Giúp mình cái VPN Remote Access !
  • Giúp mình cái VPN Remote Access !
    Mình có sơ đồ mạng như sau :
    Phần modem draytek mình đã Open các port và trỏ về địa chỉ 192.168.100.101 : TCP 3389, UDP : 500, UDP: 4500. Nhưng vẫn không thể quay vpn về được !
    Không biết còn thiếu sót gì không? :((
    Phần cấu hình ASA mình post lên các bạn xem giúp với.
    ASA Version 8.4(2)
    hostname ASATDT
    names
    interface Ethernet0/0
    description ### KET NOI TOI LAN ###
    nameif inside
    security-level 100
    interface Ethernet0/1
    description ### KET NOI TOI INTERNET ###
    nameif outside
    security-level 0
    ip address 192.168.100.100 255.255.255.0
    interface Ethernet0/2
    shutdown
    no nameif
    no security-level
    interface Ethernet0/3
    shutdown
    no nameif
    no security-level
    interface Management0/0
    nameif management
    security-level 100
    management-only
    ftp mode passive
    object network TDT_ANY
    subnet 0.0.0.0 0.0.0.0
    object network HOST_SVR03
    host 192.168.1.3
    object network HOST_WAN
    host 192.168.100.101
    object service RDP_IN
    service tcp source eq 3389
    object service RDP_OUT
    object service Out_In
    service tcp
    object network CAM200
    host 192.168.1.200
    object network CAM201
    host 192.168.1.201
    object network CAM202
    host 192.168.1.202
    object service CAM200_IN
    service tcp source eq 8000
    object service CAM200_OUT
    object service CAM201_IN
    service tcp source eq 8001
    object service CAM201_OUT
    object service CAM202_IN
    service tcp source eq 8002
    object service CAM202_OUT
    access-list 1 extended permit ip 192.168.1.0 255.255.255.0 any
    access-list Out_In_ACL extended permit tcp any object CAM201 eq 8001
    access-list Out_In_ACL extended permit tcp any object CAM200 eq 8000
    access-list Out_In_ACL extended permit tcp any object CAM202 eq 8002
    access-list Out_In_ACL extended permit tcp any object HOST_SVR03 eq 3389
    pager lines 24
    logging asdm informational
    mtu inside 1500
    mtu outside 1500
    mtu management 1500
    ip local pool VPN_POOL 192.168.2.10-192.168.2.100
    icmp permit any outside
    no asdm history enable
    arp timeout 14400
    nat (any,any) source static HOST_SVR03 HOST_WAN service RDP_IN RDP_OUT
    nat (any,any) source static CAM200 HOST_WAN service CAM200_IN CAM200_OUT
    nat (any,any) source static CAM201 HOST_WAN service CAM201_IN CAM201_OUT
    nat (any,any) source static CAM202 HOST_WAN service CAM202_IN CAM202_OUT
    nat (inside,outside) dynamic interface
    access-group 1 in interface inside
    access-group Out_In_ACL in interface outside
    route outside 0.0.0.0 0.0.0.0 192.168.100.2 1
    timeout xlate 3:00:00
    timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
    timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
    timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
    timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
    timeout tcp-proxy-reassembly 0:01:00
    timeout floating-conn 0:00:00
    dynamic-access-policy-record DfltAccessPolicy
    user-identity default-domain LOCAL
    http server enable
    http 192.168.1.0 255.255.255.0 inside
    http 10.10.10.0 255.255.255.0 management
    no snmp-server location
    no snmp-server contact
    snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
    crypto ipsec ikev1 transform-set MY_SET esp-3des esp-sha-hmac
    crypto dynamic-map DYN_MAP 1 set ikev1 transform-set MY_SET
    crypto dynamic-map DYN_MAP 1 set reverse-route
    crypto map MY_MAP 1 ipsec-isakmp dynamic DYN_MAP
    crypto map MY_MAP interface outside
    crypto ikev1 enable outside
    crypto ikev1 policy 1
    authentication pre-share
    encryption 3des
    hash sha
    group 2
    lifetime 43200
    telnet 192.168.1.0 255.255.255.0 inside
    telnet 192.168.100.0 255.255.255.0 outside
    telnet timeout 5
    ssh 0.0.0.0 0.0.0.0 outside
    ssh timeout 5
    console timeout 0
    vpdn username truongchinhtri-lxn password ***** store-local
    dhcpd dns 203.162.4.190 203.162.4.191
    dhcpd lease 172800
    dhcpd address 192.168.1.40-192.168.1.199 inside
    dhcpd enable inside
    dhcpd address 10.10.10.2-10.10.10.10 management
    dhcpd enable management
    threat-detection basic-threat
    threat-detection statistics access-list
    no threat-detection statistics tcp-intercept
    webvpn
    username admin password f3UhLvUj1QsXsuK7 encrypted privilege 15
    username user1 password TTNKHqfM6YyTcEzA encrypted
    tunnel-group VPN_TUNNEL type remote-access
    tunnel-group VPN_TUNNEL general-attributes
    address-pool VPN_POOL
    tunnel-group VPN_TUNNEL ipsec-attributes
    ikev1 pre-shared-key *****
    class-map inspection_default
    match default-inspection-traffic
    policy-map type inspect dns preset_dns_map
    parameters
    message-length maximum client auto
    message-length maximum 512
    policy-map global_policy
    class inspection_default
    inspect ftp
    inspect h323 h225
    inspect h323 ras
    inspect rsh
    inspect rtsp
    inspect esmtp
    inspect sqlnet
    inspect skinny
    inspect sunrpc
    inspect xdmcp
    inspect sip
    inspect netbios
    inspect tftp
    inspect ip-options
    inspect icmp
    service-policy global_policy global
    prompt hostname context
    no call-home reporting anonymous
    Cryptochecksum:7c6eedd6e40e7cb11d13d795f2784450
    : end
    Co ai giup minh voi !
      Dia chỉ 192.168.100.101 nằm ở đâu trong mô hình vậy bạn
      CTY TNHH TM-DV NetViet
      Website: www.netvietco.net
      Email : Info@netvietco.net
      Tel : (+84) 36-028-860
      Vice Director : Mr. Lê Văn Bé Em
      CCNP , CCNPsecurity ,
      JNCIA-ER, JNCIA-EX, JNCIA-JUNOS, JNCIS-ER, JNCIS-SEC
      Yahoo: BeEmITmaster
      Mail primary: BeEm@netvietco.net
      Phone number : +84.932.746.646
        Lưu ý, trên Vigor nhớ tắt tính năng vpn đi. Thử test quay vpn khi cắm trực tiếp với ASA ko qua Vigor thử chạy được ko là sẽ biết liền.
        YM & Email: dinhcuongvnvn@yahoo.com
          Chào bạn,
          Vote cho bạn samsung79 một phiếu.
          Bạn có thể thử bằng cách sau:
          Nối 1 PC vào cổng E0/1 của ASA
          Quay VPN test
          Nếu OK mà qua thiết bị draytek không VPN được bạn vào tắt 4 dấu check VPN trên con draytek đi là sẽ OK ngay
          Phạm Minh Tuấn
          Yahoo : phamminhtuan_vnpro
            Sao không để con Draytek chạy Bridge Mode?
              Mình thấy bạn nói rất đúng, mô hình thực tế bên ngoài thì sẽ chạy Bridge mode nếu ở đây là các modem có khả năng thực thi kém.
              Còn nếu có 2 chủng loại firewall khác nhau luôn thì cũng có thể đặt như vậy để bù trừ cho nhau.
              Còn thông thường mô hình dùng nhiều firewall thì sẽ đặt ít nhất 1 firewall bên trong để kiểm soát ứng dụng và ít nhất 1 firewall bên ngoài (vùng DMZ thì đặt giữa 2 firewall này)
              Phạm Minh Tuấn
                Giúp bạn cái Link cấu hình Draytek Router để pass-through VPN Tunnel.
                http://www.draytek.com/user/SupportFAQDetail.php?ID=184
                  làm theo những mách giúp của các thầy và mọi người đi bạn. có gì cứ poost lên.
                    Giup minh cai VPN Remote Access
                    Nhu cai tieu d? ? tren minh mu?n h?i la win 8 co choi du?c the sim 2 b?n m? r?ng khong tinh hinh la lau r?i khong choi gi? mu?n choi l?i thi minh ch? cai du?c the sim 2 b?n g?c thoi con nh?ng b?n m? r?ng thi minh cai v? choi khong du?c , ai co kinh nghi?m giup minh cai Cam on m?i ngu?i
                    http://itqueries.com/
