Bài tập lab tổng hợp cho CCNP-BCRAN. Bài 1.
BCRAN challlenging lab 1
This is a sticky topic.
Support Forum: http://www.vnpro.org- Chuyên đào tạo quản trị mạng và hạ tầng Internet
Blog: http://www.vnpro.org/blogTags: None
- Stuck
RE: BCRAN challlenging lab 1
R1#sh run
version 12.1
hostname R1
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp key vnpro1 address 150.50.5.69
crypto ipsec transform-set MYSET ah-md5-hmac esp-des
crypto map MYMAP 10 ipsec-isakmp
set peer 150.50.5.69
set transform-set MYSET
match address 113
ip address 200.0.0.1 255.255.255.255
interface Loopback1
interface Ethernet0/0
ip address 150.50.17.1 255.255.255.0
half-duplex
crypto map MYMAP
router eigrp 100
network 150.50.17.0 0.0.0.255
network 200.0.0.1 0.0.0.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
access-list 113 permit ip 192.168.10.0 0.0.0.255 150.50.4.0 0.0.0.255
logging synchronous
transport input none
line aux 0
password 7 00071A150754
login
no scheduler allocate
R1#sh ip route
200.0.0.0/32 is subnetted, 7 subnets
D 200.0.0.8 [90/2861056] via 150.50.17.2, 00:02:57, Ethernet0/0
D EX 200.0.0.9 [170/2198016] via 150.50.17.2, 00:02:57, Ethernet0/0
C 200.0.0.1 is directly connected, Loopback0
D 200.0.0.2 [90/409600] via 150.50.17.2, 01:06:35, Ethernet0/0
D 200.0.0.4 [90/2323456] via 150.50.17.2, 00:03:51, Ethernet0/0
D 200.0.0.5 [90/2323456] via 150.50.17.2, 00:02:13, Ethernet0/0
D 200.0.0.7 [90/2349056] via 150.50.17.2, 00:02:57, Ethernet0/0
C 192.168.10.0/24 is directly connected, Loopback1
D 10.1.1.0 [90/2221056] via 150.50.17.2, 00:03:51, Ethernet0/0
150.50.0.0/16 is variably subnetted, 9 subnets, 5 masks
D EX 150.50.6.209/32 [170/2198016] via 150.50.17.2, 00:02:57, Ethernet0/0
D 150.50.4.0/24 [90/2758656] via 150.50.17.2, 00:02:59, Ethernet0/0
D EX 150.50.6.0/25 [170/2198016] via 150.50.17.2, 00:02:59, Ethernet0/0
D 150.50.7.0/25 [90/2221056] via 150.50.17.2, 00:02:59, Ethernet0/0
D 150.50.9.0/26 [90/40537600] via 150.50.17.2, 01:06:37, Ethernet0/0
C 150.50.17.0/24 is directly connected, Ethernet0/0
D 150.50.24.0/24 [90/2195456] via 150.50.17.2, 00:03:59, Ethernet0/0
D 150.50.100.0/27 [90/2195456] via 150.50.17.2, 00:03:59, Ethernet0/0
D 150.50.5.64/27 [90/2733056] via 150.50.17.2, 00:02:59, Ethernet0/0
R2#sh run
hostname R2
isdn switch-type basic-ni
interface Loopback0
ip address 200.0.0.2 255.255.255.255
ip address 150.50.17.2 255.255.255.0
half-duplex
interface Serial0/0
encapsulation frame-relay
interface Serial0/0.24 point-to-point
ip address 150.50.24.2 255.255.255.0
frame-relay interface-dlci 204
interface Serial0/0.256 multipoint
ip address 150.50.100.2 255.255.255.224
no ip split-horizon
frame-relay map ip 150.50.100.5 205 broadcast
frame-relay map ip 150.50.100.6 206 broadcast
interface BRI0/0
ip address 150.50.9.2 255.255.255.192
encapsulation ppp
dialer callback-secure
dialer idle-timeout 90
dialer map ip 150.50.9.5 name R5 class dialback broadcast 8995101
dialer map ip 150.50.9.5 name R5 class dialback broadcast 8995102
dialer-group 1
isdn spid1 5201 8995201
isdn spid2 5202 8995202
ppp callback accept
ppp authentication chap
router eigrp 100
passive-interface BRI0/0
network 150.50.9.0 0.0.0.63
network 150.50.24.0 0.0.0.255
network 150.50.100.0 0.0.0.31
network 200.0.0.2 0.0.0.0
no auto-summary
ip classless
no ip http server
map-class dialer dialback
dialer callback-server username
logging synchronous
line aux 0
password 7 121A0C041104
login
R2#sh ip route
D 200.0.0.8 [90/2835456] via 150.50.100.6, 00:02:42, Serial0/0.256
[90/2835456] via 150.50.100.5, 00:02:42, Serial0/0.256
D EX 200.0.0.9 [170/2172416] via 150.50.100.6, 00:02:42, Serial0/0.256
D 200.0.0.1 [90/409600] via 150.50.17.1, 00:02:37, Ethernet0/0
C 200.0.0.2 is directly connected, Loopback0
D 200.0.0.4 [90/2297856] via 150.50.24.4, 00:02:37, Serial0/0.24
D 200.0.0.5 [90/2297856] via 150.50.100.5, 00:02:42, Serial0/0.256
D 200.0.0.7 [90/2323456] via 150.50.100.6, 00:02:42, Serial0/0.256
[90/2323456] via 150.50.100.5, 00:02:42, Serial0/0.256
D 10.1.1.0 [90/2195456] via 150.50.24.4, 00:02:37, Serial0/0.24
[170/2172416] via 150.50.100.6, 00:02:44, Serial0/0.256
D 150.50.4.0/24 [90/2733056] via 150.50.100.6, 00:02:44, Serial0/0.256
[90/2733056] via 150.50.100.5, 00:02:44, Serial0/0.256
D EX 150.50.6.0/25 [170/2172416] via 150.50.100.6, 00:02:44, Serial0/0.256
D 150.50.7.0/25 [90/2195456] via 150.50.100.6, 00:02:44, Serial0/0.256
[90/2195456] via 150.50.100.5, 00:02:44, Serial0/0.256
C 150.50.9.0/26 is directly connected, BRI0/0
C 150.50.24.0/24 is directly connected, Serial0/0.24
C 150.50.100.0/27 is directly connected, Serial0/0.256
D 150.50.5.64/27 [90/2707456] via 150.50.100.6, 00:02:44, Serial0/0.256
[90/2707456] via 150.50.100.5, 00:02:44, Serial0/0.256
R4#sh run
hostname R4
no ip domain lookup
class-map match-all FTP-CLASS
match access-group 100
class-map match-any DEFAUTL
match any
class-map match-all ICMP-CLASS
match access-group 102
class-map match-all HTTP-CLASS
match access-group 101
policy-map CBWFQ-CENTRAL
class HTTP-CLASS
bandwidth 32
class FTP-CLASS
bandwidth 32
class ICMP-CLASS
bandwidth 32
class DEFAUTL
bandwidth 16
queue-limit 40
class class-default
interface Loopback0
ip address 200.0.0.4 255.255.255.255
ip address 10.1.1.4 255.255.255.0
half-duplex
no keepalive
interface Serial0/0
interface Serial0/0.1 point-to-point
ip address 150.50.24.4 255.255.255.0
frame-relay interface-dlci 402
interface Serial0/1
shutdown
router eigrp 100
network 10.1.1.0 0.0.0.255
network 200.0.0.4 0.0.0.0
no auto-summary
ip http server
ip classless
access-list 100 permit tcp 10.1.1.0 0.0.0.255 172.16.136.0 0.0.0.255 eq ftp
access-list 100 permit tcp 10.1.1.0 0.0.0.255 172.16.136.0 0.0.0.255 eq ftp-data
access-list 101 permit tcp 10.1.1.0 0.0.0.255 172.16.136.0 0.0.0.255 eq www
access-list 102 permit icmp 10.1.1.0 0.0.0.255 172.16.136.0 0.0.0.255
line aux 0
password cisco
login
R4#sh ip route
D 200.0.0.8 [90/3347456] via 150.50.24.2, 00:04:04, Serial0/0.1
D EX 200.0.0.9 [170/2684416] via 150.50.24.2, 00:04:04, Serial0/0.1
D 200.0.0.1 [90/2323456] via 150.50.24.2, 00:05:00, Serial0/0.1
D 200.0.0.2 [90/2297856] via 150.50.24.2, 00:05:00, Serial0/0.1
C 200.0.0.4 is directly connected, Loopback0
D 200.0.0.5 [90/2809856] via 150.50.24.2, 00:03:21, Serial0/0.1
D 200.0.0.7 [90/2835456] via 150.50.24.2, 00:04:04, Serial0/0.1
C 10.1.1.0 is directly connected, Ethernet0/0
D EX 150.50.6.209/32 [170/2684416] via 150.50.24.2, 00:04:04, Serial0/0.1
D 150.50.4.0/24 [90/3245056] via 150.50.24.2, 00:04:04, Serial0/0.1
D EX 150.50.6.0/25 [170/2684416] via 150.50.24.2, 00:04:06, Serial0/0.1
D 150.50.7.0/25 [90/2707456] via 150.50.24.2, 00:04:06, Serial0/0.1
D 150.50.9.0/26 [90/41024000] via 150.50.24.2, 00:05:03, Serial0/0.1
D 150.50.17.0/24 [90/2195456] via 150.50.24.2, 00:05:03, Serial0/0.1
C 150.50.24.0/24 is directly connected, Serial0/0.1
D 150.50.100.0/27 [90/2681856] via 150.50.24.2, 00:05:03, Serial0/0.1
D 150.50.5.64/27 [90/3219456] via 150.50.24.2, 00:04:07, Serial0/0.1
R4#sh policy-map
Policy Map CBWFQ-CENTRAL
Class HTTP-CLASS
Bandwidth 32 (kbps) Max Threshold 64 (packets)
Class FTP-CLASS
Class ICMP-CLASS
Class DEFAUTL
Bandwidth 16 (kbps) Max Threshold 40 (packets)
Class class-default
R4#sh ip route
D 200.0.0.8 [90/3347456] via 150.50.24.2, 00:04:40, Serial0/0.1
D EX 200.0.0.9 [170/2684416] via 150.50.24.2, 00:04:40, Serial0/0.1
D 200.0.0.1 [90/2323456] via 150.50.24.2, 00:05:36, Serial0/0.1
D 200.0.0.2 [90/2297856] via 150.50.24.2, 00:05:36, Serial0/0.1
D 200.0.0.5 [90/2809856] via 150.50.24.2, 00:03:56, Serial0/0.1
D 200.0.0.7 [90/2835456] via 150.50.24.2, 00:04:40, Serial0/0.1
D EX 150.50.6.209/32 [170/2684416] via 150.50.24.2, 00:04:40, Serial0/0.1
D 150.50.4.0/24 [90/3245056] via 150.50.24.2, 00:04:40, Serial0/0.1
D EX 150.50.6.0/25 [170/2684416] via 150.50.24.2, 00:04:41, Serial0/0.1
D 150.50.7.0/25 [90/2707456] via 150.50.24.2, 00:04:41, Serial0/0.1
D 150.50.9.0/26 [90/41024000] via 150.50.24.2, 00:05:37, Serial0/0.1
D 150.50.17.0/24 [90/2195456] via 150.50.24.2, 00:05:37, Serial0/0.1
D 150.50.100.0/27 [90/2681856] via 150.50.24.2, 00:05:37, Serial0/0.1
D 150.50.5.64/27 [90/3219456] via 150.50.24.2, 00:04:41, Serial0/0.1
R5#sh run
hostname R5
enable password cisco
username R2 password 0 cisco
interface Loopback0
ip address 200.0.0.5 255.255.255.255
ip address 150.50.7.5 255.255.255.128
half-duplex
interface Serial0/0
ip address 150.50.100.5 255.255.255.224
no fair-queue
frame-relay class TSLAB
frame-relay traffic-shaping
interface BRI0/0
ip address 150.50.9.5 255.255.255.192
encapsulation ppp
dialer idle-timeout 60
dialer map ip 150.50.9.2 broadcast 8995201
dialer map ip 150.50.9.2 broadcast 8995202
dialer-group 1
isdn spid1 5101
isdn spid2 5102
ppp callback request
router eigrp 100
network 150.50.7.0 0.0.0.127
network 200.0.0.5 0.0.0.0
no auto-summary
ip classless
ip route 150.50.17.0 255.255.255.0 150.50.9.2 130
no ip http server
map-class frame-relay TSLAB
no frame-relay adaptive-shaping
frame-relay cir 16000
frame-relay bc 2000
frame-relay be 2500
line aux 0
password cisco
login
R5#sh ip route
D 200.0.0.8 [90/2323456] via 150.50.7.7, 00:04:28, Ethernet0/0
D EX 200.0.0.9 [170/284160] via 150.50.7.6, 00:04:28, Ethernet0/0
D 200.0.0.1 [90/2323456] via 150.50.100.2, 00:04:38, Serial0/0
D 200.0.0.2 [90/2297856] via 150.50.100.2, 00:04:38, Serial0/0
D 200.0.0.4 [90/2809856] via 150.50.100.2, 00:04:38, Serial0/0
C 200.0.0.5 is directly connected, Loopback0
D 200.0.0.7 [90/409600] via 150.50.7.7, 00:04:28, Ethernet0/0
D 10.1.1.0 [90/2707456] via 150.50.100.2, 00:04:38, Serial0/0
D EX 150.50.6.209/32 [170/284160] via 150.50.7.6, 00:04:28, Ethernet0/0
D 150.50.4.0/24 [90/2221056] via 150.50.7.7, 00:04:28, Ethernet0/0
D EX 150.50.6.0/25 [170/284160] via 150.50.7.6, 00:04:30, Ethernet0/0
C 150.50.7.0/25 is directly connected, Ethernet0/0
D 150.50.17.0/24 [90/2195456] via 150.50.100.2, 00:04:40, Serial0/0
D 150.50.24.0/24 [90/2681856] via 150.50.100.2, 00:04:40, Serial0/0
D 150.50.5.64/27 [90/2195456] via 150.50.7.7, 00:04:30, Ethernet0/0
R5#sh dialer
BRI0/0 - dialer type = ISDN
Dial String Successes Failures Last DNIS Last status
8995202 0 1 00:16:01 failed
8995201 3 1 00:15:17 successful
0 incoming call(s) have been screened.
0 incoming call(s) rejected for callback.
BRI0/0:1 - dialer type = ISDN
Idle timer (60 secs), Fast idle timer (20 secs)
Wait for carrier (30 secs), Re-enable (15 secs)
Dialer state is idle
BRI0/0:2 - dialer type = ISDN
R5# sh ip route
D 200.0.0.8 [90/2323456] via 150.50.7.7, 00:04:55, Ethernet0/0
D EX 200.0.0.9 [170/284160] via 150.50.7.6, 00:04:55, Ethernet0/0
D 200.0.0.1 [90/2323456] via 150.50.100.2, 00:05:05, Serial0/0
D 200.0.0.2 [90/2297856] via 150.50.100.2, 00:05:05, Serial0/0
D 200.0.0.4 [90/2809856] via 150.50.100.2, 00:05:05, Serial0/0
D 200.0.0.7 [90/409600] via 150.50.7.7, 00:04:55, Ethernet0/0
D 10.1.1.0 [90/2707456] via 150.50.100.2, 00:05:05, Serial0/0
D EX 150.50.6.209/32 [170/284160] via 150.50.7.6, 00:04:55, Ethernet0/0
D 150.50.4.0/24 [90/2221056] via 150.50.7.7, 00:04:55, Ethernet0/0
D EX 150.50.6.0/25 [170/284160] via 150.50.7.6, 00:04:58, Ethernet0/0
D 150.50.17.0/24 [90/2195456] via 150.50.100.2, 00:05:07, Serial0/0
D 150.50.24.0/24 [90/2681856] via 150.50.100.2, 00:05:07, Serial0/0
D 150.50.5.64/27 [90/2195456] via 150.50.7.7, 00:04:58, Ethernet0/0
R8#sh run
hostname R8
logging rate-limit console 10 except errors
aaa new-model
aaa authentication username-prompt "Who is it _"
aaa authentication login default local-case enable
username vnpro privilege 15 password 0 minhdq
username minhdp password 0 vnpro
username minhdq password 0 vnpro
ip subnet-zero
crypto isakmp policy 100
hash md5
crypto isakmp key vnpro1 address 150.50.17.1
crypto map MYMAP 110 ipsec-isakmp
set peer 150.50.17.1
match address 120
interface Loopback0
ip address 200.0.0.8 255.255.255.255
ip address 150.50.4.8 255.255.255.0
no keepalive
half-duplex
interface Serial0/0
ip address 150.50.5.69 255.255.255.224
no fair-queue
clockrate 64000
crypto map MYMAP
router eigrp 100
network 150.50.4.0 0.0.0.255
network 150.50.5.64 0.0.0.31
network 200.0.0.8 0.0.0.0
no auto-summary
router rip
version 2
network 150.50.0.0
network 200.0.0.0
ip classless
ip route 192.168.10.0 255.255.255.0 150.50.5.68
no ip http server
access-list 120 permit ip 150.50.4.0 0.0.0.255 192.168.10.0 0.0.0.255
dial-peer cor custom
R8#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
C 200.0.0.8 is directly connected, Loopback0
D EX 200.0.0.9 [170/2198016] via 150.50.5.68, 00:27:17, Serial0/0
D 200.0.0.1 [90/2861056] via 150.50.5.68, 00:07:13, Serial0/0
D 200.0.0.2 [90/2835456] via 150.50.5.68, 00:07:13, Serial0/0
D 200.0.0.4 [90/3347456] via 150.50.5.68, 00:07:13, Serial0/0
D 200.0.0.5 [90/2323456] via 150.50.5.68, 00:27:17, Serial0/0
D 200.0.0.7 [90/2297856] via 150.50.5.68, 00:27:17, Serial0/0
S 192.168.10.0/24 [1/0] via 150.50.5.68
D 10.1.1.0 [90/3245056] via 150.50.5.68, 00:07:13, Serial0/0
D EX 150.50.6.209/32 [170/2198016] via 150.50.5.68, 00:27:17, Serial0/0
C 150.50.4.0/24 is directly connected, Ethernet0/0
D EX 150.50.6.0/25 [170/2198016] via 150.50.5.68, 00:27:20, Serial0/0
D 150.50.7.0/25 [90/2195456] via 150.50.5.68, 00:27:20, Serial0/0
D 150.50.9.0/26 [90/41049600] via 150.50.5.68, 00:27:20, Serial0/0
D 150.50.17.0/24 [90/2733056] via 150.50.5.68, 00:07:15, Serial0/0
D 150.50.24.0/24 [90/3219456] via 150.50.5.68, 00:07:15, Serial0/0
D 150.50.100.0/27 [90/2707456] via 150.50.5.68, 00:17:04, Serial0/0
C 150.50.5.64/27 is directly connected, Serial0/0
R5#sh run
hostname R5
interface Loopback0
half-duplex
interface Serial0/0
no fair-queue
interface BRI0/0
encapsulation ppp
dialer-group 1
isdn spid1 5101
isdn spid2 5102
router eigrp 100
no auto-summary
ip classless
no ip http server
frame-relay bc 2000
frame-relay be 2500
R9#150.50.7.7
R7#sh run
hostname R7
interface Loopback0
ip address 200.0.0.7 255.255.255.255
ip address 150.50.7.7 255.255.255.128
half-duplex
interface Serial0/0
ip address 150.50.5.68 255.255.255.224
no fair-queue
router eigrp 100
network 200.0.0.7 0.0.0.0
no auto-summary
router rip
network 150.50.0.0
network 200.0.0.0
ip classless
ip http server
R7#sh ip route
200.0.0.0/24 is variably subnetted, 8 subnets, 2 masks
D 200.0.0.8/32 [90/2297856] via 150.50.5.69, 00:28:30, Serial0/0
D EX 200.0.0.9/32 [170/284160] via 150.50.7.6, 01:21:15, Ethernet0/0
R 200.0.0.0/24 [120/1] via 150.50.5.69, 00:00:05, Serial0/0
D 200.0.0.1/32 [90/2349056] via 150.50.7.6, 00:07:37, Ethernet0/0
[90/2349056] via 150.50.7.5, 00:07:37, Ethernet0/0
D 200.0.0.2/32 [90/2323456] via 150.50.7.6, 00:07:37, Ethernet0/0
[90/2323456] via 150.50.7.5, 00:07:37, Ethernet0/0
D 200.0.0.4/32 [90/2835456] via 150.50.7.6, 00:07:37, Ethernet0/0
[90/2835456] via 150.50.7.5, 00:07:37, Ethernet0/0
D 200.0.0.5/32 [90/409600] via 150.50.7.5, 00:58:14, Ethernet0/0
C 200.0.0.7/32 is directly connected, Loopback0
D 10.1.1.0 [90/2733056] via 150.50.7.6, 00:07:39, Ethernet0/0
[90/2733056] via 150.50.7.5, 00:07:39, Ethernet0/0
D EX 150.50.6.209/32 [170/284160] via 150.50.7.6, 01:21:17, Ethernet0/0
D 150.50.4.0/24 [90/2195456] via 150.50.5.69, 00:28:32, Serial0/0
D EX 150.50.6.0/25 [170/284160] via 150.50.7.6, 01:21:17, Ethernet0/0
D 150.50.9.0/26 [90/40537600] via 150.50.7.5, 00:58:16, Ethernet0/0
D 150.50.17.0/24 [90/2221056] via 150.50.7.6, 00:07:39, Ethernet0/0
[90/2221056] via 150.50.7.5, 00:07:39, Ethernet0/0
D 150.50.24.0/24 [90/2707456] via 150.50.7.6, 00:07:39, Ethernet0/0
[90/2707456] via 150.50.7.5, 00:07:39, Ethernet0/0
D 150.50.100.0/27 [90/2195456] via 150.50.7.6, 00:09:00, Ethernet0/0
[90/2195456] via 150.50.7.5, 00:09:00, Ethernet0/0
R6#sh run
hostname R6
enable password 7 110A1016141D
class-map HTTP
class-map FTP
policy-map PRIO
class HTTP
bandwidth percent 10
class FTP
bandwidth percent 20
ip subnet-zero
interface Ethernet0
ip address 150.50.7.6 255.255.255.128
service-policy output PRIO
interface Ethernet1
ip address 150.50.6.6 255.255.255.128
interface Serial0
ip address 150.50.100.6 255.255.255.224
frame-relay map ip 150.50.100.2 602 broadcast
frame-relay map ip 150.50.100.5 605 broadcast
frame-relay lmi-type cisco
router eigrp 100
redistribute ospf 1 metric 100000 10 255 255 1500
network 150.50.7.0 0.0.0.255
network 150.50.100.0 0.0.0.255
no auto-summary
router ospf 1
log-adjacency-changes
redistribute eigrp 100 metric 111 metric-type 1 subnets
network 150.50.6.0 0.0.0.255 area 0
ip classless
no ip http server
access-list 101 permit tcp any any eq www
access-list 102 permit tcp any any eq ftp
R6#sh ip route
D 200.0.0.8 [90/2323456] via 150.50.7.7, 00:08:25, Ethernet0
O 200.0.0.9 [110/11] via 150.50.6.9, 01:22:52, Ethernet1
D 200.0.0.1 [90/2323456] via 150.50.100.2, 00:08:31, Serial0
D 200.0.0.2 [90/2297856] via 150.50.100.2, 00:08:31, Serial0
D 200.0.0.4 [90/2809856] via 150.50.100.2, 00:08:31, Serial0
D 200.0.0.5 [90/409600] via 150.50.7.5, 00:08:25, Ethernet0
D 200.0.0.7 [90/409600] via 150.50.7.7, 00:08:25, Ethernet0
D 10.1.1.0 [90/2707456] via 150.50.100.2, 00:08:31, Serial0
O 150.50.6.209/32 [110/11] via 150.50.6.9, 01:22:52, Ethernet1
D 150.50.4.0/24 [90/2221056] via 150.50.7.7, 00:08:25, Ethernet0
C 150.50.6.0/25 is directly connected, Ethernet1
D 150.50.9.0/26 [90/40537600] via 150.50.7.5, 00:08:27, Ethernet0
D 150.50.17.0/24 [90/2195456] via 150.50.100.2, 00:08:33, Serial0
D 150.50.24.0/24 [90/2681856] via 150.50.100.2, 00:08:33, Serial0
D 150.50.5.64/27 [90/2195456] via 150.50.7.7, 00:08:27, Ethernet0
R6#sh fr
R9#sh run
hostname R9
interface Loopback0
ip address 200.0.0.9 255.255.255.255
interface Loopback1
ip address 150.50.6.209 255.255.255.128
ip address 150.50.6.9 255.255.255.128
half-duplex
router ospf 63
network 150.50.6.0 0.0.0.127 area 0
network 150.50.6.128 0.0.0.127 area 0
network 200.0.0.9 0.0.0.0 area 0
R9#sh ip route
O E1 200.0.0.8 [110/121] via 150.50.6.6, 00:29:58, Ethernet0/0
C 200.0.0.9 is directly connected, Loopback0
O E1 200.0.0.1 [110/121] via 150.50.6.6, 00:09:55, Ethernet0/0
O E1 200.0.0.2 [110/121] via 150.50.6.6, 00:09:55, Ethernet0/0
O E1 200.0.0.4 [110/121] via 150.50.6.6, 00:09:55, Ethernet0/0
O E1 200.0.0.5 [110/121] via 150.50.6.6, 00:59:43, Ethernet0/0
O E1 200.0.0.7 [110/121] via 150.50.6.6, 01:23:26, Ethernet0/0
O E1 10.1.1.0 [110/121] via 150.50.6.6, 00:09:57, Ethernet0/0
150.50.0.0/16 is variably subnetted, 9 subnets, 4 masks
C 150.50.6.128/25 is directly connected, Loopback1
O E1 150.50.4.0/24 [110/121] via 150.50.6.6, 00:29:54, Ethernet0/0
C 150.50.6.0/25 is directly connected, Ethernet0/0
O E1 150.50.7.0/25 [110/121] via 150.50.6.6, 01:23:28, Ethernet0/0
O E1 150.50.9.0/26 [110/121] via 150.50.6.6, 00:59:45, Ethernet0/0
O E1 150.50.17.0/24 [110/121] via 150.50.6.6, 00:09:57, Ethernet0/0
O E1 150.50.24.0/24 [110/121] via 150.50.6.6, 00:09:57, Ethernet0/0
O E1 150.50.100.0/27 [110/121] via 150.50.6.6, 00:19:47, Ethernet0/0
O E1 150.50.5.64/27 [110/121] via 150.50.6.6, 01:23:28, Ethernet0/0Email : vnpro@vnpro.org
