cấu hình LAN-to-LAN (quay số router-to-router)
This is a sticky topic.
  • cấu hình LAN-to-LAN (quay số router-to-router)
    (nguồn: Anh Tài - VnPro)
    Lab 01
    Objective:
    Setup:
    1. Site A.
    Step 1: Install modem to router
    RouterA# conf t
    RouterA (Config)# interface s0/4
    RouterA (Config-if)# physical-layer async
    RouterA (Config-if)# no shut
    RouterA (Config-if)# exit
    RouterA (Config)# line 5
    RouterA (Config-line)# login
    RouterA (Config-line)# password cisco1
    RouterA (Config-line)# autoselect during-login
    RouterA (Config-line)# autoselect ppp
    RouterA (Config-line)# login local
    RouterA (Config-line)# modem InOut
    RouterA (Config-line)# modem autocofigure discovery
    RouterA (Config-line)# transport input all
    RouterA (Config-line)# stopbits 1
    RouterA (Config-line)# speed 33600
    RouterA (Config-line)# flowcontrol hardware
    RouterA (Config-line)# exit
    Step 2: Create loopback interface for Telnet into Modem
    RouterA (Config)# interface loopback0
    RouterA (Config-if)# ip add 1.1.1.1 255.0.0.0
    Step 3: Secure virtual Telnet session
    RouterA (Config-if)# line vty 0 4
    RouterA (Config-line)# password cisco2
    Step 4: Testing connection from Router to Modem
    RouterA (Config)# exit
    RouterA# Telnet 1.1.1.1 2005
    Authentication
    Password: cisco1
    <test some AT commands >
    ATDT<phonenumber of remote site>
    AT&W
    Step 5: configure asyn interface
    RouterA# conf t
    RouterA (config)# interface s0/4
    RouterA (config-if)# shutdown
    RouterA (config-if)# ip add 192.168.1.1 255.255.255.0
    RouterA (config-if)# encapsulation ppp
    RouterA (config-if)# async mode dedicated
    RouterA (config-if)# no cdp enable
    RouterA (config-if)# dialer in-band
    RouterA (config-if)# dialer idle-timeout 300
    RouterA (config-if)# dialer wait-for-carrier-time 60
    RouterA (config-if)# dialer hold-queue 50
    RouterA (config-if)# dialer group 1
    RouterA (config-if)# dialer map ip 192.168.1.2 name SiteB modem-script TaiA broadcast 204
    RouterA (config-if)# exit
    RouterA (config)# chat-script REMDEVICE ABORT ERROR ABORT BUSY “” “ATZ” OK “ATDT \T” TIMEOUT 30 CONNECT \c
    RouterA (config)# dialer-list 1 protocol ip permit
    RouterA (config)# ip route 0.0.0.0 0.0.0.0 192.168.1.2
    2. Site B.
    RouterB# conf t
    RouterB (Config)# line AUX 0
    RouterB (Config-line)# login
    RouterB (Config-line)# password cisco1
    RouterB (Config-line)# autoselect during-login
    RouterB (Config-line)# autoselect ppp
    RouterB (Config-line)# login local
    RouterB (Config-line)# modem InOut
    RouterB (Config-line)# modem autocofigure discovery
    RouterB (Config-line)# transport input all
    RouterB (Config-line)# stopbits 1
    RouterB (Config-line)# speed 33600
    RouterB (Config-line)# flowcontrol hardware
    RouterB (Config-line)# exit
    RouterB (Config)# interface loopback0
    RouterB (Config-if)# ip add 1.1.1.2 255.0.0.0
    RouterB (Config-if)# no shut
    RouterB (Config-if)# line vty 0 4
    RouterB (Config-line)# password cisco2
    RouterB (Config)# exit
    RouterB# Telnet 1.1.1.2 2065
    Authentication
    Password:  (Cisco 1
    AT&W
    RouterB# conf t
    RouterB (config)# interface ASYNC 0 (???)
    RouterB (config-if)# shutdown
    RouterB (config-if)# ip add 192.168.1.2 255.255.255.0
    RouterB (config-if)# encapsulation ppp
    RouterB (config-if)# async mode dedicated
    RouterB (config-if)# no cdp enable
    RouterB (config-if)# dialer in-band
    RouterB (config-if)# dialer idle-timeout 300
    RouterB (config-if)# dialer wait-for-carrier-time 60
    RouterB (config-if)# dialer hold-queue 50
    RouterB (config-if)# dialer group 1
    RouterB (config-if)# dialer map ip 192.168.1.1 name Sitea modem-script TaiB broadcast 203
    RouterB (config-if)# exit
    RouterB (config)# chat-script REMDEVICE ABORT ERROR ABORT BUSY “” “ATZ” OK “ATDT \T” TIMEOUT 30 CONNECT \c
    RouterB (config)# dialer-list 1 protocol ip permit
    RouterB (config)# ip route 0.0.0.0 0.0.0.0 192.168.1.1
    (download file Word đính kèm)
    file word nào bạn ??? có thấy file nào đâu ???
      Download file đính kèm.
        có cách nào học trực tuyến qua mạng không vậy !!!
        mình không có điều kiện thuận lợi lắm!!
          các bạn ơi làm ơn chỉ giùm cho mình cách cấu hình cho router và swicht với!!!
            Hi Hoaikha204
            Ban đọc tài liệu CCNA Stady Guide 5.0 ấy. Nó sẽ giúp ban rất nhiều điều bổ ích.
            Bạn có thể download trên từ link
            Chúc bạn thành công .
              thanks so much
                Thật hữu ích, cảm ơn pro (new commer)
                  Cho mình hỏi thêm 1 tí :
                  mình có router 1751 cíco , và có 1 card WIC 1-AM . làm sao để tét card WIC 1-AM còn tốt hay không ??
                  các bro cho mình biết cách config với
                  thanks
                    Hi
                    Dùng lệnh show version để xem router nhận được card WIC-1A/M này chưa.
                    Sau đó có thể kiểm tra bằng cách dùng reverse telnet.
                    chúc vui vẻ
