Port Forwarding với ASA 5505
  • Port Forwarding với ASA 5505
    Hi all,
    Tôi có network như sau
    LAN ---> Cisco ASA 5505 ---> Internet
    giờ có 1 web server trong LAN, muốn map port 80 từ ASA vào LAN nhưng không được. Cấu hình hiện tại như sau:
    : Saved
    ASA Version 8.0(3)6
    hostname ciscoasa
    domain-name mydomain.com
    enable password <deleted> encrypted
    passwd <deleted> encrypted
    names
    interface Vlan1
     nameif inside
     security-level 100
     ip address 192.168.0.1 255.255.255.0
    interface Vlan2
     nameif outside
     security-level 0
     pppoe client vpdn group MyISP
     ip address pppoe setroute
    interface Ethernet0/0
     switchport access vlan 2
    interface Ethernet0/1
    interface Ethernet0/2
    interface Ethernet0/3
    interface Ethernet0/4
    interface Ethernet0/5
    interface Ethernet0/6
    interface Ethernet0/7
    ftp mode passive
    clock timezone ICT 7
    dns server-group DefaultDNS
    same-security-traffic permit intra-interface
    object-group protocol TCPUDP
     protocol-object udp
     protocol-object tcp
    access-list outside_access_in extended permit tcp any host 117.x.x.x eq www
    pager lines 24
    logging enable
    logging asdm informational
    mtu inside 1500
    mtu outside 1500
    no failover
    asdm image disk0:/asdm-603.bin
    no asdm history enable
    arp timeout 14400
    nat-control
    global (outside) 1 interface
    nat (inside) 1 0.0.0.0 0.0.0.0 dns
    static (inside,outside) tcp interface www 192.168.0.2 www netmask 255.255.255.255  dns
    static (outside,inside) tcp 192.168.0.2 www 117.x.x.x www netmask 255.255.255.255  dns
    access-group outside_access_in in interface outside
    timeout xlate 3:00:00
    timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
    timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
    timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
    timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
    dynamic-access-policy-record DfltAccessPolicy
    http server enable
    http 192.168.0.0 255.255.255.0 inside
    no snmp-server location
    no snmp-server contact
    snmp-server enable traps snmp authentication linkup linkdown coldstart
    telnet 192.168.0.0 255.255.255.0 inside
    telnet timeout 5
    ssh timeout 5
    console timeout 0
    vpdn group MyISP request dialout pppoe
    vpdn group MyISP localname MyUserName
    vpdn group MyISP ppp authentication pap
    vpdn username MyUserName password *********
    dhcpd address 192.168.0.2-192.168.0.254 inside
    threat-detection basic-threat
    threat-detection statistics
    ntp server 210.138.109.164 source outside prefer
    class-map inspection_default
     match default-inspection-traffic
    policy-map type inspect dns preset_dns_map
     parameters
      message-length maximum 512
    policy-map global_policy
     class inspection_default
      inspect ftp
      inspect h323 h225
      inspect h323 ras
      inspect rsh
      inspect rtsp
      inspect esmtp
      inspect sqlnet
      inspect skinny
      inspect sunrpc
      inspect xdmcp
      inspect sip
      inspect netbios
      inspect tftp
    service-policy global_policy global
    prompt hostname context
    Cryptochecksum:<deleted>
    : end
    Nhờ mọi người check giúp xem sai gì mà không access được Web server? Sai cấu hình NAT ?
    Xin cám ơn !
    Cheer !
    bạn bỏ thử 2 câu lệnh http command trong cấu hình ASA bằng cách:
    no http server enable
    no http 192.168.0.0 255.255.255.0 inside
    http 0.0.0.0 0.0.0.0 outside
    bạn nên sử dụng port khác ngoài port 80 của ASA để tránh rắc rối ví dụ như mapping sang port 8080
    Nguyễn Quốc Lễ, CCNP CCSP
    Email: nguyenquocle@wimaxpro.org
    Tel: (08) 35124257
    Fax: (08) 5124314
    Support Forum : http://www. vnpro.org
    Live Chat http://vnpro.org/forum/image.php?u=2...ine=1233770177 : http://www.vnpro.vn/support
    Blog VnPro : http://www.vnpro.org/blog
    Cộng Đồng Mạng Không Dây Việt Nam
