Mình cấu hình Static NAT như sau, sau khi cấu hình xong thì không ping được giữa 2 side V4 và V6, bạn nào chỉ giúp với ?
Router6#sh run
Current configuration : 574 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router6
ipv6 unicast-routing
interface FastEthernet0/0
duplex auto
speed auto
ipv6 address 2001:A:B:C::1/64
ipv6 mtu 1500
ipv6 enable
ipv6 nat
interface FastEthernet0/1
duplex auto
speed auto
shutdown
interface Vlan1
shutdown
ip classless
ipv6 route 2001:A:B:C::/64 2001:A:B:C::3
login
Router_NAT#sh run
Current configuration : 627 bytes
version 12.4
hostname Router_NAT
duplex auto
speed auto
ipv6 address 2001:A:B:C::3/64
ipv6 nat
ip address 192.168.40.199 255.255.255.0
duplex auto
speed auto
interface Vlan1
shutdown
ip classless
ipv6 nat v6v4 source 2001:A:B:C::1 192.168.40.1
ipv6 nat v4v6 source 192.168.40.200 2001::C0A8:28C8
ipv6 nat prefix 2001::/96
login
Router4#sh run
Current configuration : 467 bytes
version 12.4
hostname Router4
ip address 192.168.40.200 255.255.255.0
duplex auto
speed auto
duplex auto
speed auto
shutdown
interface Vlan1
shutdown
ip classless
login
Router6#ping 2001::c0a8:28c8
Sending 5, 100-byte ICMP Echos to 2001::c0a8:28c8, timeout is 2 seconds:
Bạn nào chỉ giúp mình với! Thanks all!
Router6#sh run
version 12.4
hostname Router6
duplex auto
speed auto
ipv6 mtu 1500
ipv6 enable
ipv6 nat
duplex auto
speed auto
shutdown
interface Vlan1
shutdown
ip classless
login
Router_NAT#sh run
version 12.4
hostname Router_NAT
duplex auto
speed auto
ipv6 nat
duplex auto
speed auto
interface Vlan1
shutdown
ip classless
login
Router4#sh run
version 12.4
hostname Router4
duplex auto
speed auto
duplex auto
speed auto
shutdown
interface Vlan1
shutdown
ip classless
login
