Công ty mình có AS5300 nhưng mình không biết cấu hình như thế nào để mình có thể quay số vào dùng đường dây diện thoại ở rất xa. Giúp mình với.
Làm sao để cấu hình AS5300 để quay số vào
trên con 5300 bạn đang dùng card/module gì?Đặng Quang Minh, CCIEx2#11897 (Enterprise Infrastructure, Wireless), DEVNET, CCSI#31417
hostname DC-L36-VGWY01
boot-start-marker
boot system flash flash:c5400-js-mz.124-16.bin
no boot startup-test
boot-end-marker
logging buffered 64000 debugging
enable secret 5 $1$PcbT$h/OizrTN/42836OoQubsw1
resource-pool disable
ip cef
ip name-server
ip name-server
isdn switch-type primary-net5
voice rtp send-recv
voice service voip
fax protocol t38 nse force ls-redundancy 0 hs-redundancy 0 fallback none
modem passthrough nse codec g711alaw
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
codec preference 4 g729br8
voice translation-rule 4
rule 1 // /4/
voice translation-rule 7
rule 1 // /7/
voice translation-profile spt
translate called 4
voice translation-profile vnpt
translate called 7
dial-control-mib retain-timer 300
controller E1 7/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
country vietnam
dnis-digits min 1 max 20
ani-digits min 0 max 20
dnis-complete
timer interdigit incoming 7000
controller E1 7/1
framing NO-CRC4
pri-group timeslots 1-31
controller E1 7/2
framing NO-CRC4
cas-custom 0
country vietnam
ani-digits min 1 max 20
dnis-complete
description E1 connect to VNPT
controller E1 7/3
framing NO-CRC4
cas-custom 0
country vietnam
dnis-complete
controller E1 7/4
shutdown
controller E1 7/5
controller E1 7/6
shutdown
controller E1 7/7
shutdown
ip tcp synwait-time 5
interface Loopback0
ip address 10.254.0.75 255.255.255.255
interface FastEthernet0/0
backup interface FastEthernet0/1
ip address
duplex auto
speed auto
mac-address 0011.21b0.3e20
ip address
duplex auto
speed auto
interface Serial0/0
shutdown
clock rate 2000000
interface Serial7/0
shutdown
interface Serial0/1
shutdown
clock rate 2000000
interface Serial7/1:15
encapsulation hdlc
no cdp enable
interface Async1
encapsulation slip
interface Group-Async0
encapsulation slip
group-range 1/00 5/59
ip http server
control-plane
voice-port 7/0:0
input gain 3
voice-port 7/2:0
input gain 3
voice-port 7/3:0
input gain 3
voice-port 7/1:D
dial-peer voice 1 voip
huntstop
service session
destination-pattern 4371...
progress_ind setup enable 3
voice-class codec 1
session protocol sipv2
session target dns:
dtmf-relay rtp-nte
playout-delay mode fixed
fax-relay ecm disable
fax rate 14400
no vad
dial-peer voice 2 voip
huntstop
service session
destination-pattern 71580..
voice-class codec 1
session target dns:
dtmf-relay rtp-nte
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
no vad
dial-peer voice 10 voip
translation-profile incoming spt
answer-address 84......
voice-class codec 1
dial-peer voice 20 voip
translation-profile incoming vnpt
answer-address 87......
voice-class codec 1
dial-peer voice 100 pots
destination-pattern 48.......
progress_ind progress enable 8
direct-inward-dial
port 7/0:0
dial-peer voice 101 pots
destination-pattern 4.T
direct-inward-dial
port 7/0:0
dial-peer voice 102 pots
preference 1
direct-inward-dial
dial-peer voice 103 pots
preference 1
direct-inward-dial
dial-peer voice 200 pots
destination-pattern 78.......
direct-inward-dial
port 7/2:0
dial-peer voice 201 pots
destination-pattern 7.T
direct-inward-dial
port 7/2:0
dial-peer voice 202 pots
preference 1
shutdown
direct-inward-dial
port 7/3:0
dial-peer voice 203 pots
preference 1
shutdown
direct-inward-dial
port 7/3:0
dial-peer voice 300 pots
sip-ua
no remote-party-id
set pstn-cause 47 sip-status 486
retry invite 2
retry response 3
retry bye 3
retry prack 6
timers expires 300000
sip-server dns:
ss7 mtp2-variant Bellcore 0
ss7 mtp2-variant Bellcore 1
ss7 mtp2-variant Bellcore 2
ss7 mtp2-variant Bellcore 3
logging synchronous
login authentication NONE
line aux 0
logging synchronous
line 1/00 1/107
modem InOut
line 3/00 3/107
modem InOut
line 5/00 5/59
modem InOut
endLast edited by ngocky; 29-03-2008, 11:47 PM.
bạn có thể giãi thích chi tiết từng tham số cụ thể của cấu hình
controller E1 7/3
framing NO-CRC4
cas-custom 0
country vietnam
dnis-complete
