CCNP2 Case tudy (Cisco Acedamy 2006)
  • CCNP2 Case tudy (Cisco Acedamy 2006)
    Cac ban tham khao.
    Day la dap an gan nhu day du. Than.
    R1
    There is 1 mistakes in this configuration.
    sh run
    Current configuration : 3090 bytes
    version 12.4
    hostname R1
    boot-start-marker
    boot-end-marker
    !card type command needed for slot 1
    enable password cisco
    aaa new-model
    aaa authentication login default local
    aaa authentication ppp default local
    aaa session-id common
    no network-clock-participate slot 1
    no network-clock-participate wic 0
    ip cef
    isdn switch-type primary-ni
    chat-script R165k ABORT ERROR "" "AT Z" OK "ATDT \T" TIMEOUT 30 CONNECT \c
    username R3 password 0 cisco
    username USERS password 0 cisco
    username R2 password 0 cisco
    username R1 password 0 cisco
    class-map match-all CBWFQ
    match access-group 101
    policy-map CBWFQ-TS
    class CBWFQ
    bandwidth 16
    crypto isakmp policy 100
    authentication pre-share
    crypto isakmp key 6 CISCO123 address 10.1.1.22
    crypto ipsec transform-set MYSET esp-des
    crypto map MYMAP 110 ipsec-isakmp
    set peer 10.1.1.22
    set transform-set MYSET
    match address 120
    interface FastEthernet0/0
    shutdown
    duplex auto
    speed auto
    interface Serial0/0
    encapsulation frame-relay
    no fair-queue
    frame-relay traffic-shaping
    frame-relay lmi-type ansi
    interface Serial0/0.102 point-to-point
    ip address 10.1.1.21 255.255.255.252
    frame-relay class R2
    frame-relay interface-dlci 102
    crypto map MYMAP
    interface Serial0/0:23
    encapsulation ppp
    dialer pool-member 1
    dialer load-threshold 1 outbound
    dialer idle-timeout 60
    ppp authentication chap
    ! <+++> Fair queue is missing ???
    interface BRI0/0
    encapsulation hdlc
    shutdown
    isdn switch-type basic-ni
    isdn point-to-point-setup
    interface Serial0/1
    shutdown
    interface Async65
    ip address 10.1.1.17 255.255.255.252
    encapsulation ppp
    dialer in-band
    dialer idle-timeout 300
    dialer wait-for-carrier-time 60
    dialer map ip 10.1.1.8 name R3 class dialback modem-script R156k broadcast 5556001
    dialer hold-queue 50
    dialer callback-secure
    dialer-group 1
    async mode dedicated
    ppp callback accept
    ppp authentication chap callin
    interface Dialer0
    ip address 10.1.1.1 255.255.255.248
    encapsulation ppp
    dialer pool 1
    dialer remote-name R2
    dialer string 5551000
    dialer watch-disable 15
    dialer watch-group 2
    dialer-group 2
    router eigrp 100
    network 10.1.1.20 0.0.0.3
    network 10.0.0.0
    network 192.168.1.0
    auto-summary
    ip route 192.168.3.0 255.255.255.0 10.1.1.18
    ! ip default-network missing ???
    ip http server
    no ip http secure-server
    map-class dialer dialback
    dialer callback-server username
    map-class frame-relay R2
    frame-relay cir 16000
    frame-relay bc 64000
    frame-relay be 64000
    frame-relay adaptive-shaping becn
    access-list 101 permit tcp any any eq telnet
    access-list 102 deny eigrp any any
    access-list 102 permit ip any any
    access-list 120 permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
    dialer watch-list 2 ip 10.1.1.20 255.255.255.252
    dialer-list 2 protocol ip list 102
    control-plane
    controller t1 1/0
    framing esf
    linecode b8zs
    pri-group timeslots 1-24
    line aux 0
    password cisco
    modem InOut
    modem autoconfigure discovery
    transport input all
    stopbits 1
    speed 115200
    flowcontrol hardware
    password cisco
    R1#
      R2:
      There are two mistakes in this configuration.
      sh run
      Current configuration : 2816 bytes
      version 12.4
      hostname R2
      boot-start-marker
      boot-end-marker
      aaa new-model
      ip cef
      policy-map CBWFQ-TS
      class CBWFQ
      bandwidth 16
      crypto isakmp key 6 CISCO123 address 10.1.1.21
      set peer 10.1.1.21
      match address 120
      shutdown
      duplex auto
      speed auto
      interface Serial0/0
      no fair-queue
      interface Serial0/0.201 point-to-point
      ip address 10.1.1.22 255.255.255.252
      frame-relay class R1
      frame-relay interface-dlci 201
      crypto map MYMAP
      interface FastEthernet0/1
      shutdown
      duplex auto
      speed auto
      interface Serial0/1
      shutdown
      interface BRI1/0
      encapsulation ppp
      isdn spid1 51055510000001 5551000
      isdn spid2 51055510010001 5551001
      interface BRI1/1
      encapsulation hdlc
      shutdown
      interface BRI1/2
      encapsulation hdlc
      shutdown
      interface BRI1/3
      encapsulation hdlc
      shutdown
      interface Dialer0
      ip address 10.1.1.2 255.255.255.248
      encapsulation ppp
      dialer pool 1
      dialer remote-name R1
      dialer string 5555000
      dialer load-threshold 1 either
      dialer-group 2
      ppp multilink
      router eigrp 100
      network 10.0.0.0
      network 192.168.2.0
      auto-summary
      ip http server
      map-class frame-relay R1
      ! <+++> frame-relay adaptive-shaping becn
      ! <+++> service-policy output xxxxxx
      access-list 120 permit ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
      control-plane
      line aux 0
      password cisco
      R2#
        R3
        There is no mistake in this configuration.
        sh run
        Current configuration : 1443 bytes
        version 12.4
        hostname R3
        boot-start-marker
        boot-end-marker
        aaa new-model
        ip cef
        chat-script R156k ABORT ERROR "" "AT Z" OK "ATDT \T" TIMEOUT 30 CONNECT \C
        username USER password 0 cisco
        no shutdown
        duplex auto
        speed auto
        interface BRI0/0
        encapsulation hdlc
        shutdown
        interface Serial0/0
        physical-layer async
        ip address 10.1.1.18 255.255.255.252
        encapsulation ppp
        dialer in-band
        dialer map ip 10.1.1.17 name R1 modem-script R156k 5556001
        dialer-group 1
        ppp callback request
        interface Serial0/1
        shutdown
        ip route 0.0.0.0 0.0.0.0 10.1.1.17
        ip http server
        control-plane
        line 1
        modem InOut
        transport input all
        stopbits 1
        speed 115200
        line aux 0
        ??? no password ???
        password cisco
        R3#
