When you enable the DHCP relay agent option 82 on the switch, these events occur:
• The host (DHCP client) generates a DHCP request and broadcasts it on the network.
• The switch (DHCP relay agent) intercepts the broadcast DHCP request packet and inserts the relay agent information option (option 82) in the packet. The relay information option contains the switch’s MAC address (the remote ID suboption) and the port SNMP ifindex from which the packet is received (circuit ID suboption).
• The switch forwards the DHCP request that includes the option-82 field to the DHCP server.
• The DHCP server receives the packet. If the server is option-82 capable, it might use the remote ID, the circuit ID, or both to assign IP addresses and implement policies, such as restricting the number of IP addresses that can be assigned to a single remote ID or circuit ID. Then the DHCP server echoes the option-82 field in the DHCP reply.
If the server does not support option 82, it ignores the option and does not echo it in the reply.
• The DHCP server unicasts the reply to the relay agent. The relay agent makes sure that the packet is destined for it by checking the IP destination address in the packet, which is the same as the Layer 3 interface where the ip helper-address interface configuration command is configured. The relay agent removes the option-82 field and forwards the packet to the switch port that connects to the
DHCP client, which sent the DHCP request.
Đúng như giả thuyết đã đưa ra bên trên, DHCP Agent dùng Option để đánh dấu Client's MAC và Reencapsulation DHCP Request bằng Its Dedault Gateway IP để gửi đến DHCP Server.
Cảm ơn Duydq đã đưa ra thông tin chính xác để giải quyết tường tận vấn đề.
Còn một cách nữa là đánh VLAN tag cho các eth frame đi tới DHCP Server nếu như khả năng của thiết bị mạng cho phép, rồi chia cái eth interface của DHCP Server thành 3 cái interface ảo với 3 IPs thuộc 3 subnet khác nhau ứng cho mỗi VLAN, làm 3 cái dhcp pool ứng với từng subnet một y như là nó đang cắm vào 3 mạng riêng biệt.
Mấy đại ca ơi! Cho em hỏi em có 2 vlan cho 2 bộ phận khác nhau. Bây giờ làm sao để in từ bộ phận này qua máy in của bộ phận khác nằm trên 2 VLAN khác nhau. Em đang rất đau đầu, không lẽ phải gắn thêm card mạng nữa à. Như vậy thì không pro tí nào. Mong các đại ca chỉ dùm em.
Chú nói rõ hơn đi , 2 vlan đó nôi với nhau quan sw àh hay router gì không ?
dùng Router hoặc Switch layer 3 để routing 2 vlan này là ok!
bạn đưa mô hình cụ thể lên đây mọi người sẽ giúp phần cấu hình :D
Bạn hãy enable port của Switch nối với máy in lên interface Trunk thì sẽ in được ngay thôi. Vì interface Trunk cho phép tất cả các VLAN đi qua.
Đã nói đến Vlan thì 2 mạng đã hoàn toàn khác nhau làm sao co sự liên kết giữa 2 mạng được. Nếu bạn muốn in giữa 2 mạng thì bạn phải route 2 mạng thôi. Mong các pro chỉ bảo thêm.
Không sợ nói sai chỉ sợ không thấy cái sai của mình
Chí phải , chí phải . trong trường hợp này , 1 Sw l3 có thể giải quyết được tình huống .
