Spanning-tree uplink fast
  • Spanning-tree uplink fast
    Tôi có hai con switch kết nối qua 2 cổng Etherrnet. Liệu tôi có thể enable uplink fast được ko? Tôi test thử nhưng có vể nó ko hoạt động theo ý mình.
    Cat3560#sh run | in uplink
    spanning-tree uplinkfast
    Cat3560#sh spanning-tree
    VLAN0001
    Spanning tree enabled protocol ieee
    Root ID Priority 20481
    Address 000b.4610.e380
    Cost 19
    Port 8 (FastEthernet0/7)
    Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
    Bridge ID Priority 20481 (priority 20480 sys-id-ext 1)
    Address 001c.b0d9.0280
    Aging Time 300
    Interface Role Sts Cost Prio.Nbr Type
    Fa0/7 Root FWD 19 128.8 P2p
    Fa0/8 Altn BLK 19 128.9 P2p
    Cat3560#conf t
    Cat3560(config)#int fa0/7
    Cat3560(config-if)#shut
    Cat3560(config-if)#
    02:58:23: STP: VLAN0001 new root port Fa0/8, cost 19
    02:58:23: STP: VLAN0001 Fa0/8 -> listening
    02:58:24: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
    02:58:25: %LINK-5-CHANGED: Interface FastEthernet0/7, changed state to administratively down
    02:58:25: STP: VLAN0001 sent Topology Change Notice on Fa0/8
    02:58:26: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/7, changed state to down
    02:58:38: STP: VLAN0001 Fa0/8 -> learning
    02:58:53: STP: VLAN0001 Fa0/8 -> forwarding
    02:58:54: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
    Theo quyen CCNP BCMSN Official Exam Certification Guide, Fourth Edition David Hucaby thì tôi có thể enable uplink fast ngay cả đối với trường hợp 2 switch connected back to back via 2 Ethernet links như trường hợp của tôi, vậy mà ... hu hu :(
    TIP Many Catalyst switches have two built-in, high-speed uplink ports (Gigabit Ethernet,
    for example). You might get the idea that UplinkFast can only toggle between two leaf-node
    uplink ports. This is entirely untrue. UplinkFast keeps a record of all parallel paths to the Root
    Bridge. All uplink ports but one are kept in the Blocking state. If the Root Port fails, the uplink
    with the next-lowest Root Path Cost is unblocked and used without delay.
