Thưa các thầy, em có sơ đồ như thế này:
Em ko biết mô hình này ngoài thực tế có chạy dc ko ạ @-)
Em đang gặp vấn đề như sau: các máy bên trong vlan ko ping ra dc ISP trong khi từ RA đã ping ra dc rồi :106:
Mog các thầy và các bạn giúp em với !!! Em xin cảm ơn !!!
Em xin post file cấu hình:
RA:
R2:
ISP:
SW:
RA:
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
interface FastEthernet0/0
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 2
ip address 192.168.2.200 255.255.25
interface FastEthernet0/1
ip address 192.168.1.1 255.255.255.
duplex auto
speed auto
interface Serial1/0
shutdown
serial restart-delay 0
interface Serial1/1
shutdown
interface Serial1/2
shutdown
interface Serial1/3
shutdown
ip route 0.0.0.0 0.0.0.0 192.168.1.2
ip http server
no ip http secure-server
control-plane
line aux 0
login
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
duplex auto
speed auto
duplex auto
speed auto
interface Serial1/0
shutdown
interface Serial1/1
shutdown
interface Serial1/2
shutdown
interface Serial1/3
shutdown
ip http server
control-plane
line aux 0
login
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
shutdown
duplex auto
speed auto
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface Serial1/0
ip address 210.10.10.2 255.255.255.0
ip nat outside
interface Serial1/1
shutdown
interface Serial1/2
shutdown
interface Serial1/3
shutdown
ip route 0.0.0.0 0.0.0.0 210.10.10.1
ip http server
ip nat inside source list 10 interface Serial1/0 overload
access-list 10 permit 192.168.1.0 0.0.0.255
control-plane
line aux 0
login
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
shutdown
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
interface Serial1/0
ip nat outside
interface Serial1/1
shutdown
interface Serial1/2
shutdown
interface Serial1/3
shutdown
ip http server
control-plane
line aux 0
login
hostname ISP
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
interface Loopback1
ip address 65.5.5.1 255.255.255.0
shutdown
duplex auto
speed auto
shutdown
duplex auto
speed auto
interface Serial1/0
ip address 210.10.10.1 255.255.255.0
interface Serial1/1
shutdown
interface Serial1/2
shutdown
interface Serial1/3
shutdown
ip http server
control-plane
line aux 0
login
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
interface Loopback1
shutdown
duplex auto
speed auto
shutdown
duplex auto
speed auto
interface Serial1/0
interface Serial1/1
shutdown
interface Serial1/2
shutdown
interface Serial1/3
shutdown
ip http server
control-plane
line aux 0
login
hostname SW
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip dhcp use vrf connected
ip dhcp pool vlan2
network 192.168.2.0 255.255.255.0
default-router 192.168.2.200
shutdown
duplex auto
speed auto
shutdown
duplex auto
speed auto
interface FastEthernet1/0
interface FastEthernet1/1
interface FastEthernet1/2
switchport access vlan 2
interface FastEthernet1/3
switchport access vlan 3
interface FastEthernet1/4
switchport access vlan 4
interface FastEthernet1/5
interface FastEthernet1/6
interface FastEthernet1/7
interface FastEthernet1/8
interface FastEthernet1/9
interface FastEthernet1/10
switchport mode trunk
interface FastEthernet1/11
interface FastEthernet1/12
interface FastEthernet1/13
interface FastEthernet1/14
interface FastEthernet1/15
interface Vlan1
interface Vlan2
ip http server
control-plane
line aux 0
login
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip dhcp pool vlan2
shutdown
duplex auto
speed auto
shutdown
duplex auto
speed auto
interface Vlan1
interface Vlan2
ip http server
control-plane
line aux 0
login
