! Last configuration change at 03:04:56 UTC Fri Jul 11 2014
! NVRAM config last updated at 05:13:00 UTC Sat Jul 12 2014
version 12.4
service timestamps
debug datetime msec
hostname BB
boot-start-marker
boot-end-marker
card type t1 0 1
card type e1 0 2
no aaa new-model
no network-clock-participate
wic 0
wic 1
wic 2
dot11
syslog
ip cef
no ip dhcp use vrf connected
ip dhcp pool BB
network 10.10.253.0 255.255.255.0
option 150 ip 10.10.254.11
default-router 10.10.253.1
no ip domain lookup
multilink bundle-name authenticated
frame-relay switching
isdn switch-type primary-ni
voice-card 0
no dspfarm
voice service voip
allow-connections h323 to h323
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
bind control source-interface FastEthernet0/1
bind media source-interface FastEthernet0/1
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice translation-rule 49
rule 1 /^49\(894443...$\)/ /\1/
voice translation-rule 100
rule 1 /^6131218$/ /1408\0/ type subscriber subscriber
rule 2 /^4086131218$/ /1\0/ type national national
rule 3 /^14086131218$/ /\0/ type international international
rule 4 /^7764016$/ /1312\0/ type subscriber subscriber
rule 5 /^3127764016$/ /1\0/ type national national
rule 6 /^13127764016$/ /\0/ type international international
rule 7 /^307128788$/ /49\0/ type national national
rule 8 /^49307128788$/ /\0/ type international international
rule 9 /^689220420$/ /\0/ type international international
rule 10 /^8662258064$/ /1\0/ type national national
rule 11 /^18662258064$/ /\0/ type international international
rule 12 /^9[19][19]$/ /911/ type subscriber subscriber
rule 13 /^8103321444$/ /18662258064/ type national national
rule 14 /^18103321444$/ /18662258064/ type international international
rule 15 // /1111/
voice translation-rule 200
rule 1 /^2221...$/ /408\0/ type any subscriber plan any isdn
rule 2 /^3332...$/ /312\0/ type any subscriber plan any isdn
rule 3 /^894443...$/ /\0/ type any national plan any isdn
rule 4 /^4082221...$/ /\0/ type any national plan any isdn
rule 5 /^3123332...$/ /\0/ type any national plan any isdn
rule 6 /^14082221...$/ /\0/ type any international plan any isdn
rule 7 /^13123332...$/ /\0/ type any international plan any isdn
rule 8 /^49\(894443...$\)/ /\1/ type any international plan any isdn
voice translation-rule 201
rule 1 /^4930.*/ /\0/ type any international plan any isdn
rule 2 /^30.*/ /\0/ type any international plan any isdn
voice translation-profile GERMANY-SRST
translate called 49
voice translation-profile TRANSLATE-CUCM-INBOUND
translate calling 201
translate called 200
voice translation-profile TRANSLATE-SITES-INBOUND
translate called 100
archive
log config
hidekeys
controller T1 0/1/0
framing esf
clock source internal
linecode b8zs
cablelength long 0db
pri-group timeslots 1-3,24
description **VOICE T1 TO R1 0/0/0**
controller T1 0/1/1
framing esf
linecode b8zs
description **VOICE T1 TO R2 0/0/0**
controller E1 0/2/0
pri-group timeslots 1-3,16
description **VOICE E1 TO R3 0/0/0**
pseudowire-class ethernet
encapsulation l2tpv3
ip local interface FastEthernet0/0.100
interface Loopback0
ip address 10.10.4.4 255.255.255.255
duplex auto
s
peed auto
description *** HQ DATA VLAN ***
encapsulation dot1Q 100
ip address 10.10.100.2 255.255.255.0
ip ospf mtu-ignore
interface FastEthernet0/0.199
description *** PSTN VLAN ***
encapsulation dot1Q 199
ip address 10.10.253.1 255.255.255.0
ip tcp adjust-mss 1360
description TRUNK_TO_BB_L2VPN-Gi1/0/1
duplex auto
speed auto
interface FastEthernet0/1.113
description SW1-Fa1/0/13_L2TP
encapsulation dot1Q 113
no ip redirects
no ip unreachables
no ip proxy-arp
ip tcp adjust-mss 1350
xconnect 192.168.14.1 113 pw-class ethernet
interface FastEthernet0/1.114
description SW1-Fa1/0/14_L2TP
encapsulation dot1Q 114
no ip redirects
no ip unreachables
no ip proxy-arp
xconnect 192.168.14.1 114 pw-class ethernet
interface FastEthernet0/1.115
description SW1-Fa1/0/15_L2TP
encapsulation dot1Q 115
no ip redirects
no ip unreachables
no ip proxy-arp
xconnect 192.168.14.1 115 pw-class ethernet
interface FastEthernet0/1.222
description R2-Gi0/2/2_L2TP
encapsulation dot1Q 222
no ip redirects
no ip unreachables
no ip proxy-arp
xconnect 192.168.14.1 222 pw-class ethernet
interface FastEthernet0/1.223
description R2-Gi0/2/3_L2TP
encapsulation dot1Q 223
no ip redirects
no ip unreachables
no ip proxy-arp
xconnect 192.168.14.1 223 pw-class ethernet
interface FastEthernet0/1.254
encapsulation dot1Q 254
ip address 10.10.254.254 255.255.255.0
interface FastEthernet0/1.322
description R3-Gi0/2/2_L2TP
encapsulation dot1Q 322
no ip redirects
no ip unreachables
no ip proxy-arp
xconnect 192.168.14.1 322 pw-class ethernet
interface FastEthernet0/1.323
description R3-Gi0/2/3_L2TP
encapsulation dot1Q 323
no ip redirects
no ip unreachables
no ip proxy-arp
xconnect 192.168.14.1 323 pw-class ethernet
interface Serial0/0/0
clock rate 2016000
interface Serial0/0/1
description ** SERIAL DATA CONNECTION TO R1 **
encapsulation frame-relay IETF
clock rate 2016000
frame-relay lmi-type ansi
frame-relay intf-type dce
frame-relay route 102 interface Serial0/0/2 201
frame-relay route 103 interface Serial0/0/3 301
description ** SERIAL DATA CONNECTION TO R2 **
clock rate 2016000
frame-relay route 201 interface Serial0/0/1 102
description ** SERIAL DATA CONNECTION TO R3 **
clock rate 2016000
frame-relay route 301 interface Serial0/0/1 103
interface Serial0/1/0:23
encapsulation hdlc
isdn protocol-emulate network
isdn incoming-voice voice
no cdp enable
interface Serial0/1/1:23
encapsulation hdlc
no cdp enable
interface Serial0/2/0:15
encapsulation hdlc
no cdp enable
interface GigabitEthernet1/0
ip address 10.10.252.1 255.255.255.0
router ospf 1
router-id 10.10.4.4
log-adjacency-changes
network 10.0.0.0 0.255.255.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
voice-port 0/1/0:23
voice-port 0/2/0:15
voice-port 0/1/1:23
dial-peer voice 101 pots
destination-pattern 2221...$
port 0/1/0:23
forward-digits all
dial-peer voice 102 pots
destination-pattern 4082221...$
port 0/1/0:23
forward-digits all
dial-peer voice 103 pots
destination-pattern 14082221...$
port 0/1/0:23
forward-digits all
dial-peer voice 201 pots
destination-pattern 3332...$
port 0/1/1:23
forward-digits all
dial-peer voice 202 pots
destination-pattern 3123332...
port 0/1/1:23
forward-digits all
dial-peer voice 203 pots
destination-pattern 13123332...$
port 0/1/1:23
forward-digits all
dial-peer voice 301 pots
destination-pattern 894443...$
port 0/2/0:15
forward-digits all
dial-peer voice 303 pots
destination-pattern 49894443...$
port 0/2/0:15
forward-digits all
dial-peer voice 49 voip
destination-pattern 49307128788$
voice-class codec 1
session protocol sipv2
session target ipv4:10.10.254.11
dtmf-relay sip-notify rtp-nte
no vad
dial-peer voice 911 voip
destination-pattern 911$
voice-class codec 1
no vad
dial-peer voice 1 pots
translation-profile incoming TRANSLATE-SITES-INBOUND
incoming called-number .
direct-inward-dial
dial-peer voice 100 voip
translation-profile incoming TRANSLATE-CUCM-INBOUND
no vad
dial-peer voice 408 voip
destination-pattern 14086131218$
voice-class codec 1
no vad
dial-peer voice 312 voip
destination-pattern 13127764016$
voice-class codec 1
no vad
dial-peer voice 999 voip
destination-pattern 999$
voice-class codec 1
s
no vad
dial-peer voice 689 voip
destination-pattern 689220420$
voice-class codec 1
no vad
dial-peer voice 866 voip
destination-pattern 18662258064$
voice-class codec 1
no vad
dial-peer voice 1000 pots
incoming called-number 4082221...$
direct-inward-dial
dial-peer voice 1001 pots
incoming called-number 14082221...$
direct-inward-dial
dial-peer voice 1007 pots
incoming called-number 2221...$
direct-inward-dial
dial-peer voice 2000 pots
incoming called-number 3123332...$
direct-inward-dial
dial-peer voice 2001 pots
incoming called-number 13123332...$
direct-inward-dial
dial-peer voice 2007 pots
incoming called-number 3332...$
direct-inward-dial
dial-peer voice 3000 pots
incoming called-number 894443...$
direct-inward-dial
dial-peer voice 3001 pots
translation-profile incoming GERMANY-SRST
incoming called-number 49894443...$
direct-inward-dial
gatekeeper
shutdown
exec-timeout 0 0
privilege level 15
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
login
scheduler allocate 20000 1000
ntp source FastEthernet0/1
ntp master
version 12.4
service timestamps
debug datetime msec
hostname BB
boot-start-marker
boot-end-marker
card type t1 0 1
card type e1 0 2
no aaa new-model
wic 0
wic 1
wic 2
dot11
syslog
ip cef
ip dhcp pool BB
no ip domain lookup
voice-card 0
no dspfarm
voice service voip
sip
voice class codec 1
rule 15 // /1111/
translate called 49
archive
log config
hidekeys
controller T1 0/1/0
framing esf
linecode b8zs
controller T1 0/1/1
framing esf
linecode b8zs
controller E1 0/2/0
interface Loopback0
duplex auto
s
peed auto
ip ospf mtu-ignore
duplex auto
speed auto
no ip redirects
no ip unreachables
no ip proxy-arp
no ip redirects
no ip unreachables
no ip proxy-arp
no ip redirects
no ip unreachables
no ip proxy-arp
no ip redirects
no ip unreachables
no ip proxy-arp
no ip redirects
no ip unreachables
no ip proxy-arp
no ip redirects
no ip unreachables
no ip proxy-arp
no ip redirects
no ip unreachables
no ip proxy-arp
clock rate 2016000
clock rate 2016000
clock rate 2016000
clock rate 2016000
encapsulation hdlc
no cdp enable
encapsulation hdlc
no cdp enable
encapsulation hdlc
no cdp enable
router ospf 1
router-id 10.10.4.4
no ip http server
control-plane
voice-port 0/1/0:23
voice-port 0/2/0:15
voice-port 0/1/1:23
port 0/1/0:23
forward-digits all
port 0/1/0:23
forward-digits all
port 0/1/0:23
forward-digits all
port 0/1/1:23
forward-digits all
port 0/1/1:23
forward-digits all
port 0/1/1:23
forward-digits all
port 0/2/0:15
forward-digits all
port 0/2/0:15
forward-digits all
voice-class codec 1
no vad
voice-class codec 1
no vad
direct-inward-dial
no vad
voice-class codec 1
no vad
voice-class codec 1
no vad
voice-class codec 1
s
no vad
voice-class codec 1
no vad
voice-class codec 1
no vad
direct-inward-dial
direct-inward-dial
direct-inward-dial
direct-inward-dial
direct-inward-dial
direct-inward-dial
direct-inward-dial
direct-inward-dial
gatekeeper
shutdown
exec-timeout 0 0
privilege level 15
line aux 0
line 66
no exec
transport input all
login
ntp master
