Xin tai lieu " Troubleshooting Cisco IP Telephony"
  • Xin tai lieu " Troubleshooting Cisco IP Telephony"
    Chào các bạn,
    Mình đang tìm sách " Cisco AVVID Solution Troubleshooting Cisco IP Telephony" nhưng chưa được. Sách dạng như sau:
    This text teaches students how to identify and resolve IP telephony problems and master troubleshooting skills. It will also be of use to networking professionals responsible for administering and IP telephony system. Reveals the methodology you need to resolve complex problems in an IP telephony network Master troubleshooting techniques and methodologies for all parts of a Cisco IP Telephony solution-Cisco CallManager, IP phones, gateways, applications, and more Learn how to investigate and resolve voice quality problems, including delayed audio, choppy or garbled audio, static and noise, one-way or no-way audio, and echo Read about the variety of trouble-shooting tools at your disposal and how and when to use them based on the problem type Discover the potential causes of common problems and how to efficiently troubleshoot them to resolution Learn how to identify and resolve gateway problems by breaking the components into logical groups and following a methodical troubleshooting approach Use best practices recommendations to build a stronger IP telephony deployment and avoid common mistakes IP telephony represents the future of telecommunications: a converged data and voice infrastructure boasting greater flexibility and more cost-effective scalability than traditional telephony. The ability to troubleshoot an IP telephony environment and the underlying network infrastructure is vitally important, just as it is in any complex system. Troubleshooting Cisco IP Telephony teaches the troubleshooting skills necessary to identify and resolve problems in an IP telephony solution. This book provides comprehensive coverage of all parts of a Cisco IP Telephony (CIPT) solution, including CallManager, IP phones, gateways, analog devices, database and directory replication, call routing, voice mail, applications, network infrastructure, and more. You'll learn how to read trace files, determine when to turn on tracing and Cisco IOS(r) Software
    Bạn nào có thì share cho mình nha!
    Tks all,
    Thắng
    thangbeckham@yahoo.com
    thangph@fpt.net
    Chỉ tìm ra cuốn này:
    Cisco IP Telephony: Planning, Design, Implementation, Operation, and Optimization
    By Ramesh Kaza, Salman Asadullah
    Publisher : Cisco Press
    Pub Date : February 23, 2005
    ISBN : 1-58705-157-5
    Pages : 672
    The comprehensive guide to planning and implementing your Cisco IP Telephony system, as shown by the experts.
    Understand how to work through the different implementation phases of a Cisco IP telephony solution
    Plan your implementation with tools and guides from the most seasoned experts in the industry
    Avoid pitfalls in the process with best-practice suggestions and other tips derived from years of actual implementation experience
    Nếu bạn Thắngbeckham cần thì mình upload lên.
      Mình có tài liệu Cisco Press Troubleshooting Cisco IP Telephony
      Paul Giralt, CCIE No. 4793
      Addis Hallmark
      Anne Smith
      Nếu bạn Thắng cần mình sẽ gửi qua mail.
        Cám ơn thầy Minh và Ken,
        Tài liệu mà mọi người gởi em đã có rồi nhưng viết chưa đủ lắm. Em đang gặp sự cố với Outgoing call từ Voice GW. Mô hình của em như sau:
        FPT ITSP ----sipv2 trunk-----3845----CCM4.0----IP Phone (SIP and SCCP)
        Khi các cuộc gọi ra PSTN tăng cao khoảng 30-40 thì có cuộc không thực hiện được. Em đang nghi do MTP Hardware trên VoiceGW 3845.
        Em cám ơn mọi người.
        Thắng.
