex LC full loaded, 24 port 306-8R0024-MM07
6 Alantek Pacth Panel MM Duplex LC full loaded, 12 port 306-8R0012-MM07
7 Alantek Rackmount fiber enclosures, ST 24 port 306-8R0024-MM01
8 Alantek Wall mount fiber enclosures, SC 6 port 306-8W0006-MM02
9 Alantek Wall mount fiber enclosures, SC12 port 306-8W0012-MM02
10 Alantek Wall mount fiber enclosures, ST 12 port 306-8W0012-MM01
11 Alantek Wall mount fiber enclosures, ST 6 port 306-8W0006-MM01
RACKMOUNT/WALLMOUNT (NEW GOODS)
1 Alantek Rack Mount Blank Fiber Optic Panel 1U 19" 306-8R1UBN-0000
2 Alantek Rack Mount Blank Fiber Optic Panel 2U 19" 306-8R2UBN-0000
3 Alantek Blank Adaptor Plate 306-8P0000-0000
4 Alantek Wall mount Blank Fiber Optic Box 1U 306-8WSBLN-0000
5 Alantek Adaptor Plate SM 6 Port Loaded ST 306-8S0106-SM00
6 Alantek Adaptor Plate MM 6 Port Loaded ST 306-8S0106-MM00
7 Alantek Adaptor Plate SM 12 Port Loaded ST 306-8S0112-SM00
8 Alantek Adaptor Plate MM 12 Port Loaded ST 306-8S0112-MM00
9 Alantek Adaptor Plate SM 6 Port Loaded SC 306-8S0206-SM00
10 Alantek Adaptor Plate MM 6 Port Loaded SC 306-8S0206-MM00
11 Alantek Adaptor Plate SM12 Port Loaded SC 306-8S0212-SM00
12 Alantek Adaptor Plate MM 12 Port Loaded SC 306-8S0212-MM00
13 Alantek Adaptor Plate SM 12 Port Loaded FC 306-8S0312-SM00
14 Alantek Duplex (6) Adaptor Plate SM 12 Port Loaded SC 306-8D0212-SM00
15 Alantek Duplex (6) Adaptor Plate MM 12 Port Loaded SC 306-8D0212-MM00
PATCH CORD SM 9/125
1 Alantek S-Mode 9/125 Patch Cord FC/SC (Simplex), 5m 306-71023M-0050
2 Alantek S-Mode 9/125 Patch Cord FC/SC (Simplex), 3m 306-71023M-0030
3 Alantek S-Mode 9/125 Patch Cord FC/SC, 10m 306-72037M-0100
4 Alantek S-Mode 9/125 Patch Cord ST/LC 3m 306-72017M-0030
5 Alantek S-Mode 9/125 Patch Cord ST/SC 3m 306-72012M-0030
6 Alantek S-Mode 9/125 Patch Cord ST/ST 3m 306-72011M-0030
7 Alantek S-Mode 9/125 Patch Cord SC/SC 3m 306-72022M-0030
8 Alantek S-Mode 9/125 Patch Cord SC/SC 15m 306-72022M-0150
9 Alantek S-Mode 9/125 Patch Cord SC/LC 3m 306-72027M-0030
10 Alantek S-Mode 9/125 Patch Cord ST/LC 3m 306-72017M-0030
11 Alantek S-Mode 9/125 Patch Cord SC/MTRJ 3m 306-72028M-0030
12 Alantek S-Mode 9/125 Patch Cord LC/LC 3m 306-72077M-0030
13 Alantek S-Mode 9/125 Patch Cord MTRJ/MTRJ 3m 306-72088M-0030
14 Alantek S-Mode patch cord FC/LC, 3m 306-72037M-0030
15 Alantek S-Mode patch cord FC/FC, 20m 306-72033M-0200
16 Alantek S-Mode patch cord FC/FC, 3m 306-72033M-0030
17 Alantek S-Mode patch cord FC/FC, 5m 306-72033M-0050
18 Alantek S-Mode patch cord FC/FC, 1m 306-72033M-0010
19 Alantek S-Mode patch cord SC/SC, 1m 306-72022M-0010
20 Alantek S-Mode patch cord FC/MTRJ, 6m 306-72038M-0060
21 Alantek S-Mode patch cord FC/MTRJ, 10m 306-72038M-0100
22 Alantek S-Mode patch cord FC/MTRJ, 15m 306-72038M-0150
23 Alantek S-Mode patch cord SC/FC, 20m 306-72023M-0200
24 Alantek S-Mode patch cord SC/FC, 10m 306-72023M-0100
25 Alantek S-Mode patch cord SC/FC, 5m 306-72023M-0050
26 Alantek FO S-Mode patch cord SC/SC, 10m 306-72022M-0100
27 Alantek FO S-Mode patch cord MTRJ/SC, 10m 306-72028M-0100
28 Alantek FO S-Mode patch cord FC/SC, 15m 306-72023M-0150
CONVERTER
1 Alantek Converter MM 10/100 SC cable 3MC-FDM2EX-TE02
2 Alantek Converter MM 10/100 SC cable 3MC-FDM2EX-TU02
3 Alantek Converter MM 10/100/1000 SC 3MC-GDM2IX-T002
4 Alantek Converter MM 10/100/1000, SC, 550m 3MC-GDM2IX-T000
5 Alantek Converter SM 10/100 SC cable 3MC-FDS2EX-TU25
6 Alantek Converter SM 10/100 SC cable 3MC-FDS2EX-TE25
7 Alantek Converter SM 1000 SC 3MC-GDS2IX-T020
8 Alantek Converter Ethernet 14 Slots Rack 3MC-RK14DP-T000
AUDIO/CONTROL & INSTRUMENTATION CABLES
1 Alantek audio/control 16AWG, 1 pair cable (500m/rl) 301-CI9501-0000
2 Alantek audio/control 16AWG, 2 pair cable (500m/rl) 301-CI9502-0000
3 Alantek audio/control 16AWG, 4 pair cable (500m/rl) 301-CI9504-0000
4 Alantek audio/control 16AWG, 10 pair cable (500m/rl) 301-CI9510-0000
5 Alantek audio/control 18AWG, 1 pair cable (500m/rl) 301-CI9401-0000
6 Alantek audio/control 18AWG, 2 pair cable (500m/rl) 301-CI9402-0000
7 Alantek audio/control 18AWG, 3 pair cable (500m/rl) 301-CI9403-0000
8 Alantek audio/control 18AWG, 4pair cable (500m/rl) 301-CI9404-0000
9 Alantek audio/control 22AWG, 1 pair cable (500m/rl) 301-CI9201-0000
10 Alantek audio/control 22AWG, 2 pair cable (500m/rl) 301-CI9202-0000
11 Alantek audio/control 22AWG, 3 pair cable (500m/rl) 301-CI9203-0000
12 Alantek audio/control 22AWG, 4 pair cable (500m/rl) 301-CI9204-0000
13 Alantek audio/control 20AWG, 1 pair cable (500m/rl) 301-CI9301-0000
14 Alantek audio/control 20AWG, 2 pair cable (500m/rl) 301-CI9302-0000
15 Alantek audio/control 20AWG, 3 pair cable (500m/rl) 301-CI9303-0000
16 Alantek audio/control 20AWG, 4 pair cable (500m/rl) 301-CI9304-0000
AUDIO/CONTROL & INSTRUMENTATION CABLES LSZH
1 Alantek PA / Control shield cable 16 AWG- 1-pair 301-CI9501-00LS
2 Alantek PA / Control shield cable 18 AWG- 1-pair 301-CI9401-00LS
6499 1 028-01 Cat 5e UTP Cable (Test up to 350MHz)
6653 1 587-24 Cat 5e Patch Panel 24-port w/ Rear Cable Manager, PCB-type
EKOHCMB EKORACK Patch Cord Manager w/ Cover (Metal)
6451 5 0XX-20 Cat 5e UTP Patch Cord - 2m (XX=94: Grey, XX=39: Blue, XX=97: Orange)
6540 5 110-00 Cat 5e RJ45 Modular Jack UTP, Keystone In-line, T568 A/B
6538 3 112-04 Faceplate US (115 x 70) w/ shutter, Horizontal 2-port
ENTERPRISE SOLUTION - CAT 6 (1-Gpbs, 250MHz, 20+5 year Warranty)
6499 1 030-01 Cat 6 UTP Cable (24AWG Star-Filler and Reel-in-the-box design)
6653 1 679-24 Cat 6 Patch Panel 24-port TrueNET w/ Rear Cable Manager, PCB-type
6451 5 9XX-20 Cat 6 UTP Patch Cord - 2.1m (XX=94: Grey, XX=39: Blue, XX=90: Red)
6830 1 800-01 Cat 6 RJ45 Modular Jack UTP
GLOBAL LEADER SOLUTION - Cat 6A (10-Gpbs 500MHz, 20+20 year Warranty)
10G-A6TR-XXXX Horizontal Cable Cat 6A UTP CopperTen (10 Gbit, TIA-568B standard) - (XXXX =BLM2: Blue, XXXX=GYM2: Grey) (305m reel)
TPNP-NNC10-NN
Patch Panel Cat 6A CopperTen 24-port w/ rear cable manager
6830 5 835-04 Modular Jack RJ45 Cat 6A CopperTen UTP
6645 2 820-10 Patch Cord RJ45 Cat 6A CopperTen UTP - 3m
PATCH-BY-EXCEPTION - HIGHBAND SOLUTIONS
6450 1 107-01 Cat 6A CopperTen HIGHBAND 240-pr Cross Connection Kit (12 HB 20-pr CAT6A modules + 12 Label Holders + 1 Backmount Frame 12 way)
6450 1 103-10 HIGHBAND 300pr DUAL Cable Management Kit (2 dual rings, 1 dual cover) BLACK COLOR
6450 2 157-10 Cable Trough Top
6450 2 157-20 Cable Trough Bottom
6645 2 820-50 Cat 6A UTP RJ45 Patch Cord CopperTen - 15m, Blue
6451 2 401C-20 HIGHBAND 20 Patch Cord Cat 6A CopperTen UTP 4-pr to 4-pr 2.1m
6451 2 401C-30 HIGHBAND 20 Patch Cord Cat 6A CopperTen UTP 4-pr to 4-pr 3.0m
6451 2 401C-40 HIGHBAND 20 Patch Cord Cat 6A CopperTen UTP 4-pr to 4-pr 4.5m
ENTERPRISE SOLUTION - CAT 6 (1-Gpbs, 250MHz)
6450 1 101-10 Cat 6 - HIGHBAND 300-pr Cat 6 Cross Connect Kit (12 HB 25-pr Cat 6 modules + 12 Label Holders + 1 Backmount Frame 12 way)
6451 5 9XX-01B Cat 6 UTP Patch Cord 568B - 15m (XX=94: Grey, XX=39: Blue)
6451 2 701C-30 HIGHBAND 25 Cat 6 Patch Cord 4-pr to 4-pr - 3m
6451 2 706-30
HIGHBAND 25 Cat 6 Patch Cord 4-pr to RJ45 - 3m (568B)
SME SOLUTION - CAT 5e (100-Mpbs, 100MHz)
6450 1 180-00 Cat 5e - HIGHBAND 300-pr Cat 5e Broadband 19" Rackmount Kit (12 HB 25-pr Cat 5e modules + 12 Label Holders + 1 Backmount Frame 12 way)
6468 5 061-00 Cat 5e - HIGHBAND 10 Disconnection Module 10-pr (box of 10 pcs)
6451 5 0XX-00 Cat 5e UTP Patch Cord - 10m (XX=94: Grey, XX=39: Blue, XX=97: Orange)
6451 2 706-30 HIGHBAND 25 Cat 6 Patch Cord 4-pr to RJ45 - 3m (568B)
TOTAL COPPER PRODUCTS
MODULE - VOICE/ DATA
6089 1 121-02 VOICE - LSA Profile Disconnection Module Serie 2/10 (KH23) (box of 10pcs)
6468 2 060-00 Cat 5e - HIGHBAND Disconnection Module 8-pr (box of 10pcs)
6468 5 061-00 Cat 5e - HIGHBAND Disconnection Module 10-pr (box of 10pcs)
6468 2 060-06 Cat 6 - HIGHBAND Ultim8 Disconnection Module 8-pr (box of 10pcs)
6468 5 300-00 Cat 5e - HIGHBAND Disconnect Module 25-pr (Box of 12 pcs)
6468 5 600-00 Cat 6 - HIGHBAND Disconnect Module 25-pr (Box of 12 pcs)
6462 2 097-00 HIGHBAND 1 pr Disconnection Plug (Box of 20 pcs)
6462 2 096-00 HIGHBAND Label Holder (Clear Cover Strip) (Bag of 10pcs)
6451 2 207-00 HIGHBAND Test cord, 1 pair to banana plugs
OVER VOLTAGE PROTECTION for VOICE & XDSL Application (5-point w/ PTC)
6905 2 330-00 VOICE - Single pair protection plug 5-point w/ PTC - (use w/ LSA series 2) (Box of 10 pcs w/ earth bar)
5909 1 076-00 ADSL - Single pair protection Plug 5-point w/ PTC - ComProtect 2/1 CP BI 180A1 (bandwidth up to 8Mpbs) (for LSA series 2) (Box of 10 pcs w/ earth bar).
7042 1 002-00 ADSL - Single pair protection Plug 5-point w/ PTC - ComProtect 2/1 CP BI 180A1 (bandwidth up to 8Mpbs) (for HIGHBAND) (Box of 10 pcs w/ earth bar).
6905 3 320-00 Earth Bar 2/10 (box of 10 pcs)
COPPER CABLES (Solid Horizontal)
6499 5 025-02 Cat 5 UTP 25-pr CMR Powersum Riser Cable
6462 3 430-35 Cat 5e UTP 25-pr CMR Powersum Riser Cable
6462 3 430-45 Cat 5e UTP 4-pr LSZH Cable
6499 1 023-03 Cat 5e FTP 4-pr Cable
6462 1 082-00 Cat 6 UTP 4-pr LSZH Cable
7053 3 271-55 Cat 6 F/FTP 4-pr LSZH Cable (1.000m reel)
PATCH PANEL UTP/STP & CABLE MANAGEMENT
6653 1 587-48 Cat 5e Patch Panel 48-port w/ Rear Cable Manager, PCB-type
6653 1 677-48 Cat 6 Patch Panel 48-port TrueNET w/ Rear Cable Manager, PCB-type
PP24AC6T-A Cat 6 Patch Panel Angle 24-port TrueNET Dynamic Left/Right Angle
7022 2 150-24
MODULAR Patch Panel 24-port HK Keystone, w/ MASTERMINDER Rear Cable Manager (Unloaded). Ready for UTP/STP Cat 5e & Cat 6 Modular jacks
MODULAR JACK UTP/ STP
6540 1 154-02 Cat 5e STP Keystone RJ-45 modular Jack T568 A/B
6467 4 202-00 Cat 6 UTP Leadframe FMK RJ-45 modular Jack (for Clipsal faceplate)
6830 1 810-01 Cat 6 STP/FTP RJ-45 Modular Jack, T568 A/B
FACE PLATES & SURFACE MOUNT BOXES
6538 3 111-03 Faceplate UK (85 x 85) w/ shutter, 1-port
6538 3 111-04 Faceplate UK (85 x 85) w/ shutter, 2-port
6538 3 112-03 Faceplate US (144.5 x 70) w/ shutter, Horizontal 1-port
6538 3 112-04 Faceplate US (144.5 x 70) w/ shutter, Horizontal 2-port
6644 1 152-02 Faceplate US (115 x 70), Flush Mount, Vertical 2-port
6644 1 154-02 Faceplate US (115 x 70), Flush Mount, Vertical 4-port
6644 1 222-02 Surface Mount Box, 2-port
6644 1 224-02 Surface Mount Box, 4-port
6467 1 075-00 Surface Mount Box SMK, 2-port
6455 1 058-00 MUTO Surface mount box kit, 12-port
CONSOLIDATION POINT
6455 1 051-00 Consolidation Box 24 pair
6455 1 057-00 Consolidation Box 48 pair
6450 1 105-01 Cat 6 Consolidation Point Kit
PATCH CORDS
CAT 5e RJ45 Patch Cord, Molded Boot, Factory Tested & Certified
6451 5 0XX-10 CAT5E UTP Patch Cord - 1m (XX=94: Grey, XX=39: Blue, XX=97: Orange)
6451 5 0XX-20 CAT5E UTP Patch Cord - 2m (XX=94: Grey, XX=39: Blue, XX=97: Orange)
6451 5 0XX-30 CAT5E UTP Patch Cord - 3m (XX=94: Grey, XX=39: Blue, XX=97: Orange)
6451 5 0XX-50
CAT5E UTP Patch Cord - 5m (XX=94: Grey, XX=39: Blue, XX=97: Orange)
CAT 6 RJ45 Patch Cord, Molded Boot, Factory Tested & Certified
6451 5 9XX-10 Cat 6 UTP Patch Cord 568A - 1.2m (XX=94: Grey, XX=39: Blue, XX=97: Red)
6451 5 9XX-20 Cat 6 UTP Patch Cord 568A - 2.1m (XX=94: Grey, XX=39: Blue, XX=97: Red)
6451 5 9XX-30 Cat 6 UTP Patch Cord 568A - 3m (XX=94: Grey, XX=39: Blue, XX=97: Red)
6451 5 9XX-50 Cat 6 UTP Patch Cord 568A - 5m (XX=94: Grey, XX=39: Blue, XX=97: Red)
6451 5 9XX-50B Cat 6 UTP Patch Cord 568B - 5m (XX=94: Grey, XX=39: Blue, XX=97: Red)
6451 5 9XX-00 Cat 6 UTP Patch Cord 568A - 10m (XX=94: Grey, XX=39: Blue)
6451 5 9XX-00B Cat 6 UTP Patch Cord 568B - 10m (XX=94: Grey, XX=39: Blue)
6451 5 9XX-01 Cat 6 UTP Patch Cord 568A - 15m (XX=94: Grey, XX=39: Blue)
6451 5 939-04 Cat 6 UTP Patch Cord 568A - 20m
6451 5 939-04B Cat 6 UTP Patch Cord 568B - 20m
6451 5 939-09 Cat 6 UTP Patch Cord 568A - 30m
6451 5 939-09B Cat 6 UTP Patch Cord 568B - 30m
6451 5 693-10B Cat 6 S/FTP Patch Cord 568B LSZH - 1.2m
6451 5 693-20B Cat 6 S/FTP Patch Cord 568B LSZH - 2.1m
6451 5 693-30B Cat 6 S/FTP Patch Cord 568B LSZH - 3m
6451 5 693-40B Cat 6 S/FTP Patch Cord 568B LSZH - 5m
Cat 6A RJ45 Patch Cord, Molded Boot, Factory Tested & Certified
6645 2 820-07 Cat 6A UTP Patch Cord CopperTen - 2.1m
6645 2 820-10 Cat 6A UTP Patch Cord CopperTen - 3m
6645 2 820-15 Cat 6A UTP Patch Cord CopperTen - 4.5m
6645 2 820-25 Cat 6A UTP Patch Cord CopperTen - 10m
6645 2 820-50 Cat 6A UTP Patch Cord CopperTen - 15m
6645 2 820-66 Cat 6A UTP Patch Cord CopperTen - 20m
6645 2 820-99
Cat 6A UTP Patch Cord CopperTen - 30m
HIGHBAND Patch Cord - Ultim8 patch cord
6451 2 701C-20 Cat 6 HIGHBAND 25 Patch Cord 4-pr to 4-pr - 2.1m
6451 2 701C-30 Cat 6 HIGHBAND 25 Patch Cord 4-pr to 4-pr - 3m
6451 2 701C-40 Cat 6 HIGHBAND 25 Patch Cord 4-pr to 4-pr - 4.5m
6451 2 706-30 Cat 6 HIGHBAND 25 Patch Cord 4-pr to RJ45 568B - 3m
TP6TB-BL10 Cat 6 HIGHBAND Ultim 8 Patch Cord 4-pr to RJ45 568B - 3m
6451 2 051-31 Cat 6 HIGHBAND Ultim8 Patch Cord 4-pr to 4-pr - 3m
TOOLS
6417 2 055-01 KRONE LSA Sensor Insertion Tool
6830 1 490-00 Termination Crimper for Cat 6 Module
Nguyễn Thị Nhung
Sales Senior
Skype: nguyenthinhung1992 Yahoo: lotus_kd5
Mobile: 0949.903.003 / 0975.986.620
HQTELECOM
LIÊN HỆ:
CATEGORY 5E CABLE
JACK CAT5E
RJ45 PLUG
FACEPLATE
MOUNT BOX
PARCH PANEL CAT5E
RUBBER BOOT
PATCH CABLE CAT5E
PATCH CORD CAT5E
CATEGORY 6 CABLE
JACK CAT6
PATCH CORD CAT6
PATCH PANEL CAT6
COAXIAL CABLE
SPLITTER
TAP & SPLITTER
F-CONNECTOR
TOOLS
MODULATORS
FO CONNECTOR
RACKMOUNT/WALLMOUNT
PATCH CORD SM 9/125
CONVERTER
TPNP-NNC10-NN
6451 2 706-30
7022 2 150-24
CONSOLIDATION POINT
PATCH CORDS
6451 5 0XX-50
6645 2 820-99
TOOLS
Nguyễn Thị Nhung
Sales Senior
