Reliable and affordable L4-7 Server Load Balancing
Regardless of the application or environment, the E250GX scales your applications while staying within your budget.
Features
Great for
Web applications aren't the only servers in the data center. With the E250GX, you can load balance servers for email, portals, ERP applications, file transfer (FTP), terminal services and many more. The E250GX provides scalability and high availability for all your applications in one easy to configure hardware appliance.
The E250GX provides ample capacity to manage mission-critical web applications, content and infrastructure servers. The E250GX scales as your business grows to support up to 64 clusters containing up to 16 servers each. No other product in its class is as scalable or reliable.
Specifications
Features
- Load balance Web, email, file transfer and database protocols
- 1.2 Gb/s L4 throughput
- Support high availability deployments
- Add and remove servers without service interruption
- Configure and install in less than 30 minutes
Great for
- Small to mid-size organizations
- Single data center server expansion/reconfiguration
- 100% uptime of your mission critical applications
Specifications
- Clusters: 64
- Servers per Cluster: 16
- Applications Supported: All Web/HTTP-based applications (PHP, ASP, Oracle, Apache, etc.), Microsoft Products (SharePoint, Exchange, Link, OWA, etc.), SSL VPN, Database clustering, Email services, Streaming Media
- Load Balancing Features/ Algorithms: L4 TCP/UDP SLB, L7 HTTP/HTTPS SLB, Cookie Insertion/Persistence, Custom Header Injection, L4 port range support, User defined custom LB policy, Server connection limits, VLB basic SLB, IPV6 SLB (L7 clusters only)
- Envoy GSLB: Included
- Global Server LB Features: Latency based Geo LB policy, Geo LB by Site Load, Geo LB by Site Weight, Adaptive Geo LB, MX record support, IPv6 quad A record support
- High Availability Features: Subnet control for peer heartbeat. Active-Active Failover
- Fault Tolerance: Full system-level redundancy (requires two Equalizers), Server heartbeat and configuration data exchanges over Ethernet
- Security: Global Object SSL Certificate Storage, Implicit Deny on Exterior Elements, Non Root CLI, Configurable Acess Control Lists
- Network Features: Single Network, Dual Multi-Network, Direct Server Return, Multi-netting, Configurable Outbound NAT function, NTP Client and Server option
- SSL Offloading: Software
- HTTP Compression: N/A
- Acceleration Features: Software SSL, Outbound http to https URL rewrite, SSL Cipher Suite Control
- Health Checking/ Monitors: ACV (Active Content Verification), Server Side Agents, VLB - VMWare API health check, Web UI, Graphical utilization reports for all configuration objects, Configurable L3 probes, Enhanced L4 protocol checks
- Management/ Reporting: Context sensitive CLI, API, Role Based Admin, Email notification, CSV Export, Utilization plotting, Proprietary SNMP MIB , Remote Syslog, Server Pool objects, Drag and Drop, Graphical Dashboard, Enhanced Plotting, i18N messaging with coding, Event Handler
- Ethernet: 2 Gigabit (1000base-T)
- Power: 110 VAC - 29W, 220 VAC - 40W, auto selecting 50/60 Hz
- Dimensions: H 1.75" W 17.25" D 10.5"
- Weight: 7lbs. (3.2kg)
- Environmental Temp.: 40-105 F, 5-40 C
- Humidity: 5-90%, non-condensing
