LAB-MPLS VPN Multi_VRF
  • LAB-MPLS VPN Multi_VRF
    Trong mô hình MPLS VPN,khách hàng ở nhiều chi nhánh khác nhau kết nối vào mạng core MPLS có thể dùng dynamic routing protocal giữa các chi nhánh
    Qui hoạch IP:
    (1) 192.168.1.0/24
    (2) 192.168.2.0/24
    (3) 192.168.3.0/24
    (4) 192.168.4.0/24
    (5) 192.168.5.0/24
    (6) 192.168.6.0/24
    (7) Lo0: 10.10.10.10/24
    (8) Lo0: 20.20.20.20/24
    (9) Lo0: 1.1.1.1/24
    (10) Lo0: 3.3.3.3/24
    (11) Lo0: 2.2.2.2/24
    (12) Lo0: 30.30.30.30/24
    (13) Lo0: 40.40.40.40/24
      ROUTER A1:
      hostname A1
      boot-start-marker
      boot-end-marker
      no aaa new-model
      ip subnet-zero
      ip cef
      no ip domain lookup
      ip audit po max-events 100
      interface Loopback0
      ip address 10.10.10.10 255.255.255.0
      interface FastEthernet0/0
      duplex auto
      speed auto
      interface FastEthernet0/1
      shutdown
      duplex auto
      speed auto
      router eigrp 10
      network 10.0.0.0
      network 192.168.1.0
      no auto-summary
      ip classless
      ip http server
      no ip http secure-server
      exec-timeout 0 0
      line aux 0
      privilege level 15
      no login
      line vty 5 15
      privilege level 15
      no login
      End
      ROUTER B1:
      hostname B1
      boot-start-marker
      boot-end-marker
      no aaa new-model
      ip subnet-zero
      ip cef
      no ip domain lookup
      interface Loopback0
      ip address 20.20.20.20 255.255.255.0
      shutdown
      duplex auto
      speed auto
      interface Serial0/0
      clock rate 2000000
      ip address 100.100.100.100 255.255.255.0
      duplex auto
      speed auto
      no keepalive
      interface Serial0/1
      shutdown
      clock rate 2000000
      router eigrp 20
      network 20.0.0.0
      network 100.0.0.0
      network 192.168.2.0
      no auto-summary
      ip classless
      ip http server
      exec-timeout 0 0
      line aux 0
      privilege level 15
      no login
      line vty 5 15
      privilege level 15
      no login
      End
        ROUTER PE01:
        hostname PE01
        boot-start-marker
        boot-end-marker
        no aaa new-model
        ip subnet-zero
        ip cef
        no ip domain lookup
        ip vrf A1
        rd 1:100
        route-target export 1:100
        route-target import 1:100
        ip vrf B1
        rd 1:200
        route-target export 1:200
        route-target import 1:200
        interface Loopback0
        ip address 1.1.1.1 255.255.255.0
        ip vrf forwarding A1
        duplex auto
        speed auto
        interface Serial0/0
        ip vrf forwarding B1
        clock rate 64000
        duplex auto
        speed auto
        mpls label protocol ldp
        tag-switching ip
        interface Serial0/1
        shutdown
        clock rate 2000000
        router eigrp 100
        auto-summary
        address-family ipv4 vrf B1
        network 192.168.2.0
        no auto-summary
        autonomous-system 20
        exit-address-family
        address-family ipv4 vrf A1
        network 192.168.1.0
        no auto-summary
        autonomous-system 10
        exit-address-family
        router rip
        version 2
        network 1.0.0.0
        network 192.168.3.0
        no auto-summary
        router bgp 1
        no synchronization
        bgp log-neighbor-changes
        neighbor 2.2.2.2 remote-as 1
        neighbor 2.2.2.2 update-source Loopback0
        no auto-summary
        address-family vpnv4
        neighbor 2.2.2.2 activate
        neighbor 2.2.2.2 send-community extended
        exit-address-family
        redistribute eigrp 20
        no auto-summary
        no synchronization
        exit-address-family
        redistribute eigrp 10
        no auto-summary
        no synchronization
        exit-address-family
        ip classless
        ip http server
        exec-timeout 0 0
        line aux 0
        privilege level 15
        no login
        line vty 5 15
        privilege level 15
        no login
        End
        ROUTER P:
        hostname P
        boot-start-marker
        boot-end-marker
        no aaa new-model
        ip subnet-zero
        ip cef
        no ip domain lookup
        interface Loopback0
        ip address 3.3.3.3 255.255.255.0
        ip address 192.168.3.2 255.255.255.0
        duplex auto
        speed auto
        tag-switching ip
        ip address 192.168.4.1 255.255.255.0
        duplex auto
        speed auto
        tag-switching ip
        router rip
        version 2
        network 3.0.0.0
        network 192.168.3.0
        network 192.168.4.0
        no auto-summary
        ip classless
        ip http server
        exec-timeout 0 0
        line aux 0
        privilege level 15
        no login
        line vty 5 15
        privilege level 15
        no login
        End
        ROUTER PE02:
        hostname PE02
        boot-start-marker
        boot-end-marker
        no aaa new-model
        ip subnet-zero
        ip cef
        no ip domain lookup
        ip vrf A2
        rd 1:100
        ip vrf B2
        rd 1:200
        interface Loopback0
        ip address 2.2.2.2 255.255.255.0
        ip address 192.168.4.2 255.255.255.0
        duplex auto
        speed auto
        tag-switching ip
        interface Serial0/0
        ip vrf forwarding A2
        ip address 192.168.5.1 255.255.255.0
        clock rate 64000
        ip vrf forwarding B2
        ip address 192.168.6.1 255.255.255.0
        duplex auto
        speed auto
        interface Serial0/1
        shutdown
        clock rate 2000000
        router eigrp 100
        auto-summary
        address-family ipv4 vrf B2
        redistribute bgp 1 metric 1000 100 100 100 100
        network 192.168.6.0
        auto-summary
        autonomous-system 40
        exit-address-family
        address-family ipv4 vrf A2
        network 192.168.5.0
        auto-summary
        autonomous-system 30
        exit-address-family
        router rip
        version 2
        network 2.0.0.0
        network 192.168.4.0
        no auto-summary
        router bgp 1
        no synchronization
        neighbor 1.1.1.1 remote-as 1
        neighbor 1.1.1.1 update-source Loopback0
        no auto-summary
        neighbor 1.1.1.1 activate
        neighbor 1.1.1.1 send-community extended
        exit-address-family
        redistribute eigrp 40
        no auto-summary
        no synchronization
        exit-address-family
        redistribute eigrp 30
        no auto-summary
        no synchronization
        exit-address-family
        ip classless
        ip http server
        exec-timeout 0 0
        line aux 0
        privilege level 15
        no login
        line vty 5 15
        privilege level 15
        no login
        End
          ROUTER A2:
          hostname A2
          boot-start-marker
          boot-end-marker
          no aaa new-model
          ip subnet-zero
          ip cef
          no ip domain lookup
          interface Loopback0
          ip address 30.30.30.30 255.255.255.0
          shutdown
          duplex auto
          speed auto
          interface Serial0/0
          ip address 192.168.5.2 255.255.255.0
          clock rate 2000000
          shutdown
          duplex auto
          speed auto
          interface Serial0/1
          shutdown
          clock rate 2000000
          router eigrp 30
          network 30.0.0.0
          network 192.168.5.0
          no auto-summary
          ip classless
          ip http server
          exec-timeout 0 0
          line aux 0
          privilege level 15
          no login
          line vty 5 15
          privilege level 15
          no login
          End
          ROUTER B2:
          hostname B2
          boot-start-marker
          boot-end-marker
          no aaa new-model
          ip subnet-zero
          ip cef
          no ip domain lookup
          interface Loopback0
          ip address 40.40.40.40 255.255.255.0
          ip address 192.168.6.2 255.255.255.0
          duplex auto
          speed auto
          shutdown
          duplex auto
          speed auto
          router eigrp 40
          network 40.0.0.0
          network 192.168.6.0
          no auto-summary
          ip classless
          ip http server
          exec-timeout 0 0
          line aux 0
          privilege level 15
          no login
          line vty 5 15
          privilege level 15
          no login
          End
            Kiểm tra hoạt động:
            • Đối với MPLS Domain :
            i. Kiểm tra bảng định tuyến :
            Trên PE01
            PE01#show ip route
            1.0.0.0/24 is subnetted, 1 subnets
            C 1.1.1.0 is directly connected, Loopback0
            2.0.0.0/24 is subnetted, 1 subnets
            R 2.2.2.0 [120/2] via 192.168.3.2, 00:00:12, FastEthernet0/1
            3.0.0.0/24 is subnetted, 1 subnets
            R 3.3.3.0 [120/1] via 192.168.3.2, 00:00:12, FastEthernet0/1
            R 192.168.4.0/24 [120/1] via 192.168.3.2, 00:00:12, FastEthernet0/1
            C 192.168.3.0/24 is directly connected, FastEthernet0/1
            Trên P
            P#show ip route
            R 1.1.1.0 [120/1] via 192.168.3.1, 00:00:07, FastEthernet0/0
            R 2.2.2.0 [120/1] via 192.168.4.2, 00:00:11, FastEthernet0/1
            C 3.3.3.0 is directly connected, Loopback0
            C 192.168.4.0/24 is directly connected, FastEthernet0/1
            C 192.168.3.0/24 is directly connected, FastEthernet0/0
            Trên PE02
            PE02#show ip route
            R 1.1.1.0 [120/2] via 192.168.4.1, 00:00:27, FastEthernet0/0
            C 2.2.2.0 is directly connected, Loopback0
            R 3.3.3.0 [120/1] via 192.168.4.1, 00:00:27, FastEthernet0/0
            C 192.168.4.0/24 is directly connected, FastEthernet0/0
            R 192.168.3.0/24 [120/1] via 192.168.4.1, 00:00:27, FastEthernet0/0
            Kết luận : Định tuyến nội giữa MPLS Domain đã thông, từ đó cấu hình MPLS
            ii. Kiểm tra LFIP table
            Trên PE01
            PE01#show mpls forwarding-table
            Local Outgoing Prefix Bytes tag Outgoing Next Hop
            tag tag or VC or Tunnel Id switched interface
            16 16 2.2.2.0/24 0 Fa0/1 192.168.3.2
            17 Pop tag 3.3.3.0/24 0 Fa0/1 192.168.3.2
            18 Pop tag 192.168.4.0/24 0 Fa0/1 192.168.3.2
            Trên P
            P#show mpls forwarding-table
            16 Pop tag 2.2.2.0/24 3375 Fa0/1 192.168.4.2
            17 Pop tag 1.1.1.0/24 5007 Fa0/0 192.168.3.1
            Trên PE02
            PE02#show mpls forwarding-table
            16 Pop tag 3.3.3.0/24 0 Fa0/0 192.168.4.1
            17 Pop tag 192.168.3.0/24 0 Fa0/0 192.168.4.1
            18 17 1.1.1.0/24 0 Fa0/0 192.168.4.1
            iii. Cấu hình BGP trên PE01 và PE02
            Trên PE01
            PE01#show ip bgp summary
            BGP router identifier 1.1.1.1, local AS number 1
            BGP table version is 1, main routing table version 1
            Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
            2.2.2.2 4 1 55 54 1 0 0 00:43:36 0
            Trên PE02
            PE02#show ip bgp summary
            BGP router identifier 2.2.2.2, local AS number 1
            1.1.1.1 4 1 55 56 1 0 0 00:44:24 0
            - Kiểm tra vrf routing table của A1,A2,B1,B2 trên PE01 và PE02
            Trên PE01:
            PE01#show ip route vrf A1
            Routing Table: A1
            B 192.168.5.0/24 [200/0] via 2.2.2.2, 00:45:07
            D 10.10.10.0 [90/156160] via 192.168.1.1, 00:45:24, FastEthernet0/0
            C 192.168.1.0/24 is directly connected, FastEthernet0/0
            30.0.0.0/24 is subnetted, 1 subnets
            B 30.30.30.0 [200/2297856] via 2.2.2.2, 00:45:07
            PE01#show ip route vrf B1
            Routing Table: B1
            100.0.0.0/24 is subnetted, 1 subnets
            D 100.100.100.0 [90/2172416] via 192.168.2.1, 00:44:46, Serial0/0
            20.0.0.0/24 is subnetted, 1 subnets
            D 20.20.20.0 [90/2297856] via 192.168.2.1, 00:44:46, Serial0/0
            40.0.0.0/24 is subnetted, 1 subnets
            B 40.40.40.0 [200/156160] via 2.2.2.2, 00:46:20
            B 192.168.6.0/24 [200/0] via 2.2.2.2, 00:46:20
            C 192.168.2.0/24 is directly connected, Serial0/0
            Trên PE02:
            PE02#show ip route vrf A2
            Routing Table: A2
            C 192.168.5.0/24 is directly connected, Serial0/0
            B 10.10.10.0 [200/156160] via 1.1.1.1, 00:45:16
            B 192.168.1.0/24 [200/0] via 1.1.1.1, 00:45:16
            D 30.30.30.0 [90/2297856] via 192.168.5.2, 00:48:47, Serial0/0
            PE02#show ip route vrf B2
            Routing Table: B2
            B 100.100.100.0 [200/2172416] via 1.1.1.1, 00:46:44
            B 20.20.20.0 [200/2297856] via 1.1.1.1, 00:46:44
            D 40.40.40.0 [90/156160] via 192.168.6.2, 00:49:30, FastEthernet0/1
            C 192.168.6.0/24 is directly connected, FastEthernet0/1
            B 192.168.2.0/24 [200/0] via 1.1.1.1, 00:45:59
            - Kiểm tra thông tuyến:
            A1#ping 30.30.30.30
            Sending 5, 100-byte ICMP Echos to 30.30.30.30, timeout is 2 seconds:
            Success rate is 100 percent (5/5), round-trip min/avg/max = 196/236/300 ms
            B1#ping 40.40.40.40
            Sending 5, 100-byte ICMP Echos to 40.40.40.40, timeout is 2 seconds:
            Success rate is 100 percent (5/5), round-trip min/avg/max = 156/180/200 ms
            - Kiểm tra bảng LFIP hoàn chỉnh trên mỗi Router PE01 và PE02:
            19 Untagged 20.20.20.0/24[V] 0 Se0/0 point2point
            20 Untagged 100.100.100.0/24[V] \
            0 Se0/0 point2point
            21 Untagged 10.10.10.0/24[V] 0 Fa0/0 192.168.1.1
            22 Aggregate 192.168.1.0/24[V] 520
            23 Aggregate 192.168.2.0/24[V] 520
            19 Untagged 30.30.30.0/24[V] 520 Se0/0 point2point
            20 Aggregate 192.168.5.0/24[V] 0
            21 Untagged 40.40.40.0/24[V] 570 Fa0/1 192.168.6.2
            22 Aggregate 192.168.6.0/24[V] 0
            - Kiểm tra cơ chế chuyển mạch nhãn tại MPLS Domain
            PE01#traceroute vrf A1 30.30.30.30
            Tracing the route to 30.30.30.30
            1 192.168.3.2 [MPLS: Labels 16/19 Exp 0] 160 msec 184 msec 144 msec
            2 192.168.5.1 [MPLS: Label 19 Exp 0] 128 msec 60 msec 92 msec
            3 192.168.5.2 176 msec * 216 msec
            PE02#traceroute vrf B2 20.20.20.20
            Tracing the route to 20.20.20.20
            1 192.168.4.1 [MPLS: Labels 17/19 Exp 0] 176 msec 120 msec 156 msec
            2 192.168.2.2 [MPLS: Label 19 Exp 0] 212 msec 64 msec 52 msec
            3 192.168.2.1 92 msec * 160 msec
              làm xong bài này em ping A1 sang PE01 được còn PE01 Ping sang A1 không được!!!!!Như vậy A2 chỉ ping được tới PE01, Ai biết tình huống này giúp mình với!!!!!
                ai chỉ với coi
