Lab 15-1: PIM DENSE-MODE
Cấu hình cho sơ đồ thực tế sau:
R1, R2, R3, R4 chạy OSPF là giao thức unicast để mang thông tin multicast
Host1 và Host2 là hai router làm client để yêu cầu join group. R3, R5 nối vào cùng một segment để hiểu rõ hơn về DR, và IGMP querier
Cấu hình Dense-mode
R1#show run
hostname R1
enable password cisco
ip subnet-zero
no ip domain lookup
ip host Host_1 192.168.3.2
ip host R3 192.168.1.18
ip host R4 192.168.1.14
ip host R5 192.168.1.6
ip host r2 192.168.1.22
ip multicast-routing
interface Serial0/0
ip address 192.168.1.1 255.255.255.252
ip pim dense-mode
clockrate 64000
interface FastEthernet0/1
ip pim dense-mode
duplex auto
speed auto
interface Serial0/1
ip address 192.168.1.21 255.255.255.252
ip pim dense-mode
clockrate 64000
router ospf 1
log-adjacency-changes
network 0.0.0.0 255.255.255.255 area 0
R2#show run
hostname R2
interface Serial0/0
ip address 192.168.1.17 255.255.255.252
ip pim dense-mode
no fair-queue
clockrate 64000
interface Serial0/1
ip address 192.168.1.22 255.255.255.252
ip pim dense-mode
router ospf 1
ip classless
ip http server
End
R3#show run
hostname R3
ip subnet-zero
no ip domain lookup
interface Ethernet0/0
ip pim dense-mode
no ip mroute-cache
half-duplex
interface Serial0/0
ip address 192.168.1.13 255.255.255.252
ip pim dense-mode
no ip mroute-cache
no fair-queue
interface Serial0/1
ip address 192.168.1.18 255.255.255.252
ip pim dense-mode
no ip mroute-cache
router ospf 1
ip http server
ip classless
R4
hostname R4
ip subnet-zero
no ip domain lookup
ip address 192.168.1.5 255.255.255.252
ip pim dense-mode
no ip mroute-cache
half-duplex
interface Serial0/0
ip address 192.168.1.2 255.255.255.252
ip pim dense-mode
no ip mroute-cache
no fair-queue
interface Serial0/1
ip address 192.168.1.14 255.255.255.252
ip pim dense-mode
no ip mroute-cache
clockrate 64000
router ospf 1
ip classless
End
R5
hostname R5
no ip domain lookup
interface FastEthernet0/0
ip address 192.168.1.6 255.255.255.252
ip pim dense-mode
no ip mroute-cache
duplex auto
speed auto
ip pim dense-mode
no ip mroute-cache
duplex auto
speed auto
router ospf 1
Host_1#show run
hostname Host_1
memory-size iomem 10
ip subnet-zero
no ip routing
no ip domain lookup
ip address 192.168.3.2 255.255.255.0
ip igmp join-group 228.0.0.1
half-duplex
ip default-gateway 192.168.3.1
Host_2
hostname Host_2
ip subnet-zero
no ip domain lookup
ip host R1 192.168.1.21
ip host R2 192.168.1.22
ip address 192.168.2.3 255.255.255.0
half-duplex
router ospf 1
Giải thích một số lệnh
no ip mrou-cache: Không cho phép router chuyển mạch nhanh bằng cache của interface mà phải định tuyến cho từng packet một. Nếu không thì router chỉ định tuyến cho packet đầu tiên còn tất cả các packet còn lại sẽ được chuyển mạch nhanh bằng các report được lưu trong bộ nhớ đệm gọi là cache.
show ip mroute trên các router: để xem bảng định tuyến multicast của các group: muốn các group hiện lên trên các router thì trước hết từ host1 ta ping host2 để tao multicast trafic thì mói có group trên các router nếu không thì do quá 3 interval thì router sẽ tự động gởi Prune message cho up link port.
R1#show ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
L - Local, P - Pruned, R - RP-bit set, F - Register flag,
T - SPT-bit set, J - Join SPT, M - MSDP created entry,
X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
U - URD, I - Received Source Specific Host Report, s - SSM
Outgoing interface flags: H - Hardware switched
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 224.0.1.40), 00:13:39/00:00:00, RP 0.0.0.0, flags: DCL
Incoming interface: Null, RPF nbr 0.0.0.0
Outgoing interface list:
Serial0/0, Forward/Dense, 00:13:20/00:00:00
Serial0/1, Forward/Dense, 00:13:37/00:00:00
FastEthernet0/1, Forward/Dense, 00:13:39/00:00:00
(*, 228.0.0.1), 00:13:16/00:02:55, RP 0.0.0.0, flags: DC
Serial0/1, Forward/Dense, 00:13:16/00:00:00
FastEthernet0/1, Forward/Dense, 00:13:16/00:00:00
Serial0/0, Forward/Dense, 00:13:16/00:00:00
R3#sh ip mroute
U - URD, I - Received Source Specific Host Report, Z - Multicast Tunnel
Y - Joined MDT-data group, y - Sending to MDT-data group
(*, 228.0.0.1), 00:11:14/stopped, RP 0.0.0.0, flags: DC
Ethernet0/0, Forward/Dense, 00:11:14/00:00:00
Serial0/0, Forward/Dense, 00:11:14/00:00:00
Serial0/1, Forward/Dense, 00:11:14/00:00:00
(192.168.1.1, 228.0.0.1), 00:05:22/00:00:58, flags: T
Incoming interface: Ethernet0/0, RPF nbr 192.168.2.2
Serial0/0, Prune/Dense, 00:02:13/00:00:50
Serial0/1, Forward/Dense, 00:05:22/00:00:00
(192.168.1.21, 228.0.0.1), 00:05:22/00:00:55, flags: T
Incoming interface: Serial0/1, RPF nbr 192.168.1.17
Ethernet0/0, Forward/Dense, 00:05:22/00:00:00
Serial0/0, Forward/Dense, 00:05:22/00:00:00
(192.168.3.1, 228.0.0.1), 00:02:14/00:00:48, flags: PT
Serial0/0, Prune/Dense, 00:02:14/00:00:48
Serial0/1, Prune/Dense, 00:02:14/00:00:48
(*, 224.0.1.40), 00:12:09/00:02:39, RP 0.0.0.0, flags: DCL
Ethernet0/0, Forward/Dense, 00:12:09/00:00:00
Serial0/0, Forward/Dense, 00:12:07/00:00:00
Serial0/1, Forward/Dense, 00:12:07/00:00:00
R4# show ip mroute
(*, 224.0.1.40), 00:12:29/00:00:00, RP 0.0.0.0, flags: DCL
Serial0/1, Forward/Dense, 00:12:26/00:00:00
Serial0/0, Forward/Dense, 00:12:28/00:00:00
Ethernet0/0, Forward/Dense, 00:12:29/00:00:00
(*, 228.0.0.1), 00:08:15/00:02:59, RP 0.0.0.0, flags: D
Serial0/1, Forward/Dense, 00:08:15/00:00:00
Serial0/0, Forward/Dense, 00:08:15/00:00:00
Ethernet0/0, Forward/Dense, 00:08:15/00:00:00
(192.168.1.1, 228.0.0.1), 00:05:42/00:00:31, flags: T
Incoming interface: Serial0/0, RPF nbr 192.168.1.1
Ethernet0/0, Forward/Dense, 00:05:42/00:00:00
Serial0/1, Forward/Dense, 00:05:42/00:00:00
(192.168.1.21, 228.0.0.1), 00:02:33/00:00:26, flags:
Ethernet0/0, Forward/Dense, 00:02:33/00:00:00
Serial0/1, Forward/Dense, 00:02:33/00:00:00
(192.168.3.1, 228.0.0.1), 00:05:42/00:00:31, flags: T
R5#show ip mroute
(*, 224.0.1.40), 00:12:10/00:00:00, RP 0.0.0.0, flags: DCL
FastEthernet0/0, Forward/Dense, 00:12:10/00:00:00
FastEthernet0/1, Forward/Dense, 00:11:31/00:00:00
(*, 228.0.0.1), 00:11:36/00:02:59, RP 0.0.0.0, flags: DC
FastEthernet0/0, Forward/Dense, 00:11:33/00:00:00
FastEthernet0/1, Forward/Dense, 00:11:36/00:00:00
(192.168.1.1, 228.0.0.1), 00:01:36/00:01:23, flags: CT
Incoming interface: FastEthernet0/0, RPF nbr 192.168.1.5
FastEthernet0/1, Forward/Dense, 00:01:38/00:00:00
(192.168.1.21, 228.0.0.1), 00:01:38/00:01:21, flags: CT
Incoming interface: FastEthernet0/1, RPF nbr 192.168.2.1
FastEthernet0/0, Forward/Dense, 00:01:38/00:00:00
(192.168.3.1, 228.0.0.1), 00:01:38/00:01:21, flags: CT
Kiểm tra
1. Ta sử dụng lệnh show ip pim neighbor interface number để xem router nào là DR trong segment. Ở đây ta sử dụng lệnh này trên R3, và R5. R5 là DR
R5#show ip pim interface fastEthernet 0/1
Address Interface Ver/ Nbr Query DR DR
Mode Count Intvl Prior
192.168.2.1 FastEthernet0/1 v2/D 1 30 1 192.168.2.2
R3#show ip pim neighbor inte0/0
PIM Neighbor Table
Neighbor Interface Uptime/Expires Ver DR
Address Prio/Mode
192.168.2.2 Ethernet0/0 00:03:15/00:01:29 v2 1 / DR S
Ta sử dụng lệnh ping từ host1 đến Host2 thì ta sẻ cho kết quả trên R3 và R5 như sau: R5 báo mforward có nghĩa là nó chịu trách truyền multicast đến cho các client trong segment, còn R3 thì không: sử dụng lênh debug ip mpacket
R3#
*Mar 1 00:09:52.607: IP(0): s=192.168.3.1 (Ethernet0/0) d=228.0.0.1 id=15, prot=1, len=114(100), mroute olist null
*Mar 1 00:09:52.615: IP(0): s=192.168.3.1 (Serial0/0) d=228.0.0.1 id=15, prot=1, len=104(100), not RPF interface
*Mar 1 00:09:52.615: IP(0): s=192.168.3.1 (Serial0/1) d=228.0.0.1 id=15, prot=1, len=104(100), not RPF interface
R5#
*Mar 1 00:10:49.407: IP: s=192.168.1.1 (FastEthernet0/0) d=228.0.0.1 (FastEthernet0/1) len 114, mforward
*Mar 1 00:10:49.423: IP: s=192.168.3.1 (FastEthernet0/0) d=228.0.0.1 (FastEthernet0/1) len 114, mforward
*Mar 1 00:10:49.427: IP: s=192.168.1.21 (FastEthernet0/1) d=228.0.0.1 (FastEthernet0/0) len 114, mforward
*Mar 1 00:10:53.979: IP: s=192.168.1.1 (FastEthernet0/0) d=228.0.0.1 (FastEthernet0/1) len 114, mforward
Cấu hình Dense-mode
R1#show run
hostname R1
ip subnet-zero
no ip domain lookup
interface Serial0/0
ip pim dense-mode
clockrate 64000
ip pim dense-mode
duplex auto
speed auto
interface Serial0/1
ip pim dense-mode
clockrate 64000
router ospf 1
R2#show run
hostname R2
interface Serial0/0
ip pim dense-mode
no fair-queue
clockrate 64000
interface Serial0/1
ip pim dense-mode
router ospf 1
ip classless
ip http server
End
R3#show run
hostname R3
ip subnet-zero
no ip domain lookup
ip pim dense-mode
no ip mroute-cache
half-duplex
interface Serial0/0
ip pim dense-mode
no ip mroute-cache
no fair-queue
interface Serial0/1
ip pim dense-mode
no ip mroute-cache
router ospf 1
ip http server
ip classless
R4
hostname R4
ip subnet-zero
no ip domain lookup
ip pim dense-mode
no ip mroute-cache
half-duplex
interface Serial0/0
ip pim dense-mode
no ip mroute-cache
no fair-queue
interface Serial0/1
ip pim dense-mode
no ip mroute-cache
clockrate 64000
router ospf 1
ip classless
End
R5
hostname R5
no ip domain lookup
ip pim dense-mode
no ip mroute-cache
duplex auto
speed auto
ip pim dense-mode
no ip mroute-cache
duplex auto
speed auto
router ospf 1
Host_1#show run
hostname Host_1
ip subnet-zero
no ip routing
no ip domain lookup
half-duplex
Host_2
hostname Host_2
ip subnet-zero
no ip domain lookup
half-duplex
router ospf 1
R1#show ip mroute
R3#sh ip mroute
R4# show ip mroute
R5#show ip mroute
Kiểm tra
PIM Neighbor Table
Address Prio/Mode
R3#
R5#
