SX-3000GB Gigabit Ethernet USB Device Server -chia sẻ máy scan, máy fax,.. qua mạng
  • SX-3000GB Gigabit Ethernet USB Device Server -chia sẻ máy scan, máy fax,.. qua mạng
    Network your USB devices over Gigabit Ethernet!
    With the SX-3000GB, silex technology is introducing the next generation of USB device servers. Network your USB devices with even more data throughput and higher compatibility. 2 USB ports are available. Using a USB hub up to 15 simultaneous USB connections are possible.
    It turns your USB devices into network resources. When a USB device is connected through the USB Device Server, it can be used by any network user as though it were locally connected.
    Printing, scanning, faxing, storage (NTFS and FAT), listening to music, synchronising iPhone with iTunes, securing software with USB dongles – all functions become available over the network. The integration of USB devices into virtual environments - VMWare, Citrix, Hyper-V etc. - is also supported.
    Of course, the SX-3000GB is also compatibel with 10/100 Base-TX networks.
    SX-Virtual Link - the software that automatically detects all USB devices and USB device servers on the network. You can connect to a device and make it available as if it was locally connected.
    Technical description:
    Supported Operating Systems: Windows 7/Vista/XP, Server 2008/2003, Mac OS X v.10.3-10.7
    Device Interfaces: 2x USB 2.0 Hi-Speed, one with a 4 times the current supply provided by a conventional USB port (up to 2000 mA)
    Using an optional USB hub, a max. of 15 USB connections are possible
    Network Interfaces: 10/100/1000 Mbps (auto-detect)
    USB Device Server and Print Server in one device
    Compatible with the current printer protocols IPP (Internet Printing Protocol), LPR (Line Printer Remote protocol), RAW and GDI (Graphics Device Interface)
    Particular security due to IP address filter
    250 MHz CPU, 4 MB Flash, 32 MB DDR-RAM
    Compatible with NTFS and FAT formatted memory
    http://thegioimang.biz
    VNE,jsc - Chuyên cấp các thiết bị mạng, thiết bị quản lý băng thông Cisco, Fortinet, Juniper, Peplink,...
    Địa chỉ: P.402A - tòa nhà 347 Đội Cấn Ba Đình Hà Nội
    Tại T.p Hồ Chính Minh: 610 Võ Văn Kiệt, Phường Cầu kho, Q1, T.p HCM
    Tel: 84.4.62731335/22124123 email: sales@thegioimang.biz | hotline 0989069456 | Y/M: salevne
