Help frame relay multipoint, point to point
  • Help frame relay multipoint, point to point
    Trong mô hình trên Con FR cấu hình để được các PVC là R1->R2, R1->R3.
    Cấu hình của FR:
    hostname FRSW
    no ip domain lookup
    frame-relay switching
    interface s1/0
    encapsulation frame-relay ietf
    frame-relay intf-type dce
    frame-relay lmi-type q933a
    frame-relay route 102 interface Serial1/1 201
    frame-relay route 103 interface Serial1/2 301
    no shutdown
    exit
    interface s1/1
    frame-relay route 201 interface Serial1/0 102
    no shutdown
    exit
    interface s1/2
    frame-relay route 301 interface Serial1/0 103
    no shutdown
    exit
    Cấu hình của R1:
    hostname R1
    no ip domain lookup
    interface fa0/0
    no shutdown
    keepalive
    exit
    interface S1/0
    no shutdown
    exit
    interface s1/0.1 multipoint
    ip address 194.1.1.1 255.255.255.0
    no ip split-horizon
    frame-relay map ip 194.1.1.2 102 broadcast
    frame-relay map ip 194.1.1.3 103 broadcast
    no shutdown
    exit
    router rip
    version 2
    no auto-summary
    network 194.1.1.0
    network 172.16.0.0
    exit
    Cấu hình của R2:
    hostname R2
    no ip domain lookup
    interface fa0/0
    ip address 172.16.2.1 255.255.255.0
    no shutdown
    keepalive
    exit
    interface S1/0
    no shutdown
    exit
    interface s1/0
    ip address 194.1.1.2 255.255.255.0
    frame-relay interface-dlci 201
    no shutdown
    exit
    router rip
    version 2
    no auto-summary
    network 194.1.1.0
    network 172.16.0.0
    exit
    Cấu hình của R3:
    hostname R3
    no ip domain lookup
    interface fa0/0
    ip address 172.16.3.1 255.255.255.0
    no shutdown
    keepalive
    exit
    interface S1/0
    no shutdown
    exit
    interface s1/0
    ip address 194.1.1.3 255.255.255.0
    frame-relay interface-dlci 301
    no shutdown
    exit
    router rip
    version 2
    no auto-summary
    network 194.1.1.0
    network 172.16.0.0
    exit
    Bảng frame relay route của FR:
    FRSW#show frame-relay route
    Input Intf Input Dlci Output Intf Output Dlci Status
    Serial1/0 102 Serial1/1 201 active
    Serial1/0 103 Serial1/2 301 active
    Serial1/1 201 Serial1/0 102 active
    Serial1/2 301 Serial1/0 103 active
    FRSW#
    Bảng routing của R1:
    R1#show ip route
    172.16.0.0/24 is subnetted, 3 subnets
    C 172.16.1.0 is directly connected, FastEthernet0/0
    R 172.16.2.0 [120/1] via 194.1.1.2, 00:00:26, Serial1/0.1
    R 172.16.3.0 [120/1] via 194.1.1.3, 00:00:00, Serial1/0.1
    C 194.1.1.0/24 is directly connected, Serial1/0.1
    R1#
    Bảng routing của R2:
    R2#show ip route
    R 172.16.1.0 [120/1] via 194.1.1.1, 00:00:24, Serial1/0
    C 172.16.2.0 is directly connected, FastEthernet0/0
    R 172.16.3.0 [120/2] via 194.1.1.3, 00:00:24, Serial1/0
    R2#
    Bảng routing của R3:
    R3#show ip route
    R 172.16.1.0 [120/1] via 194.1.1.1, 00:00:00, Serial1/0
    R 172.16.2.0 [120/2] via 194.1.1.2, 00:00:00, Serial1/0
    C 172.16.3.0 is directly connected, FastEthernet0/0
    R3#
    Mặc dù trong bảng routing của R2 có mạng 172.16.3.0/24 của R3 nhưng ping không được:
    R2#ping 172.16.3.1 source 172.16.2.1
    Sending 5, 100-byte ICMP Echos to 172.16.3.1, timeout is 2 seconds:
    Packet sent with a source address of 172.16.2.1
    R2#
    Nhưng khi cấu hình subinterface trên R2 và R3 thì lại ping thành công.
    R2:
    interface s1/0.201 point-to-point
    no shutdown
    exit
    R3:
    interface s1/0.301 point-to-point
    no shutdown
    exit
    Ping từ R2 sang R3:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 76/92/108 ms
    R2#
    R2#traceroute 172.16.3.1 source 172.16.2.1
    Tracing the route to 172.16.3.1
    1 194.1.1.1 40 msec 44 msec 44 msec
    2 194.1.1.3 100 msec * 88 msec
    R2#
    các anh cho em hỏi tại sao khi cấu hình không subinterface point to point trên R2 và R3 thì dù thấy route tới đích nhưng không đi được.
    còn khi cấu hình subinterface point to point lại là đi được.
    Rất mong nhận được giải đáp
    Thanks!
    Hi bạn! Khi bạn cấu hình frame-relay point-to-point thì câu lệnh frame-relay interface-dlci 301 thì câu lệnh này sẽ khác khi bạn cấu hình trên cổng bình thường. Ở trên cổng vật lí bình thường (no sub-interface) thì bạn dùng câu lệnh frame-relay map ip x.x.x.x DLCI để map địa chỉ IP với DLCI hoặc có thể sử dụng chế độ Inverse ARP để ánh xạ DLCI. Trên cổng sub point-to-point thì không cần thì đã là point-to-point thì nó chỉ có việc đẩy gói tin ra khỏi cổng đó và map nó với DLCI.
    Lê Hồng Nam
    NIIT-iPMAC
    Website: www.ipmac.vn
    NET YOUR WORK!
      thanks! nhưng em hỏi là tại sao khi trên interface thì không ping được giữa 2 card internet R2 và R3, còn khi subinterface thì được.
        Tham khảo thêm ở đây bạn hen. Cổng Point-point sub có 1 số điểm mà theo thầy nói là "điều kỳ quặc" của Point - to - point :D
        Nguyễn Bá Hiển
        Email: nguyenbahien@vnpro.org
        Yahoo: nguyenbahien_vnpro
          Add frame-lay map statements to R2 and R3 if you don't want to use point-point subinterface. I hope this helps.
          R2:
          interface S1/0
          frame-relay map ip 194.1.1.1 201 broadcast
          R3:
          interface S1/0
          frame-relay map ip 194.1.1.1 301 broadcast
          Trần Nhân Hòa
          CMND #0146257668
            R2:
            interface S1/0
            R3:
            interface S1/0
            thanks ! có lẽ bạn không hiểu ý mình hỏi rồi.
              http://vnpro.org/blog/?p=186
              thanks! bạn học thày nào vậy?
