Mình có đọc tài liệu về SIP, nhưng mình không hiểu là SIP-I và SIP-T khác nhau ở điểm nào. Vào chúng được dùng trong các trường hợp cụ thể nào? Mong anh em giúp đỡ. Xin cảm ơn.
SIP-I và SIP-T khác nhau như thế nào?
Originally posted by huutaivn View PostMình có đọc tài liệu về SIP, nhưng mình không hiểu là SIP-I và SIP-T khác nhau ở điểm nào. Vào chúng được dùng trong các trường hợp cụ thể nào? Mong anh em giúp đỡ. Xin cảm ơn.
2. SIP-T
SIP-T is defined by RFC3372 of the IETFMMUSIC working group. The SIP-T protocol suite contains RFC3372, RFC2976, RFC3204 and RFC3398.
SIP-T is an extension of SIP, which inherits the flexibility of SIP, provides additional support for telephone application and therefore is quite suitable for IP networks. SIP-T enables the SIP messages to carry the ISUP signaling. It established three models for interworking between SIP and ISUP on an end-to-end basis, that is, PSTN-PSTN call over an SIP network, SIP-PSTN call, and PSTN-SIP call.
SIP-T provides two methods for the interworking between SIP and ISUP, that is, encapsulation and mapping, which are defined by RFC3204 and RFC3398 respectively. However, the SIP-T only focuses on the interworking of the basic call, and does not involve supplementary services basically.
3. SIP-I
SIP-I contains TRQ.2815 and Q.1912.5 of the ITU-TSG11 working group. TRQ.2815 defines technical requirements for interworking between SIP and Bearer Independent Call Control Protocol (BICC)/ISUP, including interworking interface model, protocol capability set supported by InterWorking Unit (IWU), and security model of the interworking interface. Q.1912.5 defines the interworking between 3GPPSIP and BICC/ISUP, between SIP and BICC/ISUP and between SIP-I and BICC/ISUP in detail, according to different protocol capability sets supported by IWU at the Network-to Network Interface (NNI) on the SIP side.
SIP-I reuses many IETF standards and drafts, which covers not only the interworking of the basic call, but the interworking of the BICC/ISUP supplementary service.
SIP - T has a wider application. For example, in CDMA2000 protocol, SIP-T is used between MSCes.
SIP - I has been regarded as the core interworking protocol between softswitch and traditional telecommunication networks by 3GPP, main telecommunication carriers and big telecommunication equipment supplier around the world.
Attached FilesLast edited by camaptrang; 10-11-2008, 11:00 AM.
CAMAPTRANG
http://www.asterisk.vn
