Cáp quang (fiber optic)
This is a sticky topic.
  • #46
    Oh may that!
    Minh cung dang rat can day Admin. Hien cong viec cua minh cung dang can tai lieu ve cap quang.
    • #47
      • #48
        các bạn có thể download quyển sách trên trong file đính kèm.
        Chúc mọi người vui vẻ
        • #49
          Đính kèm là tài liệu đào tạo cáp quang của hãng Krone. Mời các bạn download file .pdf.
          Nội dung file:
          1 History........................................... .................................................. .................................................. ........3
          1.1 Bell's Photo- phone .................................................. .................................................. .......3
          1.2 Fibre-optic link.............................................. .................................................. .............................4
          1.2 Components in a Fibre-optic transmission system .................................................. ................4
          1.3 General Description .................................................. .................................................. ...................5
          1.3 Applications map showing bitrate/ distance .................................................. ........................5
          1.4 Structured Cabling as per ISO............................................... .............................................7
          2. Fibre Cables .................................................. .................................................. ..........................................8
          2.1 Fibre-optic Cables............................................ .................................................. ...........................8
          2.1 Fibre-optic Cable Construction .................................................. ..........................................9
          2.2 Indentification of fibres .................................................. .................................................. ..............10
          2.3 Fibre Types .................................................. .................................................. .............................11
          2.2 Fibre Types............................................. .................................................. .......................11
          3. Optical Parameters .................................................. .................................................. .................................12
          3.1 Electro-magnetic spectrum.......................................... .................................................. .................13
          3.1 Electro-magnetic Spectrum .................................................. ..............................................13
          3.2 Optical Transmission - Principles........................................ .................................................. ............14
          3.3 Fibre Cable Types............................................. .................................................. ...........................15
          3.3.1 Multi-mode Step Index (SI) .................................................. .................................................. .....15
          3.3.2 Multi-mode Graded Index (AS) (GI) .................................................. ............................................16
          4. Joining Cables............................................ .................................................. .............................................19
          4.1 Splices and Connectors........................................ .................................................. ........................19
          4.1 Splices and Connectors in an Installation...................................... ........................................19
          4.2 Installation errors............................................ .................................................. ................20
          4.3 Positioning the Fibre............................................. .................................................. ...........21
          4.2 Thermal or Fusion Splicing .................................................. .................................................. .........22
          4.4 Thermal Splicing.......................................... .................................................. ...................22
          4.3 Splice Machines .................................................. .................................................. ........................23
          4.4 Splices, Couplers and Connectors........................................ .................................................. ..........24
          4.5 Coupling Fibres............................................ .................................................. ...................24
          4.6 Industry Standard Connectors........................................ .................................................. ..25
          4.5 Branching and Mixing Devices .................................................. .................................................. ....26
          4.7 Branches .................................................. .................................................. .....................26
          4.8 Mixers .................................................. .................................................. .........................27
          4.6 Wavelength Demultiplexers .................................................. .................................................. ........28
          4.9 Multiplexers/Demultiplexers.................................... .................................................. ..........28
          4.10 Channel Multiplexer/Demutiplexer .................................................. ...................................29
          5. Optical Transmitters and receivers......................................... .................................................. ......................30
          5.1 Optical Transmitters and Receivers......................................... .............................................30
          5.1 Optical Transmitters...................................... .................................................. ..............................30
          5.2 Optical Transmitters .................................................. .................................................. ......30
          Coupling the Optical Transmitter to the Fibre .................................................. .......................................31
          5.3 Coupling LED and LD .................................................. .................................................. ....31
          5.2 Optical Receivers......................................... .................................................. ...............................32
          5.4 Typical Wavelength Ranges............................................ .................................................. ..32
          • #50
            Chào các bạn,
            Mạn phép cho tôi được góp ý về cáp quang SM và MM.
            Về thông số vật lý:
            Đường kính lõi sợi ( phần truyền tin): Core.
            SM: 9/125;
            MM: 50/125 và 62.5/125.
            Đường kính vỏ phản xạ: Cladding thì cả SM và MM đều như nhau là 125um.
            Về Coating thì tùy thuộc vào dặc tính cần bảo vệ mà người ta làm lớp này, tuy nhiên thông thường đối với cáp out door thì nó là 250, với cáp in door thì nó là 900, điều này không phụ thuộc vào nó la cáp SM hay MM.
            Về sử dụng thì tùy thuộc vào công suất phát, độ nhạy thu, khoảng cách truyền dẫn, tốc đọ yêu cầu và giá thành mà người ta quyết định dùng SM hoặc MM.
            Nếu cần thì bạn có thể liên lạc với tôi theo số máy 0913514408, tôi sẵn sàng chia sẻ với bạn 10 năm kinh nghiệm nghiên cứu và làm việc về cáp quang trong nước và nước ngoài của tôi
            • #51
              Chào các bạn,
              Theo tôi thì bác 1''hpSky đã giải thích khá thấu đáo về mặt lý thuyết về Mode của cáp quang.
              Còn đưa 2 sợi quang trần thì không thể phân biệt được SM và MM đâu. Để phân biệt được thì bạn phải có Microscope hoặc Fusion Splicer.
              • #52
                Hello các bác,
                Thấy các bác bàn về Fiber Optic thấy xôm quá cũng muốn góp vui chút ít.
                Tôi thì cũng mới làm việc với hệ thống thông tin quang được 10 năm rồi nên cũng có chút ít kinh nghiệm về cái món này.
                Bác nào cần thông tin gì về món này thì alo cho tôi nhé, số ĐT 0913514408 (24/7/365: Làm việc 24 giờ 1 ngày, 7 ngày một tuần và 365 ngày 1 năm nên các bác đùng ngại khi ĐT khuya hay ngày nghỉ.)
                • #53
                  Chao cac ban,
                  Doi voi he thong cap soi quang, de co duoc he thong quang chac chac, giam chi phi sua chua.... chung ta nen su dung kieu han pigtail vi do on dinh cao, suy hao thap (<0.1dB).
                  con khi su dung kieu bam dau connector thi chi mang tinh chat tam thoi, khong phai la mot giai phap hoan hao, kho kiem soat duoc he thong, nhat la he thong truc, vi chung ta se mat rat nhieu thoi gian de tim ra loi.
                  ve gia thanh cua he thong dau noi minh se dua ra so sanh nhu sau de cac ban tham khao nhe:
                  Ca 2 giai phap deu co cac phu kien tuong tu nhau nhu:
                  Hop chua phu kien (patchpanel/ ODF),
                  Adaptor
                  Patchcord
                  khac biet:
                  doi voi giai phap han soi quang pigtail (gia su han 6 soi quang)
                  pigtail MM: 7 USD/ 1 pcs
                  tray :14 USD/ tray 12 or 24 soi
                  cong han : 4 USD/ moi han
                  tong cong cho 6 soi: 42 + 14 + 24 = 80 USD
                  doi voi giai phap bam dau connector:
                  Connector :4 USD/ 1 pcs
                  cong bam dau : 4 USD/ dau
                  tong cong cho 6 dau: 24+24 = 48 USD
                  Nhu vay chenh lech cho moi diem ket cuoi cap quang 6 core la 80 - 48 = 32 USD.
                  cheer.
                  nguyenhungvuong.
                  • #54
                    Bạn nguyenhungvuong cho mình hỏi phải hàn tối thiểu bao nhiêu mối mới có giá hàn 4$/ mối vậy bạn, nếu có thể vui lòng cho mình xin địa chỉ và số điện thoại của cty hàn cáp quang này. Cảm ơn bạn nhiều
                    Lê Trọng Thịnh
                    www.modemquang.com
                    Tel: 08.39940163 - Hotline: 0917 553 715
                    Cung cấp: Bộ chuyển đổi quang điện giá tốt nhất, sản xuất và phân phối cáp quang, dây nhảy quang và phụ kiện quang
                    • #55
                      Hi ban Thinh,
                      vi forum nay chu yeu ban ve cong nghe va ky thuat, khong di sau ve mang kinh doanh, nen minh hen ban gap nhau vao mot dip nao do de trao doi se thuan tien hon, hoac vui long email cho minh nhe : hungvuongpq@yahoo.com
                      chuc ban suc khoe va thanh cong.
                      nguyenhungvuong.
                      • #56
                        To HauNguyen !
                        The original message was received at Thu, 31 Jan 2008 09:58:09 +0700 from ci161-141.netnam.vn [202.151.161.141] (may be forged)
                        ----- The following addresses had permanent fatal errors ----- <haauj@yahoo.com>
                        (reason: 554 delivery error: dd This user doesn't have a yahoo.com account (haauj@yahoo.com) [0] - mta182.mail.re2.yahoo.com)
                        ----- Transcript of session follows ----- ... while talking to d.mx.mail.yahoo.com.:
                        >>> DATA
                        <<< 451 Message temporarily deferred - [250] ... while talking to g.mx.mail.yahoo.com.:
                        >>> DATA
                        <<< 554 delivery error: dd This user doesn't have a yahoo.com account (haauj@yahoo.com) [0] - mta182.mail.re2.yahoo.com
                        554 5.0.0 Service unavailable
                        • #57
                          anh opticnets!
                          Khi chiều em có liên hệ điện thoại nhờ anh tư vấn Về mạng cáp quang đó anh!
                          Khi nào rãnh rỗi anh có thể nói thêm về mạng cáp quang cho em với được không(về cáp,thiết bị đầu cuối...).
                          Em mới làm mạng cáp quang nên còn rất bỡ ngỡ.có chi mong anh chỉ giáo cho em với!
                          Em cảm ơn anh trước.
                          • #58
                            Nhờ các bác tư vấn về kết nối hệ thống quang
                            em đang cần kết nối 2 hệ thống
                            3 con switch CE 500G kết nối Ring bằng cổng quang, cáp quang, ODF, dây nhẩy
                            3 switch 2950 kết nối với nhau thành Ring cổng quang, cáp quang, ODF, dây nhẩy
                            em không nắm rõ về kỹ thuật nhưng rõ ràng hệ thống dây nhẩy và module quang của 2 hệ thống này khác nhau
                            muốn kết nối thành 1 RING thì cần những thiết bị gì, mời các bác tư vấn giúp
                            • #59
                              Hi CCNA07,
                              Về cáp quang thì tuỳ theo yêu cầu người ta chia ra làm nhiều loại khác nhau:
                              Theo Mode thì có: SM và MM (MM có 2 loại: 62.5 và 50).
                              Theo môi trường lắp đặt thì có OutdoOr và In door.
                              Outdoor lại chia ra thành các loại: F8 và Underground.
                              Về thiết bị đầu cuối thì cũng đơn giản thôi, bạn học CCNA thì quan tâm đến Ethernet, Media Converter, nếu bạn quan tâm đến viễn thông thì quan tâm đến PDH, SDH, thiết bị DWM. Tuy nhiên ranh giới giữa IT và Telecom không rõ ràng đâu, tuỳ theo yêu cầu thực tế mà kết hợp.
                              Mình chỉ phân tách tạm thời các khái niệm để bạn dễ dàng nắm được basic thôi.
                              Nói chung hệ thống thông tin quang không có gì phức tạp đâu, đơn giản nó cũng chỉ là Layer 1 thôi, đừng phức tạp hoá nó làm gì.
                              Có gì thì bạn mail cho mình rồi cùng trao đổi thêm.
                              Thân
                              • #60
                                Cảm ơn anh Opticnets!
                                anh cho em xin mail của anh với
                                Đây là Mail của em:cdtthuan@yahoo.com
                                À anh nè,nếu khoảng cách 1km thì dùng switch 2 đầu có ổn không,hay phải dùng router.
                                Nếu dùng router thì nên chọn loại nào là phù hợp.(người ta yêu cầu hệ thống quang này phải có độ ổn định,không được chập chờn)
                                Còn nếu như dùng Cisco thì nên dùng loại nào?
                                Em chào anh!:)
