Lab về DMVPN
  • Lab về DMVPN
    Lab về DMVPN
    Tác giả: Vi Thị Mưu
    Các bước thực hiện cho cấu hình:
    Bước 1 : Cấu hình cho các Router thấy nhau
    Spoke 1:
    Router#config terminal
    Router(config)# hostname Spoke1
    Spoke1(config)# interface f0/0
    Spoke1(config-if)# ip address 172.30.1.1 255.255.255.0
    Spoke1(config-if)# no shutdown
    Spoke1(config-if)# exit
    Spoke1(config)# interface f0/1
    Spoke1(config-if)# ip address 192.168.1.1 255.255.255.0
    Spoke1(config)# ip route 0.0.0.0 0.0.0.0 172.30.1.2
    Spoke 2:
    Router# config terminal
    Router(config)# hostname Spoke2
    Spoke2(config)# interface f0/0
    Spoke2(config-if)# ip address 172.30.3.1 255.255.255.0
    Spoke2(config-if)# no shutdown
    Spoke2(config-if)# exit
    Spoke2(config)# interface f0/1
    Spoke2(config-if)# ip address 192.168.2.1 255.255.255.0
    Spoke2(config)# ip route 0.0.0.0 0.0.0.0 172.30.3.2
    HUB
    Router(config)# hostname Hub
    Hub(config)# interface f0/0
    Hub(config-if)# ip address 172.30.2.1 255.255.255.0
    Hub(config-if)# no shutdown
    Hub(config-if)# exit
    Hub(config)# interface loop back 0
    Hub(config-if)# ip address 192.168.0.1 255.255.255.0
    Hub(config)# ip route 0.0.0.0 0.0.0.0 172.30.2.2
    Thực hiện cấu hình đối với Spoke1
    Bước 2: cấu hình phase 1 cho Spoke1
    Spoke1(config)# crypto isakmp enable
    Spoke1(config)# crypto isakmp policy 1
    Spoke1(config-isakmp)# authentication pre-share
    Spoke1(config-isakmp)# hash md5
    Spoke1(config-isakmp)# exit
    Spoke1(config)# crypto isakmp key cisco47 address 0.0.0.0 0.0.0.0
    Bước 3: cấu hình dmvpn cho Spoke1
    Spoke1(config)# interface tunnel 0
    Spoke1(config-if)# ip address 10.0.0.2 255.255.255.0
    Spoke1(config-if)# ip mtu 1400
    Spoke1(config-if)# ip nhrp authentication cisco47
    Spoke1(config-if)# ip nhrp map 10.0.0.1 172.30.2.1
    Spoke1(config-if)# ip nhrp hold-time 600
    Spoke1(config-if)# ip nhs 10.0.0.1
    Spoke1(config-if)# no ip next-hop-self eigrp 1
    Spoke1(config-if)# ip map multicast 172.30.2.1
    Spoke1(config-if)# ip nhrp network-id 100
    Spoke1(config-if)# tunnel source f0/0
    Spoke1(config-if)# tunnel key 1000
    Spoke1(config-if)# tunnel mode gre multipoint
    Spoke1(config-if)# tunnel protection ipsec profile dmvpn
    Bước 4: cấu hình phase 2 cho Spoke1
    Spoke1(config)# crypto ipsec transform-set myset esp-des esp-md5-hmac
    Spoke1(config)# crypto map dmvpn local-address f0/0
    Spoke1(config)# crypto map dmvpn 10 ipsec-isakmp
    Spoke1(config-crypto-map)# set peer 172.30.2.1
    Spoke1(config-crypto-map)# set security-association level per-host
    Spoke1(config-crypto-map)# set transform-set myset
    Spoke1(config-crypto-map)# match address 101
    Spoke1(config-crypto-map)# exit
    Spoke1(config)# access-list 101 permit gre 172.30.1.0 0.0.0.255 host 172.30.2.1
    Bước 5: định tuyến dùng giao thức EIGRP
    Spoke1(config)# router eigrp 1
    Spoke1(config-router)# network 10.0.0.0 0.0.0.255
    Spoke1(config-router)# network 192.168.1.0 0.0.0.255
    Spoke1(config-router)# no auto-summary
    Thực hiện cấu hình đối với Spoke2
    Bước 2: cấu hình phase 1 cho Spoke2
    Spoke2(config)# crypto isakmp enable
    Spoke2(config)# crypto isakmp policy 1
    Spoke2(config-isakmp)# authentication pre-share
    Spoke2(config-isakmp)# hash md5
    Spoke2(config-isakmp)# exit
    Spoke2(config)# crypto isakmp key cisco47 address 0.0.0.0 0.0.0.0
    Bước 3: cấu hình dmvpn cho Spoke2
    Spoke2(config)# interface tunnel 0
    Spoke2(config-if)# ip address 10.0.0.3 255.255.255.0
    Spoke2(config-if)# ip mtu 1400
    Spoke2(config-if)# ip nhrp authentication cisco47
    Spoke2(config-if)# ip nhrp map 10.0.0.1 172.30.2.1
    Spoke2(config-if)# ip nhrp hold-time 600
    Spoke2(config-if)# ip nhs 10.0.0.1
    Spoke2(config-if)# no ip next-hop-self eigrp 1
    Spoke2(config-if)# ip map multicast 172.30.2.1
    Spoke2(config-if)# ip nhrp network-id 100
    Spoke2(config-if)# tunnel source f0/0
    Spoke2(config-if)# tunnel key 1000
    Spoke2(config-if)# tunnel mode gre multipoint
    Spoke2(config-if)# tunnel protection ipsec profile dmvpn
    Bước 4: cấu hình phase 2 cho spoke2
    Spoke2(config)# crypto ipsec transform-set myset esp-des esp-md5-hmac
    Spoke2(config)# crypto map dmvpn local-address f0/0
    Spoke2(config)# crypto map dmvpn 10 ipsec-isakmp
    Spoke2(config-crypto-map)# set peer 172.30.2.1
    Spoke2(config-crypto-map)# set security-association level per-host
    Spoke2(config-crypto-map)# set transform-set myset
    Spoke2(config-crypto-map)# match address 101
    Spoke2(config-crypto-map)# exit
    Spoke2(config)# access-list 101 permit gre 172.30.3.0 0.0.0.255 host 172.30.2.1
    Spoke2(config)# router eigrp 1
    Spoke2(config-router)# network 10.0.0.0 0.0.0.255
    Spoke2(config-router)# network 192.168.2.0 0.0.0.255
    Spoke2(config-router)# no auto-summary
    Thực hiện cấu hình cho HUB
    Hub(config)# crypto isakmp enable
    Hub(config)# crypto isakmp policy 1
    Hub(config-isakmp)# authentication pre-share
    Hub(config-isakmp)# hash md5
    Hub(config-isakmp)# exit
    Hub(config)# crypto isakmp key cisco47 address 0.0.0.0 0.0.0.0
    Hub(config)# crypto ipsec transform-set myset esp-des esp-md5-hmac
    # tạo IPSec profile
    Hub(config)# crypto ipsec profile dmvpn
    Hub(config-profile)# set transform-set myset
    Hub(config)# interface tunnel 0
    # cấu hình dmvpn
    Hub(config-if)# ip address 10.0.0.1 255.255.255.0
    Hub(config-if)# ip mtu 1400
    Hub(config-if)# ip nhrp authentication cisco47
    Hub(config-if)# ip nhrp multicast dynamic
    Hub(config-if)# ip nhrp hold-time 600
    Hub(config-if)# tunnel source f0/0
    Hub(config-if)# tunnel mode gre multipoint
    Hub(config-if)# tunnel key 1000
    Hub(config-if)# tunnel protection ipsec profile dmvpn
    Hub(config)# interface f0/1
    # định tuyến dùng giao thức EIGRP
    Hub(config)# router eigrp 1
    Hub(config-router)# network 10.0.0.0 0.0.0.255
    Hub(config-router)# network 192.168.0.0 0.0.0.255
    Hub(config-router)# no auto-summary
    Kiểm tra kết quả
    Thực hiện ping từ PC1 đến PC2
    Thực hiện Ping từ PC1 đến 192.168.0.1
    Đặng Hoàng Khánh
    Bài viết hay, thank
      Hi Khanh ,
      co Labs DMVPN chay cho OSPF ko,
      Hugo
