CẤU HÌNH PPPoE AND VPN
This is a sticky topic.
  • CẤU HÌNH PPPoE AND VPN
    Địa chỉ của các interface :
    Device Interface Ip address
    Client Lo0
    Dialer1 10.10.10.10/24
    203.106.10.2/24
    Remote E0/0
    S0/0 20.20.20.20/24
    203.162.11.2/24
    Server Lo1
    S0/0 203.106.10.1/24
    203.162.11.1/24
    Cấu hình toàn bộ :
    remote#sh run
    Current configuration : 1273 bytes
    version 12.1
    no service single-slot-reload-enable
    service timestamps log uptime
    hostname remote
    logging rate-limit console 10 except errors
    memory-size iomem 10
    ip subnet-zero
    no ip finger
    crypto isakmp policy 10
    hash md5
    authentication pre-share
    group 2
    crypto isakmp key cisco address 203.106.10.2 255.255.255.0
    crypto ipsec transform-set vnpro ah-md5-hmac esp-des
    crypto map tam 10 ipsec-isakmp
    set peer 203.106.10.2
    set transform-set vnpro
    match address 110
    call rsvp-sync
    interface Ethernet0/0
    ip address 20.20.20.20 255.255.255.0
    ip nat inside
    no keepalive
    half-duplex
    interface Serial0/0
    ip address 203.162.11.2 255.255.255.0
    ip nat outside
    crypto map tam
    interface Serial0/1
    shutdown
    ip nat inside source list 100 interface Serial0/0 overload
    ip classless
    ip route 0.0.0.0 0.0.0.0 203.162.11.1
    no ip http server
    access-list 100 deny ip 20.20.20.0 0.0.0.255 10.10.10.0 0.0.0.255
    access-list 100 permit ip 20.20.20.0 0.0.0.255 any
    access-list 110 permit ip 20.20.20.0 0.0.0.255 10.10.10.0 0.0.0.255
    dial-peer cor custom
    transport input none
    line aux 0
    no scheduler allocate
    Client#sh run
    Current configuration : 1596 bytes
    version 12.2
    hostname Client
    ip subnet-zero
    vpdn enable
    vpdn-group 1
    request-dialin
    protocol pppoe
    hash md5
    group 2
    crypto isakmp key cisco address 203.162.11.2 255.255.255.0
    set peer 203.162.11.2
    match address 110
    voice call carrier capacity active
    mta receive maximum-recipients 0
    interface Loopback0
    ip address 10.10.10.10 255.255.255.0
    ip nat inside
    interface Loopback1
    half-duplex
    pppoe enable
    interface Serial0/0
    shutdown
    no fair-queue
    interface Serial0/1
    shutdown
    interface Dialer1
    mtu 1492
    ip address 203.106.10.2 255.255.255.0
    ip nat outside
    encapsulation ppp
    dialer pool 1
    dialer-group 1
    crypto map tam
    ip nat inside source list 100 interface Dialer1 overload
    ip classless
    ip route 0.0.0.0 0.0.0.0 203.106.10.1
    ip http server
    access-list 1 permit 10.10.10.0 0.0.0.255
    access-list 100 deny ip 10.10.10.0 0.0.0.255 20.20.20.0 0.0.0.255
    access-list 100 permit ip 10.10.10.0 0.0.0.255 any
    access-list 110 permit ip 10.10.10.0 0.0.0.255 20.20.20.0 0.0.0.255
    call rsvp-sync
    mgcp profile default
    line aux 0
    Server#sh run
    Current configuration : 858 bytes
    version 12.2
    hostname Server
    logging queue-limit 100
    ip subnet-zero
    vpdn enable
    vpdn-group 1
    accept-dialin
    protocol pppoe
    virtual-template 1
    no voice hpi capture buffer
    no voice hpi capture destination
    interface Loopback1
    ip address 203.106.10.1 255.255.255.0
    half-duplex
    pppoe enable
    interface Serial0/0
    ip address 203.162.11.1 255.255.255.0
    clockrate 64000
    no fair-queue
    interface Virtual-Template1
    ip unnumbered Loopback1
    ip http server
    ip classless
    call rsvp-sync
    line aux 0
    Cấu hình từng bước : Trong bài này chỉ cấu hình phần PPPoE và VPN. Các cấu hình còn lại coi như đã biết.
    • Cấu hình PPPoE :
    Server :
    Tạo vpdn group :
    Server(config)#vpdn enable
    Server(config)#vpdn-group 1
    Server(config-vpdn)#accept-dialin
    Server(config-vpdn-acc-in)#protocol pppoe
     Bật tính năng vpdn để thiết lập các PPPoE session
    Server(config-vpdn-acc-in)#virtual-template 1 <- sử dụng virtual để giao tiếp với client
    Server(config-vpdn-acc-in)#exit
    Server(config)#int lo1
    Server(config-if)#ip add 203.106.10.1 255.255.255.0
    Server(config-if)#int e0/0
    Server(config-if)#pppoe enable <- bật PPPoE trên interface kết nối với client
    Tạo interface virtual-template :
    Server(config)#int virtual-template 1
    Server(config-if)#ip unnumbered lo1
    Client :
    Tạo vpdn group :
    Client(config)#vpdn enable
    Client(config)#vpdn-group 1
    Client(config-vpdn)#request-dialin
    Client(config-vpdn-req-in)#protocol pppoe
    Bật PPPoE trên interface nối với server
    Client(config)#int e0/0
    Client(config-if)#pppoe enable
    Kết hợp interface e0/0 với interface dialer để thiết lập encapsulation cho PPPoE client
    Client(config-if)#pppoe-client dial-pool-number 1
    Client(config-if)#exit
    Cấu hình interface dialer :
    Client(config)#int dialer 1
    Client(config-if)#mtu 1492
    Client(config-if)#ip add 203.106.10.2 255.255.255.0
    Client(config-if)#ip nat outside
    Client(config-if)#encapsulation ppp
    Client(config-if)#dialer pool 1
    Client(config-if)#dialer-group 1
    Client(config)#access-list 1 permit 10.10.10.0 0.0.0.255
    Client(config)#dialer-list 1 protocol ip permit
    Tạo PAT :
    Client(config)#ip nat inside source list 100 interface Dialer1 overload
    Client(config)#access-list 100 deny ip 10.10.10.0 0.0.0.255 20.20.20.0 0.0.0.255
    Client(config)#access-list 100 permit ip 10.10.10.0 0.0.0.255 any
    Bật các lệnh debug và lệnh show để kiểm tra kết nối giữa Server và Client :
    Client(config)#debug ip nat
    Client#ping
    Protocol [ip]:
    Target IP address: 203.106.10.1
    Repeat count [5]:
    Datagram size [100]:
    Timeout in seconds [2]:
    Extended commands [n]: y
    Source address or interface: 10.10.10.10
    Type of service [0]:
    Set DF bit in IP header? [no]:
    Validate reply data? [no]:
    Data pattern [0xABCD]:
    Sweep range of sizes [n]:
    Sending 5, 100-byte ICMP Echos to 203.106.10.1, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 4/12/44 ms
    *Mar 1 01:28:19.438: NAT: s=10.10.10.10->203.106.10.2, d=203.106.10.1 [50]
    *Mar 1 01:28:19.438: NAT*: s=203.106.10.1, d=203.106.10.2->10.10.10.10 [50]
    *Mar 1 01:28:19.442: NAT: s=10.10.10.10->203.106.10.2, d=203.106.10.1 [51]
    *Mar 1 01:28:19.446: NAT*: s=203.106.10.1, d=203.106.10.2->10.10.10.10 [51]
    Client#SH INT
    Ethernet0/0 is up, line protocol is up
    Hardware is AmdP2, address is 000b.5f9a.d0e0 (bia 000b.5f9a.d0e0)
    MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
    Encapsulation ARPA, loopback not set
    Keepalive set (10 sec)
    ARP type: ARPA, ARP Timeout 04:00:00
    Last input 00:00:32, output 00:00:03, output hang never
    <omitted>
    Virtual-Access1 is up, line protocol is up
    Hardware is Virtual Access interface
    MTU 1492 bytes, BW 56 Kbit, DLY 100000 usec,
    Encapsulation PPP, loopback not set
    Interface is bound to Di1 (Encapsulation PPP)
    LCP Open
    Listen: CDPCP
    Open: IPCP
    Last input 00:00:01, output never, output hang never
    Last clearing of "show interface" counters 00:06:35
    Dialer1 is up, line protocol is up (spoofing)
    Hardware is Unknown
    Internet address is 203.106.10.2/24
    MTU 1492 bytes, BW 56 Kbit, DLY 20000 usec,
    DTR is pulsed for 1 seconds on reset
    Interface is bound to Vi1
    Bound to:
    LCP Open
    Listen: CDPCP
    Open: IPCP
    Server#SH INTER
    Hardware is AmdP2, address is 0009.e8d8.f840 (bia 0009.e8d8.f840)
    MTU 1492 bytes, BW 100000 Kbit, DLY 100000 usec,
    Base PPPoE vaccess, loopback not set
    DTR is pulsed for 5 seconds on reset
    Virtual-Access1.1 is up, line protocol is up
    Interface is unnumbered. Using address of Loopback1 (203.106.10.1)
    Encapsulation PPP, LCP Open
    Open: IPCP
    PPPoE vaccess, cloned from Virtual-Template1
    85 packets input, 3414 bytes
    87 packets output, 3499 bytes
    • Cấu hình VPN cho Client và remote :
    Để cấu hình VPN ta cấu hình 2 phase :
    - Phase 1 (IKE phase 1 hay còn gọi là ISAKMP ) : là phase dùng để tạo key, mã hoá key, và trao đổi key.
    Nếu phase 1 thành công sẽ chuyển sang phase 2
    - Phase 2 : là phase sử dụng IPSEC policy để bảo mật data.
    Cấu hình như sau :
    Phase 1 :
    Client(config)#crypto isakmp enable
    Client(config)#crypto isakmp key cisco address 203.162.11.2 255.255.255.0
    Client(config)#crypto isakmp policy 10
    Client(config-isakmp)#authentication pre-share
    Client(config-isakmp)#encryption des
    Client(config-isakmp)#hash md5
    Client(config-isakmp)#group 2
    Client(config-isakmp)#exit
    Client(config)#crypto isakmp identity address
    remote(config)#crypto isakmp enable
    remote(config)#crypto isakmp key cisco address 203.106.10.2 255.255.255.0
    remote(config)#crypto isakmp policy 10
    remote(config-isakmp)#authentication pre
    remote(config-isakmp)#encryption des
    remote(config-isakmp)#hash md5
    remote(config-isakmp)#group 2
    remote(config-isakmp)#exit
    remote(config)#crypto isakmp identity address
    Phase 2 :
    Client(config)#access-list 110 permit ip 10.10.10.0 0.0.0.255 20.20.20.0 0.0.0.255
    Client(config)#crypto ipsec transform-set vnpro esp-des ah-md5-hmac
    Client(cfg-crypto-trans)#exit
    Client(config)#crypto map tam 10 ipsec-isakmp
    Client(config-crypto-map)#set peer 203.162.11.2
    Client(config-crypto-map)#set transform-set vnpro
    Client(config-crypto-map)#match add 110
    Client(config-crypto-map)#exit
    Client(config-if)#crypto map tam
    remote(config)#access-list 110 permit ip 20.20.20.0 0.0.0.255 10.10.10.0 0.0.0.255
    remote(config)#crypto ipsec transform-set vnpro esp-des ah-md5-hmac
    remote(cfg-crypto-trans)#exit
    remote(config)#crypto map tam 10 ipsec-isakmp
    remote(config-crypto-map)#set peer 203.106.10.2
    remote(config-crypto-map)#set tran
    remote(config-crypto-map)#set transform-set vnpro
    remote(config-crypto-map)#match add 110
    remote(config-crypto-map)#exit
    remote(config)#int s0/0
    remote(config-if)#crypto map tam
    remote#debug crypto isakmp
    Crypto ISAKMP debugging is on
    remote#debug crypto ipsec
    Crypto IPSEC debugging is on
    remote#ping
    Protocol [ip]:
    Target IP address: 10.10.10.10
    Repeat count [5]:
    Source address or interface: 20.20.20.20
    Sending 5, 100-byte ICMP Echos to 10.10.10.10, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 52/53/56 ms
    Bật debug để quan sát quá trình ISAKMP negotiate giữa các peer trước khi cho phép SA được sử dụng cho IPSEC .
    00:36:59: IPSEC(sa_request):
    (key eng.msg.) src= 203.162.11.2, dest= 203.106.10.2,
    src_proxy= 10.10.10.0/255.255.255.0/0/0 (type=4),
    dest_proxy= 20.20.20.0/255.255.255.0/0/0 (type=4),
    protocol= ESP, transform= esp-des esp-md5-hmac,
    lifedur= 3600s and 4608000Kb,
    spi= 0x0(0), conn_id= 0, keysize= 0, flags= 0x4004
    !Interesting traffic từ remote đến client kích thích ISAKMP Main Mode.
    ! Quá trình ISAKMP negotiate bắt đầu trong IKE Phase 1 main mode :
    00:36:59: ISAKMP: received ke message (1/2)
    00:36:59: ISAKMP: local port 500, remote port 500
    00:36:59: ISAKMP (0:1): beginning Main Mode exchange
    Tại mode này, ISAKMP sẽ negotiate ISAKMP policy. Bên nào bắt đầu quá trình này trước sẽ gửi tất cả các policy mà nó có đến peer của nó. Trong cấu hình này là remote (203.162.11.2).Peer của router remote là router Client sẽ tìm trong các policy của nó cho đến khi có policy mactch với remote.
    00:36:59: ISAKMP (0:1): sending packet to 203.106.10.2 (I) MM_NO_STATE
    00:37:00: ISAKMP (0:1): received packet from 203.106.10.2 (I) MM_NO_STATE
    00:37:00: ISAKMP (0:1): processing SA payload. message ID = 0
    00:37:00: ISAKMP (0:1): found peer pre-shared key matching 203.106.10.2
    00:37:00: ISAKMP (0:1): Checking ISAKMP transform 1 against priority 10 policy
    00:37:00: ISAKMP: encryption DES-CBC
    00:37:00: ISAKMP: hash MD5
    00:37:00: ISAKMP: default group 2
    00:37:00: ISAKMP: auth pre-share
    00:37:00: ISAKMP: life type in seconds
    00:37:00: ISAKMP: life duration (VPI) of 0x0 0x1 0x51 0x80
    00:37:00: ISAKMP (0:1): atts are acceptable. Next payload is 0
    Tại đây 2 peer đã tìm thấy matching ISAKMP policy.
    00:37:00: ISAKMP (0:1): SA is doing pre-shared key authentication using id type ID_IPV4_ADDR
    Pre-share key dành cho xác thực đã được xác nhận.
    00:37:00: ISAKMP (0:1): sending packet to 203.106.10.2 (I) MM_SA_SETUP
    00:37:00: ISAKMP (0:1): received packet from 203.106.10.2 (I) MM_SA_SETUP
    00:37:00: ISAKMP (0:1): processing KE payload. message ID = 0
    00:37:01: ISAKMP (0:1): processing NONCE payload. message ID = 0
    00:37:01: ISAKMP (0:1): found peer pre-shared key matching 203.106.10.2
    00:37:01: ISAKMP (0:1): SKEYID state generated
    00:37:01: ISAKMP (0:1): processing vendor id payload
    00:37:01: ISAKMP (0:1): speaking to another IOS box!
    00:37:01: ISAKMP (1): ID payload
    next-payload : 8
    type : 1
    protocol : 17
    port : 500
    length : 8
    00:37:01: ISAKMP (1): Total payload length: 12
    00:37:01: ISAKMP (0:1): sending packet to 203.106.10.2 (I) MM_KEY_EXCH
    00:37:01: ISAKMP (0:1): received packet from 203.106.10.2 (I) MM_KEY_EXCH
    00:37:01: ISAKMP (0:1): processing ID payload. message ID = 0
    00:37:01: ISAKMP (0:1): processing HASH payload. message ID = 0
    00:37:01: ISAKMP (0:1): SA has been authenticated with 203.106.10.2
    ! Main mode hoàn tất. Lúc này các peer đã được xác thực , secret key được tạo ra. Bắt đầu vào Phase 2 Quick Mode.
    00:37:01: ISAKMP (0:1): beginning Quick Mode exchange, M-ID of -391346015
    00:37:01:IPSEC(key_engine): got a queue event…
    00:37:01:IPSEC(spi_response): getting spi 199818953 for SA from 203.106.10.2 to 203.162.11.2
    00:37:01: ISAKMP (0:1): processing HASH payload. message ID = -391346015
    00:37:01: ISAKMP (0:1): processing SA payload. message ID = -391346015
    00:37:01: ISAKMP (0:1): Checking IPSec proposal 1
    00:37:01: ISAKMP: transform 1, AH_MD5
    00:37:01: ISAKMP: attributes in transform:
    00:37:01: ISAKMP: encaps is 1
    00:37:01: ISAKMP: SA life type in seconds
    00:37:01: ISAKMP: SA life duration (basic) of 3600
    00:37:01: ISAKMP: SA life type in kilobytes
    00:37:01: ISAKMP: SA life duration (VPI) of 0x0 0x46 0x50 0x0
    00:37:01: ISAKMP: authenticator is HMAC-MD5
    00:37:01: ISAKMP (0:1): atts are acceptable.
    00:37:01: ISAKMP: transform 1, ESP_DES
    00:37:01: IPSEC(validate_proposal_request): proposal part #1,
    00:37:01: ISAKMP (0:1): processing NONCE payload. message ID = -391346015
    00:37:01: ISAKMP (0:1): processing ID payload. message ID = -391346015
    ! IPSEC policy đã được negotiate và đã được xác thực.
    ! Tiếp đến là quá trình thiết lập SA.
    00:37:01: ISAKMP (0:1): Creating IPSec SAs
    00:37:01: inbound SA from 203.106.10.2 to 203.162.11.2
    (proxy 10.10.10.0 to 20.20.20.0)
    00:37:01: has spi 0x75B29B72 and conn_id 2000 and flags 4
    00:37:01: lifetime of 3600 seconds
    00:37:01: lifetime of 4608000 kilobytes
    00:37:01: outbound SA from 203.162.11.2 to 203.106.10.2 (proxy 20.20.20.0 to 10.10.10.0 )
    00:37:01: has spi 721289306 and conn_id 2001 and flags 4
    00:37:01: has spi 0x609CD1A8 and conn_id 2002 and flags 4
    00:37:01: has spi 199818953 and conn_id 2003 and flags 4
    00:37:01: IPSEC(key_engine) : got a queue event…
    00:37:01: IPSEC(initialize_sas):,
    spi= 0x609CD1A8 (199818953), conn_id= 2002, keysize= 0, flags= 0x4
    ! IPSEC SA đã được thiết lập và data có thể trao đôi đảm bảo secure.
