Nhờ ace giúp đỡ, em đang cấu hình con ASA 5525-x chạy ASA 8.6, muốn các host trong dmz và inside giao tiếp qua lại với nhau, ví dụ như: RDP mà hiện giờ vẫn chưa thực hiện được. ACE nào check giúp em phần config được không ạ?
: Saved
ASA Version 8.6(1)2
hostname ASA
enable password FJBSRjaNrck2SEKT encrypted
names
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address IP_public 255.255.255.192
interface GigabitEthernet0/1
shutdown
no nameif
no security-level
interface GigabitEthernet0/2
nameif dmz
security-level 50
ip address 10.9.8.1 255.255.255.24
interface GigabitEthernet0/3
nameif inside
security-level 100
ip address 10.9.9.1 255.255.255.240
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
interface GigabitEthernet0/6
shutdown
no nameif
no security-level
interface GigabitEthernet0/7
shutdown
no nameif
no security-level
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
object network IP_LOCAL_WEBSERVER
host 10.9.8.2
object network IP_GLOBAL_WEBSERVER
host ip_web_global
object network IP_subnet_inside
subnet 10.9.9.0 255.255.255.240
object network IP_subnet_dmz
subnet 10.9.8.0 255.255.255.240
access-list outside-in extended permit tcp any object IP_LOCAL_WEBSERVER eq www
access-list dmz-in extended permit tcp object IP_LOCAL_WEBSERVER object IP_subne
t_inside eq www
t_inside eq 1433
access-list inside-in extended permit tcp object IP_subnet_inside object IP_LOCA
L_WEBSERVER eq 3839
access-list dmz-i extended permit tcp host 10.9.8.2 host 10.9.9.4 eq telnet
access-list dmz-i extended permit icmp host 10.9.8.2 host 10.9.9.4 echo
access-list dmz-i extended permit icmp host 10.9.8.2 host 10.9.9.4 echo-reply
pager lines 24
logging asdm informational
mtu management 1500
mtu outside 1500
mtu dmz 1500
mtu inside 1500
no failover
no asdm history enable
arp timeout 14400
nat (inside,dmz) source static IP_subnet_inside IP_subnet_inside destination sta
tic IP_subnet_dmz IP_subnet_dmz
nat (dmz,outside) static IP_GLOBAL_WEBSERVER service tcp www www
nat (dmz,outside) dynamic interface
access-group outside-in in interface outside
access-group dmz-in in interface dmz
access-group inside-in in interface inside
route outside 0.0.0.0 0.0.0.0 ip_gateway 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maxim
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
Cryptochecksum:464185c7e3d68ec48afb2f180b2a11c8
: end
: Saved
ASA Version 8.6(1)2
hostname ASA
names
nameif outside
security-level 0
shutdown
no nameif
no security-level
nameif dmz
security-level 50
nameif inside
security-level 100
shutdown
no nameif
no security-level
shutdown
no nameif
no security-level
shutdown
no nameif
no security-level
shutdown
no nameif
no security-level
nameif management
security-level 100
management-only
ftp mode passive
host 10.9.8.2
host ip_web_global
t_inside eq www
t_inside eq 1433
L_WEBSERVER eq 3839
pager lines 24
mtu management 1500
mtu outside 1500
mtu dmz 1500
mtu inside 1500
no failover
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
: end
