Max hopcount của các giao thức định tuyến ??
Nhưng...
Trích từ: http://www.cisco.com/univercd/cc/td/....htm#wp1000064
Vậy xin hỏi maxhopcount của Eigrp là bao nhiêu ?
Max. Hopcounts
RIP1/RIP2 15
IGRP 255
EIGRP 224
OSPF unlimited
RIP1/RIP2 15
IGRP 255
EIGRP 224
OSPF unlimited
metric maximum-hops
To have the IP routing software advertise as unreachable those routes with a hop count higher than is specified by the command (Enhanced Interior Gateway Routing Protocol [EIGRP] only), use the metric maximum-hops command in router configuration mode. To reset the value to the default, use the no form of this command.
metric maximum-hops {hops-number}
no metric maximum-hops {hops-number}
Syntax Description
hops-number
Maximum hop count (in decimal). The default value is 100 hops; the maximum number of hops that can be specified is 255.
Syntax Description
hops-number
