This post details the method to connect to Firewall in GNS3 using ASDM. You will establish ASDM session from your machine to GNS3 so we will be building connection/bridge between GNS3 and PC. Also because first you will have to copy ASDM via TFTP to Firewall so this connection is necessary.
1. Follow this guide about how to add a loopback adapter to Windows 7, Windows XP
Windows 7
Windows XP
2. Restart your PC
3. Follow this guide about how to configure ASA 8.4(2) for GNS3.
4. Start a new Porject in GNS3 and drag/drop a ASA (8.4) firewall to the topology
5. Drag/Drop Cloud Object from Panel on the Left to the topology and right click it. Select 'Configure'. Select 'C1' or whatever name of the object.
6. Now as per following diagram select the loopback adapter that you added in step 1.
trình tự ở trang này :
Windows 7
Windows XP
2. Restart your PC
