Routing Enable trên Switch 3560x
  • Routing Enable trên Switch 3560x
    Mình đang chia VLAN trên con 3560x nhưng không hiểu tại sao các máy con trong 2 vlan 34 và 99 không ping thấy nhau được.
    Mong được trợ giúp
    Thông tin tren switch như bên dưới.
    - Thông tin OS
    Backbone-C3560X#sh ver
    Cisco IOS Software, C3560E Software ([B][COLOR="#FF0000"]C3560E-UNIVERSALK9-M), Version 12.2(55)SE5[/COLOR][/B], RELEASE SOFTWARE (fc1)
    Technical Support: http://www.cisco.com/techsupport
    Copyright (c) 1986-2012 by Cisco Systems, Inc.
    Compiled Thu 09-Feb-12 18:32 by prod_rel_team
    Image text-base: 0x00003000, data-base: 0x02800000
    ROM: Bootstrap program is C3560E boot loader
    BOOTLDR: C3560E Boot Loader (C3560X-HBOOT-M) Version 12.2(58r)SE1, RELEASE SOFTWARE (fc1)
    Backbone-C3560X uptime is 1 hour, 44 minutes
    System returned to ROM by power-on
    System image file is "flash:/c3560e-universalk9-mz.122-55.SE5/c3560e-universalk9-mz.122-55.SE5.bin"
    - Thông tin cấu hình
    Backbone-C3560X#sh ru
    Current configuration : 5345 bytes
    version 12.2
    no service pad
    hostname Backbone-C3560X
    boot-start-marker
    boot-end-marker
    enable secret 5 $1$7rNI$TqVEZRs1vmfLREVg/5p2z0
    username admin secret 5 $1$KBxm$ueNqrHJyEnJ/8ipqS4epu0
    no aaa new-model
    system mtu routing 1500
    [COLOR="#FF0000"][B]ip routing[/B][/COLOR]
    ip dhcp pool VLAN-99
       network 192.168.99.0 255.255.255.0
       default-router 192.168.99.1
       dns-server 192.168.0.12
    ip dhcp pool VLAN-34
       network 192.168.34.0 255.255.255.0
       default-router 192.168.34.1
    interface GigabitEthernet0/21
     switchport access vlan [COLOR="#FF0000"][B]34[/B][/COLOR]
     switchport mode access
    interface GigabitEthernet0/22
     switchport access vlan [COLOR="#FF0000"][B]99[/B][/COLOR]
    Backbone-C3560X#sh sdm pr
     The current template is "desktop routing" template.
     The selected template optimizes the resources in
     the switch to support this level of features for
     8 routed interfaces and 1024 VLANs.
      number of unicast mac addresses:                  3K
      number of IPv4 IGMP groups + multicast routes:    1K
      number of IPv4 unicast routes:                    11K
        number of directly-connected IPv4 hosts:        3K
        number of indirect IPv4 routes:                 8K
      [COLOR="#FF0000"][B]number of IPv4 policy based routing aces:         0.5K[/B][/COLOR]
      number of IPv4/MAC qos aces:                      0.5K
      number of IPv4/MAC security aces:                 1K
    Backbone-C3560X#sh int tru
    Port        Mode             Encapsulation  Status        Native vlan
    Gi1/1       auto             802.1q         trunking      1
    Po1         on               802.1q         trunking      99
    Port        Vlans allowed on trunk
    Gi1/1       1-4094
    Po1         1-4094
    Port        Vlans allowed and active in management domain
    Gi1/1       1,10-12,17,34,56,77,99,199
    Po1         1,10-12,17,34,56,77,99,199
    Địa chỉ ip trên interface vlan chưa có mà
      có rồi bạn ơi.
      P/s: cũng các bước cấu hình đó mình làm trên packet Tracert (OS: c3560-advipservicesk9-mz.122-37.SE1.bin) thì các máy tính lấy IP và thông nhau bình thường, còn trên thiết bị thiệt (c3560e-universalk9-mz.122-55.SE5) thì không lấy được IP. Không biết phải OS không nữa
        - Các máy tính thuộc 2 vlan này đặt defalt gateway chưa ?
        - Đứng trến sw L3 thử ping 192.168.34.1 source interface vlan 99 xem thế nào
        P/S: trên switch có thể tạo ACLs để monitor traffic từ 2 vlan này, xem có thông tin gì ko.
