Khởi động định tuyến OSPFv3 cho IPv6 trên các interfaces
Router(config)#interface type number
Router(config-if)#ipv6 eigrp as-number
Router(config-if)#ipv6 router eigrp as-number
Router(config-router)#eigrp router-id ip-address
Ø Điều chỉnh Link Bandwidth được sử dụng trên EIGRP (mặc định Link Bandwidth là 50%)
Router(config-if)#ipv6 bandwidth-percent eigrp as-number percent
Ø Cấu hình chứng thực EIGRP
Router(config-if)#ipv6 authentication mode eigrp as-number md5
Router(config-if)#ipv6 authentication key-chain eigrp as-numberkey-chain
Router(config)#key chain name-of-chain
Router(config)#key key-id
Router(config)#key-string text
Router(config)#accept-lifetime start-time {infinite | end-time| duration seconds}
Router(config)#send-lifetime start-time {infinite | end-time| duration seconds}
Lab EIGRP ipv6
R2
R2(config)#int fa 0/0
R2(config-if)#ipv6 address 2001:1:1:410::2/60
R2(config-if)#ipv6 address FE80::410:2 link-local
R2(config-if)#no sh
R2(config)#ipv6 unicast-routing
R2(config-rtr)#int fa 0/0
R2(config-if)#ipv6 enable
R2(config-if)#ipv6 eigrp 10
R2(config-if)#exit
R2(config)#ipv6 router eigrp 10
R2(config-rtr)#router-id 2.2.2.2
R2(config-rtr)#no sh
R3
R3(config-if)#int fa 0/0
R3(config-if)#ipv6 address 2001:1:1:410::3/60
R3(config-if)#ipv6 address FE80::410:3 link-local
R3(config-if)#no sh
R3(config)#ipv6 unicast-routing
R3(config-rtr)#int fa 0/0
R3(config-if)#ipv6 enable
R3(config-if)#ipv6 eigrp 10
R3(config-if)#exit
R3(config)#ipv6 router eigrp 10
R3(config-rtr)#router-id 3.3.3.3
R3(config-rtr)#no sh
R4
R4(config-if)#int fa 0/0
R4(config-if)#ipv6 address 2001:1:1:410::4/60
R4(config-if)#ipv6 address FE80::410:4 link-local
R4(config-if)#no sh
R4(config)#ipv6 unicast-routing
R4(config-rtr)#int fa 0/0
R4(config-if)#ipv6 enable
R4(config-if)#ipv6 eigrp 10
R4(config-if)#exit
R4(config)#ipv6 router eigrp 10
R4(config-rtr)#router-id 4.4.4.4
R4(config-rtr)#no sh
Lab EIGRP ipv6
R2
R2(config-if)#no sh
R2(config-if)#exit
R3
R3(config-if)#no sh
R3(config-if)#exit
R4
R4(config-if)#no sh
R4(config-if)#exit
