Hi các bạn,
Hiện tại mình có 2 sever 2008 sp1 đang chạy cluster file server. Bây giờ mình muốn nâng cấp lên window server 2008 R2 nhưng lúc mình upgrade thì nó báo lỗi này
Before continuing with the upgrade, make sure software vendors support your software on Windows Server 2008 R2. Follow their software specific recommendations before and after the upgrade. To verify software compatibility on the Windows Server Catalog and to download tools and documentation, go to http://go.microsoft.com/fwlink/?LinkID=85172
Important: If the software isn’t supported on Windows Server 2008 R2, or if the software vendor does not support software that is installed during the upgrade of the operating system, uninstall that software before you upgrade. If you do not uninstall the software, your system will be unsupported, the software might not work, and software settings or other information might be lost.
The following issues are preventing Windows from upgrading. Cancel the upgrade, complete each task, and then restart the upgrade to continue.
For these items, make the following changes:
Turn off these Windows features.
Server Clustering - Please read Microsoft Knowledge Base article: 935197
Upgrading Windows will affect the following features:
Windows Mail is no longer included in Windows; however your e-mail files and settings will still be available after the upgrade. To send and receive e-mail you will need to install a new e-mail program. You can get e-mail programs from other software manufacturers or from the Microsoft website.
