GNS3 bị lỗi khi mô phỏng lab MPLS VPN
Xem link: http://www.sadikhov.com/forum/index....-to-port-7200/
Bạn thử làm theo trong đó, nhớ tắt firewall của PC xem có ańh sáng cuối đường hầm hông nhe.
Trích:
"1. Go to the IOS images and hypervisor
2. Go to the external hypervisor tab
3. Add and external hypervisor with the following settings:
- host :127.0.0.1
- port: 7200
- base udp: 10000
- base console 2000
4. Go to the images tab
5. select the image that you want to use and uncheck the @use the hyoervision manager
6. Select the 127.0.0.1:7200 hypervisor"Last edited by hell13; 31-05-2012, 09:43 PM.
