CONFIGURATION DOCUMENT
A. LAB DIAGRAM
B. CONFIGURATION
Configuration on Router R1 :
Current configuration : 1060 bytes
version 12.2
service timestamps log uptime
hostname R1
frame-relay switching
interface Tunnel0
ip address 192.168.1.5 255.255.255.252
tunnel source FastEthernet0/0
tunnel destination 192.168.1.2
interface Tunnel2
ip address 192.168.1.22 255.255.255.252
tunnel source Serial0/1
tunnel destination 192.168.1.14
interface FastEthernet0/0
ip address 192.168.1.1 255.255.255.252
duplex auto
speed auto
interface Serial0/0
encapsulation frame-relay
no fair-queue
clockrate 64000
frame-relay intf-type dce
frame-relay route 16 interface Tunnel0 16
frame-relay route 17 interface Tunnel2 17
interface Serial0/1
ip address 192.168.1.13 255.255.255.252
ip classless
ip http server
line aux 0
login
Configuration on Router R2:
Current configuration:
version 12.0
hostname R2
ip subnet-zero
interface Tunnel1
ip address 192.168.1.18 255.255.255.252
no ip directed-broadcast
tunnel source Ethernet0/0
tunnel destination 192.168.1.10
interface Tunnel2
ip address 192.168.1.21 255.255.255.252
tunnel source Serial0/0
tunnel destination 192.168.1.13
interface Ethernet0/0
ip address 192.168.1.9 255.255.255.252
interface Serial0/0
ip address 192.168.1.14 255.255.255.252
no ip mroute-cache
no fair-queue
clockrate 64000
interface Serial0/1
logging event subif-link-status
logging event dlci-status-change
clockrate 64000
frame-relay route 18 interface Tunnel1 18
ip classless
transport input none
line aux 0
login
no scheduler allocate
Configuration on Router R7:
Current configuration : 1747 bytes
version 12.2
hostname R7-3600
enable password cisco
call rsvp-sync
interface Tunnel0
ip address 192.168.1.6 255.255.255.252
interface Tunnel1
ip address 192.168.1.17 255.255.255.252
tunnel source FastEthernet0/1
tunnel destination 192.168.1.9
ip address 192.168.1.2 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.1.10 255.255.255.252
duplex auto
speed auto
interface Serial1/3
clockrate 64000
line aux 0
password cisco
login
Configuration on R3:
version 12.0
hostname R3
ip subnet-zero
interface Serial1
ip address 172.16.1.3 255.255.255.0
ip classless
logging synchronous
line aux 0
login
Configuration on R5:
version 12.0
hostname R5
ip subnet-zero
interface Serial1
ip address 172.16.1.5 255.255.255.0
ip classless
line aux 0
login
Configuration on R6:
version 12.0
hostname R6
ip subnet-zero
interface Serial0
ip address 172.16.1.4 255.255.255.0
no ip mroute-cache
no fair-queue
interface Serial1
shutdown
ip classless
logging synchronous
line aux 0
login
A. LAB DIAGRAM
B. CONFIGURATION
version 12.2
hostname R1
interface Tunnel0
interface Tunnel2
duplex auto
speed auto
interface Serial0/0
no fair-queue
clockrate 64000
interface Serial0/1
ip classless
ip http server
line aux 0
login
version 12.0
hostname R2
ip subnet-zero
interface Tunnel1
interface Tunnel2
interface Serial0/0
no ip mroute-cache
no fair-queue
clockrate 64000
interface Serial0/1
clockrate 64000
ip classless
line aux 0
login
version 12.2
hostname R7-3600
call rsvp-sync
interface Tunnel0
interface Tunnel1
duplex auto
speed auto
duplex auto
speed auto
interface Serial1/3
clockrate 64000
line aux 0
password cisco
login
version 12.0
hostname R3
ip subnet-zero
interface Serial1
ip classless
logging synchronous
line aux 0
login
version 12.0
hostname R5
ip subnet-zero
interface Serial1
ip classless
line aux 0
login
version 12.0
hostname R6
ip subnet-zero
interface Serial0
no ip mroute-cache
no fair-queue
interface Serial1
shutdown
ip classless
logging synchronous
line aux 0
login
