Cấu hình QoS dùng SDM
Yêu cầu :
Cấu hình cơ chế hàng đợi LLQ dùng SDM
Sơ đồ:
Trong bài lab này, sẽ hướng dẫn cách cấu hình mô hình MQC dùng SDM.
Thực hiện
Cấu hình ban đầu của hệ thống:
R1:
R1#sh run
Current configuration : 1167 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 10.10.20.1
ip dhcp pool 10.10.20.0
network 10.10.20.0 255.255.255.0
default-router 10.10.20.1
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
multilink bundle-name authenticated
voice-card 0
no dspfarm
archive
log config
hidekeys
interface FastEthernet0/0
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.10.20.1 255.255.255.0
duplex auto
speed auto
interface Serial0/1/0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.1.1.2
ip http server
no ip http secure-server
control-plane
exec-timeout 0 0
logging synchronous
line aux 0
privilege level 15
no login
scheduler allocate 20000 1000
R1#
R2#sh run
Current configuration : 1198 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 15
ip cef
voice-card 0
no dspfarm
ip address 20.20.20.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside
clock rate 2000000
interface Serial0/3/0
shutdown
clock rate 2000000
ip route 10.10.0.0 255.255.0.0 192.1.1.1
ip http server
ip nat inside source list 1 interface FastEthernet0/1 overload
access-list 1 permit 10.10.0.0 0.0.255.255
control-plane
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
privilege level 15
logging synchronous
no login
R2#
c2600_1#sh run
Current configuration : 832 bytes
version 12.3
hostname c2600_1
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
ip audit po max-events 100
interface Ethernet0/0
ip address 10.10.10.2 255.255.255.0
half-duplex
interface BRI0/0
encapsulation hdlc
shutdown
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.10.1
voice-port 1/0/0
voice-port 1/0/1
dial-peer voice 1 pots
destination-pattern 1111
port 1/0/0
dial-peer voice 2 voip
destination-pattern 2222
session target ipv4:20.20.20.2
exec-timeout 0 0
logging synchronous
line aux 0
privilege level 15
no login
c2600_1#
c2600_2#sh run
Current configuration : 854 bytes
version 12.3
hostname c2600_2
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
ip address 20.20.20.2 255.255.255.0
half-duplex
interface TokenRing0/0
shutdown
ring-speed 16
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 20.20.20.1
voice-port 1/0/0
voice-port 1/0/1
port 1/0/0
session target ipv4:10.10.10.2
exec-timeout 0 0
logging synchronous
line aux 0
privilege level 15
logging synchronous
no login
c2600_2#
Các bước thực hiện
Bước 1:
Dùng một máy PC trên LAN 10.10.20.0 /24 dùng chương trình SDM kết nối với R2:
Chương trình sẽ bắt đầu chạy:
Vào tab configure
Bên thanh công cụ bên trái chọn Quality of Service, Chọn Lauch QoS wizard, cũng có thể chỉnh sửa dùng tab Edit QoS Policy
Đọc nội dung giới thiệu sau đó chọn Next
Chọn cổng giao tiếp mà chính sách QoS sẽ được cài đặt. Trong trường hợp này sẽ để cho cơ chế NBAR tự động dò tìm lưu lượng chạy qua. Chọn Next để tiếp tục
Do cổng kết nối đang dùng cấu hình SDM từ PC cũng là cổng sẽ áp dụng QoS nên sẽ có bảng cảnh báo thông tin có thể bị đứt kết nối. Chọn Yes để tiếp tục
Hình 118
Bảng cấu hình với các thông số mặc định sẽ hiện ra, có thể giữ hoặc chỉnh sửa lại cho phù hợp với hệ thống
Trong trường hợp này ví dụ chỉnh lại lưu lượng voip chiếm 10% băng thông và transactional lên 10%, chú ý là giao diện sẽ tính toán cho phù hợp với thông số bandwidth trên cổng hiện hành (trong trường hợp này là mặc định 1.544 kbps), Chọn Next để tiếp tục
Một bảng tóm tắt sẽ hiển thị các thông số Cisco SDM sẽ áp dụng lên router, chọn Finish để hoàn tất, back để chỉnh sửa nếu muốn và cancel để hủy bỏ.
Do có dùng cơ chế NBAR trên cổng nên SDM truy vấn cho người đang cấu hình một lần nữa về mong muốn sử dụng NBAR trên cổng tương ứng. Chọn Yes
SDM tiến hành cài đặt các thông số QoS tương ứng lên router, chọn OK
Thông tin cấu hình được hiển thị dưới dạng đồ họa, người dùng vẫn có thể chỉnh sửa lại các thông số nếu muốn.
Có thể quan sát thông tin giám sát lưu lượng bằng SDM, vào Tab Monitor
Chọn QoS status bên thanh công cụ bên trái
Thực hiện 1 cuộc gọi và quan sát kết quả:
Có thể thấy thông tin thống kê tốc độ truyền của lớp lưu lượng tương ứng, trong trường hợp này là SDM-Voice với 12 kbps
Theo thời gian, tốc độ truyền tăng lên 25 kbps
Quan sát cấu hình sinh ra trên R2
R2#sh run
Current configuration : 3203 bytes
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
class-map match-any SDM-Transactional-1
match protocol citrix
match protocol finger
match protocol notes
match protocol novadigm
match protocol pcanywhere
match protocol secure-telnet
match protocol sqlnet
match protocol sqlserver
match protocol ssh
match protocol telnet
match protocol xwindows
class-map match-any SDM-Signaling-1
match protocol h323
match protocol rtcp
match protocol sip
class-map match-any SDM-Scavenger-1
match protocol napster
match protocol fasttrack
match protocol gnutella
class-map match-any SDM-Routing-1
match protocol bgp
match protocol egp
match protocol eigrp
match protocol ospf
match protocol rip
match protocol rsvp
class-map match-any SDM-Voice-1
match protocol rtp audio
class-map match-any SDM-Streaming-Video-1
match protocol cuseeme
match protocol netshow
match protocol rtsp
match protocol streamwork
match protocol vdolive
class-map match-any SDM-Management-1
match protocol dhcp
match protocol dns
match protocol imap
match protocol kerberos
match protocol ldap
match protocol secure-imap
match protocol secure-ldap
match protocol snmp
match protocol socks
match protocol syslog
class-map match-any SDM-Interactive-Video-1
match protocol rtp video
class-map match-any SDM-BulkData-1
match protocol exchange
match protocol ftp
match protocol irc
match protocol nntp
match protocol pop3
match protocol printer
match protocol secure-ftp
match protocol secure-irc
match protocol secure-nntp
match protocol secure-pop3
match protocol smtp
match protocol tftp
policy-map SDM-QoS-Policy-1
class SDM-Voice-1
set dscp ef
priority percent 10
class SDM-Signaling-1
set dscp cs3
bandwidth percent 5
class SDM-Routing-1
set dscp cs6
bandwidth percent 5
class SDM-Management-1
set dscp cs2
bandwidth percent 5
class SDM-Transactional-1
set dscp af21
bandwidth percent 10
class class-default
fair-queue
random-detect
ip nat inside
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nbar protocol-discovery
ip nat inside
clock rate 2000000
service-policy output SDM-QoS-Policy-1
shutdown
clock rate 2000000
ip http server
control-plane
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
privilege level 15
logging synchronous
no login
R2#
Yêu cầu :
Sơ đồ:
Thực hiện
R1:
R1#sh run
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
voice-card 0
no dspfarm
archive
log config
hidekeys
duplex auto
speed auto
duplex auto
speed auto
ip http server
control-plane
exec-timeout 0 0
logging synchronous
line aux 0
privilege level 15
no login
R1#
R2#sh run
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
voice-card 0
no dspfarm
ip nat inside
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside
clock rate 2000000
shutdown
clock rate 2000000
ip http server
control-plane
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
privilege level 15
logging synchronous
no login
R2#
c2600_1#sh run
version 12.3
hostname c2600_1
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
half-duplex
interface BRI0/0
encapsulation hdlc
shutdown
ip http server
ip classless
voice-port 1/0/0
voice-port 1/0/1
port 1/0/0
exec-timeout 0 0
logging synchronous
line aux 0
privilege level 15
no login
c2600_1#
c2600_2#sh run
version 12.3
hostname c2600_2
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
half-duplex
shutdown
ring-speed 16
ip http server
ip classless
voice-port 1/0/0
voice-port 1/0/1
port 1/0/0
exec-timeout 0 0
logging synchronous
line aux 0
privilege level 15
logging synchronous
no login
c2600_2#
Các bước thực hiện
Bước 1:
Vào tab configure
Hình 118
R2#sh run
version 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
match protocol ssh
match protocol h323
match protocol rtcp
match protocol sip
match protocol bgp
match protocol egp
match protocol ospf
match protocol rip
match protocol rsvp
match protocol rtsp
match protocol dhcp
match protocol dns
match protocol imap
match protocol ldap
match protocol snmp
match protocol ftp
match protocol irc
match protocol nntp
match protocol pop3
match protocol smtp
match protocol tftp
class SDM-Voice-1
set dscp ef
priority percent 10
set dscp cs3
bandwidth percent 5
class SDM-Routing-1
set dscp cs6
bandwidth percent 5
set dscp cs2
bandwidth percent 5
set dscp af21
class class-default
fair-queue
random-detect
ip nat inside
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside
clock rate 2000000
shutdown
clock rate 2000000
ip http server
control-plane
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
privilege level 15
logging synchronous
no login
R2#
