Nhờ AE Review dịch vụ FTTH
  • #31
    Cấu hình Cisco 878 với đường ADSL.
    ADSL#sh run
    Current configuration : 1353 bytes
    version 12.4
    no service pad
    hostname ADSL
    boot-start-marker
    boot-end-marker
    enable password xxxxxx
    no aaa new-model
    resource policy
    ip subnet-zero
    ip cef
    vpdn enable
    username admin
    controller DSL 0
    line-term cpe
    interface BRI0
    encapsulation hdlc
    shutdown
    interface FastEthernet0
    interface FastEthernet1
    interface FastEthernet2
    interface FastEthernet3
    interface Vlan1
    ip nat inside
    ip virtual-reassembly
    pppoe enable group global
    interface Dialer1
    mtu 1492
    ip address negotiated
    ip nat outside
    encapsulation ppp
    dialer pool 1
    dialer-group 1
    ppp authentication pap callin
    ppp pap sent-username xxxxx password 0 xxxxxx
    ip classless
    no ip http server
    no ip http secure-server
    ip nat inside source list 1 interface Dialer1 overload
    access-list 1 permit 192.168.1.0 0.0.0.255
    dialer-list 100 protocol ip permit
    control-plane
    password xxxxx
    login
    no modem enable
    line aux 0
    line vty 0 2
    password xxxxx
    login
    line vty 3 4
    login
    scheduler max-task-time 5000
    ADSL#sh ip int brie
    ADSL#sh ip int brief
    Interface IP-Address OK? Method Status Prot
    ocol
    FastEthernet0 unassigned YES unset down down
    FastEthernet1 unassigned YES unset up up
    FastEthernet2 unassigned YES unset down down
    FastEthernet3 unassigned YES unset down down
    BRI0 unassigned YES unset administratively down down
    BRI0:1 unassigned YES unset administratively down down
    BRI0:2 unassigned YES unset administratively down down
    Vlan1 192.168.1.1 YES manual up up
    Dialer1 221.132.49.17 YES IPCP up up
    Virtual-Access1 unassigned YES unset up up
    NVI0 unassigned YES unset up up
    ADSL#ping 203.162.4.1 source 192.168.1.1
    Sending 5, 100-byte ICMP Echos to 203.162.4.1, timeout is 2 seconds:
    Packet sent with a source address of 192.168.1.1
    Success rate is 100 percent (5/5), round-trip min/avg/max = 32/32/32 ms
    • #32
      Bác cứ liên hệ với VNPT Hà Nội (nếu bác ở Hà Nội), họ sẽ làm hết cho bác, cung cấp cả modem quang đầu cuối). Theo tôi được biết hiện nay FPT cũng đang thuê truyền dẫn BackBone (Hà Nội - Đà Nẵng - tp Hồ CHí Minh) của VTN/VNPT và 1 số tuyến từ Hà Nội đi các tỉnh thành phố khác.
      • #33
        Như vậy mình kết luận:
        - Con Rouetr 878 có thể dùng port G.shdsl kết nối Megawan cho các site(cái này xài phổ biến cho các đường Megawan của VNPT),
        - Ngoài ra có thể dùng cấu hình PPPOE ra internet,cách này ít xài hơn,
        Hugo
        • #34
          Xin được tóm tắt các thảo luận về FTTH trong thread này. Mời các bạn tiếp tục thảo luận.
          Hỏi:
          Hiện tại cơ quan tôi đang sử dụng 2 đường ADSL của VDC và Viettel. Tuy nhiên, chất lượng dịch vụ của 2 nhà cung cấp này mà chúng tôi được hưởng rất tệ. Hiện chúng tôi đang cân nhắc chuyển sang dùng dịch vụ FTTH của FPT. Nhờ các AE đã sử dụng đánh giá giúp. Mình đang có yêu cầu design hệ thống mạng cho một chuỗi cafe internet, anh em nào biết thì cho mình hỏi để sử dụng dịch vụ Internet FTTH của FPT (có thể) thì dùng những thiết bị đầu cuối nào (hỗ trợ PPPoE, hay DHCP) ? có config mẫu về việc cấu hình Router Cisco 878 chạy với đường FTTH của FPT thì cho mình xin với
          Trả lời từ các thành viên:
          Là một trong những nơi có đường FTTH sớm nhất ở SG, không biết những nơi khác thì sao chứ chúng tôi đang khổ sở vì cái chuyện dis connection của nó hầu như mỗi ngày, kể từ khi lắp đặt (Jul 2006) đến giờ đây. Làm việc với kỹ thuật của FPT mấy tháng nay, ngay cả tự thay luôn router Zyxel = Cisco và fiber modem của AMP nhưng đến ngày hôm nay tình hình vẫn chưa cải thiện mà tiền vẫn phải trả hàng tháng 6tr6. Họ nói trong tuần này họ sửa chửa nâng cấp gì tiếp ---> lại đợi và hy/vô vọng :mad: .
          Hy vọng là chỉ có mình chỗ tui bị như vậy. Bạn hỏi tiếp những nơi khác, nếu họ tốt hơn thì cho tui biết để học hỏi kiếm cách khắc phục.
          Tóm tắt kinh nghiệm đã trãi qua:
          Good:
          + very fast (<=1ms) chỉ khi kết nối đến FPT's servers
          Bad:
          + Lost connection almost daily, several times!!!!!
          + very slow when going out to Internet, sometime slower than ADSL.
          Cấu hình mẫu dùng router Cisco:
          Client#sh run
          Current configuration : 1596 bytes
          version 12.2
          hostname Client
          vpdn enable
          vpdn-group 1
          request-dialin
          protocol pppoe
          interface Loopback0
          ip address 10.10.10.10 255.255.255.0//thay cho cổng LAN bên trong
          ip nat inside
          interface Ethernet0/0 <--cổng gắn vào cáp quang của FPT
          half-duplex
          pppoe enable
          interface Dialer1
          mtu 1492
          ip address YOUR_IP_FROM_ISP <---IP xin từ ISP tĩnh/động
          ip nat outside
          encapsulation ppp
          dialer pool 1
          dialer-group 1
          ip nat inside source list 100 interface Dialer1 overload
          ip classless
          ip http server
          access-list 1 permit 10.10.10.0 0.0.0.255
          Trường hợp cấu hình load balancing cho nhiều đường FTTH
          Router 2851
          no aaa new-model
          ip cef
          no ip domain lookup
          ip name-server 203.162.0.181
          ip name-server 222.255.250.190
          vpdn enable
          vpdn-group pppoe
          track 1 interface Dialer0 ip routing
          delay down 1 up 1
          track 2 interface Dialer1 ip routing
          delay down 1 up 1
          track 3 interface Dialer2 ip routing
          delay down 1 up 1
          track 4 interface vlan3 ip routing
          delay down 1 up 1
          interface GigabitEthernet0/0
          description Local Inside
          ip address ........
          ip nbar protocol-discovery
          ip nat inside
          ip route-cache flow
          interface GigabitEthernet0/1
          description FPT2
          ip tcp adjust-mss 1344
          duplex auto
          speed auto
          pppoe enable group pppoe
          interface FastEthernet0/0/0 (Card HWIC SW4Ethernet)
          description FPT1
          switchport access vlan 2
          pppoe-client dial-pool-number 2
          interface FastEthernet0/0/1 (Card HWIC SW 4 Ethernet noi voi kenh LeasedLine)
          description Connect to LL
          switchport access vlan 3
          interface FastEthernet0/0/2
          interface FastEthernet0/0/3
          interface ATM0/1/0
          description ADSL
          no atm ilmi-keepalive
          dsl operating-mode auto
          pvc 0/35
          pppoe-client dial-pool-number 3
          interface Vlan1
          interface Vlan2
          interface Vlan3
          ip address .... .....
          ip nat outside
          interface Dialer0
          description FPT2
          mtu 1492
          no ip redirects
          ip nat outside
          no ip virtual-reassembly
          encapsulation ppp
          dialer pool 1
          ppp pap sent-username ... password ...
          interface Dialer1
          description FPT1
          mtu 1492
          no ip redirects
          ip nat outside
          encapsulation ppp
          dialer pool 2
          interface Dialer2
          description ADSL
          mtu 1942
          ip nat outside
          encapsulation ppp
          dialer pool 3
          ppp chap hostname ....
          ppp chap password ....
          ppp pap sent-username .... password .....
          interface Group-Async0
          physical-layer async
          encapsulation slip
          shutdown
          no group-range
          router ospf 1
          log-adjacency-changes
          network .... ..... area 0
          default-information originate always
          ip route 0.0.0.0 0.0.0.0 Dialer0 track 1
          ip route 0.0.0.0 0.0.0.0 Dialer1 track 2
          ip route 0.0.0.0 0.0.0.0 Dialer2 track 3
          ip route 0.0.0.0 0.0.0.0 Vlan3 track 4
          ip http server
          ip http authentication local
          ip http timeout-policy idle 60 life 86400 requests 10000
          ip nat inside source route-map FPT1 interface Dialer0 overload
          ip nat inside source route-map FPT2 interface Dialer1 overload
          ip nat inside source route-map ADSL interface Dialer2 overload
          ip nat inside source route-map LL interface Vlan6 overload
          route-map FPT1 permit 10
          match interface Dialer0
          set interface Dialer0
          route-map FPT2 permit 20
          match interface Dialer1
          set interface Dialer1
          route-map ADSL permit 30
          match interface Dialer2
          set interface Dialer3
          route-map LL permit 40
          match interface vlan3
          set interface vlan3
          control-plane
          Trường hợp cấu hình dùng interface vlan
          ADSL#sh run
          version 12.4
          no service pad
          hostname ADSL
          boot-start-marker
          boot-end-marker
          no aaa new-model
          resource policy
          ip subnet-zero
          ip cef
          vpdn enable
          username admin
          controller DSL 0
          line-term cpe
          interface BRI0
          encapsulation hdlc
          shutdown
          interface Vlan1
          ip nat inside
          interface Dialer1
          mtu 1492
          ip nat outside
          encapsulation ppp
          dialer pool 1
          dialer-group 1
          ip classless
          no ip http server
          control-plane
          password xxxxx
          login
          no modem enable
          line aux 0
          line vty 0 2
          password xxxxx
          login
          line vty 3 4
          login
          • #35
            FPT miền Nam = good!
            Originally posted by ndminhhai View Post
            Trời!!! Dịch vụ tốt vậy sao. Có AE nào đã dùng line này ở Hà Nội đặc biệt là quận Đống Đa chưa xin cho ít ý kiến với. Các bác FPT trong này không có ai hay sao mà không phản ứng gì.
            Hiện cty tôi đang dùng 2 đường Fiber Bronze của FPT ở HCM và Vũng Tàu. Chất lượng và hỗ trợ khá tốt. Về tổng quan có thể không được Excellent nhưng cũng được Good.
            Một kinh nghiệm khi cần hỗ trợ kỹ thuật của FPT:
            - Từ khi đăng ký lắp đặt Fiber của FPT tôi lưu lại tất cả các số phone mà mình liên hệ với họ, bao gồm từ Saler, nhân viên đi cáp, nhân viên cấu hình modem, trưởng phòng kỹ thuật, và kể cả kế toán,... Khi nào có vấn đề mà gọi hotline của FPT không được thì tôi gọi hết cả đám trên, thế nào cũng được hỗ trợ nhanh nhất. :)) Lúc gọi thì phải gọi bằng số di động của mình, chứ số lạ là họ không nghe máy đâu!
            CÔNG TY CỔ PHẦN THẾ GIỚI NĂNG LƯỢNG MỚI
            www.ennolite.com.vn
            • #36
              ! ADTRAN OS version 17.05.03.00.E
              ! Boot ROM version 17.01.01.00
              ! Platform: NetVanta 3120, part number 1700601G2
              ! Serial number LBADTN0931AD934
              hostname "NetVanta3120"
              enable password *********
              ip subnet-zero
              ip classless
              ip routing
              ip domain-proxy
              no auto-config
              event-history on
              no logging forwarding
              logging forwarding priority-level info
              no logging email
              username "*****" password "******"
              ip firewall
              no ip firewall alg msn
              no ip firewall alg mszone
              no ip firewall alg h323
              no dot11ap access-point-control
              ip crypto
              vlan 1
              name "Default"
              interface eth 0/1
              description FTTH
              no awcp
              no shutdown
              no lldp send-and-receive
              interface switchport 0/1
              spanning-tree edgeport
              no shutdown
              interface switchport 0/2
              no shutdown
              interface switchport 0/3
              no shutdown
              interface switchport 0/4
              no shutdown
              interface vlan 1
              access-policy Private
              no shutdown
              interface ppp 1
              access-policy Public
              no fair-queue
              ppp pap sent-username ***** password ******
              no lldp send 802.3-info mac-phy-config
              no shutdown
              cross-connect 1 eth 0/1 ppp 1
              ip access-list standard wizard-ics
              remark Internet Connection Sharing
              permit any
              ip access-list extended self
              remark Traffic to NetVanta
              permit ip any any log
              ip access-list extended web-acl-9
              permit ip any any
              ip policy-class "NAT Trial"
              ! Implicit discard
              ip policy-class Private
              allow list self self
              nat source list wizard-ics interface ppp 1 overload
              nat source list web-acl-9 interface vlan 1 overload
              ip policy-class Public
              ! Implicit discard
              no ip tftp server
              2000.01.02 22:20:42 INTERFACE_STATUS.swx 0/4 changed state to upno ip tftp
              r overwrite
              ip http server
              no ip snmp agent
              no ip ftp server
              no ip scp server
              no ip sntp server
              no snmp-server enable traps
              no login
              line telnet 0 4
              login local-userlist
              password password
              no shutdown
              line ssh 0 4
              no shutdown
              Mọi ngừơi chỉ em cấu hình NAT và VPN trên con router này với, router cáp quan của vnpt. không biết NAT bằng cách nào nửa.#:-S
              • #37
                Có ai đang sử dụng Adtran không chỉ tôi với, tôi đang gặp sự cố là từ văn phòng kết nối vpn vào server chỉ đúng 1phút30s là nó ngắt kết nói. dù biểu tượng vpn vẫn còn và ở các địa điểm khác thì không bị tình trạng như vậy.
                • #38
                  Originally posted by nmc79 View Post
                  FPT đang chuẩn bị chuyển sang công nghệ GPON bạn có thể tìm hiểu qua công nghệ này.
                  Mình mới test xong thiết bị công nghệ GPON tại FPT xong.
                  Híc, bản chất dùng G-PON chỉ để tiết kiệm cáp sợi quang thông cái splitter thôi. Xét cho cùng vẫn chỉ là ở lớp vật lý mà thôi.
                  • #39
                    Tôi cũng đang sử dụng đường này & có thêm 6 IP route. Nhờ các bác chỉ giúp mình cấu hình 6 IP route này trên router như thế nào. Cám ơn.
                    • #40
                      Chào mọi người,
                      Cùng quan tâm về FTTH.
                      To smtq: Nếu có thêm 6 IP route. Theo mình hiểu là họ (ISP) bán cho bạn 1 subnet 2 bit (8 IPs) trong đó 1 IP là subnet, 1 IPs là broadcast, nên bạn còn lại 6 IP để xài.
                      Cách cấu hình mà mình biết như sau:
                      Ngoài các cấu hình như a ĐQ Minh và mọi người hướng dẫn, bạn sẽ add thêm 1 dải IP vào cùng port FE hay VLan1 , port này là port cắm vào LAN của bạn.
                      Ví dụ: dải IP được cấp là 116.6.16.0/29
                      bạn sẽ cấu hình 116.6.16.1/29 làm gateway.
                      Cấu hình cụ thể:
                      TH1: Vlan1
                      interface vlan 1
                      ip address 117.6.16.1 255.255.255.248 secondary ---> là cái này
                      no shutdown
                      TH1:
                      interface FastEthernet 0/1
                      description Connect to LAN
                      no shutdown
                      Vì là dải IP dùng để route nên ko cần đặt access-list cũng như nat.
                      Đôi lời góp ý!L-)
                      • #41
                        Dịch vụ FTTH của Viettel.
                        Mình ko thấy mọi người nhắc đến dịch vụ FTTH của Viettel. Tốc độ cao hơn FPT, ổn định hơn và mức giá cước thì nhẹ hơn FPT nhiều.
                        http://www.vietteltelecom.vn/interne.../2009/06/4262/
                        • #42
                          Originally posted by LamPhuongHoang View Post
                          Các thiết bị đầu cuối bao gồm:
                          FTTH Gateway
                          Converter
                          Module quang
                          http://www.fpt.vn/ffiber.aspx
                          cái này bây giờ được tích hợp chung 1 thiết bị, họ sử dụng con OCOM 6652, gọi là modem quang (tư vấn FPT..hihi) cái này có wifi luôn, chức năng thì đa dạng có cả chia VLAN, NAT, Route. Nhưng dùng thử thì thấy chưa có good lắm. Tuy nhiên đường truyền thì ổn định.
                          • #43
                            Mình ở Tân Bình FPT xài hay rớt mạng , Viettel thì chậm nhưng ít bị rớt mạng .Bây giờ mình đang xài SCTV thấy mạng ổn định.
                            • #44
                              Bạn nào đã nghe nói dịch vụ FTTx của CMCTI chưa. Đây là nhà cung cấp dịch vụ viễn thông đầu tiên triển khai công nghệ GPON tại Việt Nam. Hiện tại theo mình biết bên đó đang cho dùng thử FTTH trong vòng 1 tháng. Băng thông ra nước ngoài khoảng 2MB down 1MB up đó. Cần biết thêm thông tin vào cmcti.vn
                              • #45
                                Hỏi:
                                Good:
                                Bad:
                                Client#sh run
                                version 12.2
                                hostname Client
                                vpdn enable
                                vpdn-group 1
                                request-dialin
                                protocol pppoe
                                interface Loopback0
                                ip nat inside
                                half-duplex
                                pppoe enable
                                interface Dialer1
                                mtu 1492
                                ip nat outside
                                encapsulation ppp
                                dialer pool 1
                                dialer-group 1
                                ip classless
                                ip http server
                                Router 2851
                                no aaa new-model
                                ip cef
                                no ip domain lookup
                                vpdn enable
                                vpdn-group pppoe
                                delay down 1 up 1
                                delay down 1 up 1
                                delay down 1 up 1
                                delay down 1 up 1
                                ip address ........
                                ip nat inside
                                ip route-cache flow
                                description FPT2
                                duplex auto
                                speed auto
                                description FPT1
                                interface ATM0/1/0
                                description ADSL
                                pvc 0/35
                                interface Vlan1
                                interface Vlan2
                                interface Vlan3
                                ip nat outside
                                interface Dialer0
                                description FPT2
                                mtu 1492
                                no ip redirects
                                ip nat outside
                                encapsulation ppp
                                dialer pool 1
                                interface Dialer1
                                description FPT1
                                mtu 1492
                                no ip redirects
                                ip nat outside
                                encapsulation ppp
                                dialer pool 2
                                interface Dialer2
                                description ADSL
                                mtu 1942
                                ip nat outside
                                encapsulation ppp
                                dialer pool 3
                                encapsulation slip
                                shutdown
                                no group-range
                                router ospf 1
                                ip http server
                                set interface vlan3
                                control-plane
                                ADSL#sh run
                                version 12.4
                                no service pad
                                hostname ADSL
                                boot-start-marker
                                boot-end-marker
                                no aaa new-model
                                resource policy
                                ip subnet-zero
                                ip cef
                                vpdn enable
                                username admin
                                controller DSL 0
                                line-term cpe
                                interface BRI0
                                encapsulation hdlc
                                shutdown
                                interface Vlan1
                                ip nat inside
                                interface Dialer1
                                mtu 1492
                                ip nat outside
                                encapsulation ppp
                                dialer pool 1
                                dialer-group 1
                                ip classless
                                no ip http server
                                control-plane
                                password xxxxx
                                login
                                no modem enable
                                line aux 0
                                line vty 0 2
                                password xxxxx
                                login
                                line vty 3 4
                                login
                                Bác Minh cho em xin luôn cái draft để cấu hình Primary/Backup trên 2 đường FTTH và ADSL được không ạ. Em có 2 đường Internet (1 ngon, 1 lởm) Em muốn cấu hình trên Router (2800) để traffic chạy qua đường FTTH. Còn đường ADSL chỉ là backup. Giúp em với
