Giúp em ping từ ipv4 sang ipv6 qua công nghệ nat???
  • Giúp em ping từ ipv4 sang ipv6 qua công nghệ nat???
Name:	mp phong.jpg
    Em cấu hình router NAT- Pt như sau
    NAT-PT
    Router#conf t
    Router(config)#ipv6 unicast-routing
    Router(config)#interface f0/0
    Router(config-if)#ipv6 add 2001:A:B:C::4/64
    Router(config-if)#ipv6 nat
    Router(config-if)#no shut
    %LINK-5-CHANGED: Interface FastEthernet0/0, changed state to up
    %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to up
    Router(config-if)#exit
    Router(config)#interface f0/1
    Router(config-if)#ip add 192.168.1.1 255.255.255.0
    Router(config-if)#
    %LINK-5-CHANGED: Interface FastEthernet0/1, changed state to up
    %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to up
    Router(config)#ipv6 access-list to_v4
    Router(config-ipv6-acl)#permit ipv6 2001:A:B:C::/64 any
    Router(config-ipv6-acl)#exit
    Router(config)#ipv6 nat v6v4 pool ipv4 192.168.1.1 192.168.1.3 prefix-length 24
    Router(config)#ipv6 nat v6v4 source list to_v4 pool ipv4
    Router(config)#ipv6 nat v4v6 source 192.168.1.10 2001::C0A8:10A
    Router(config)#ipv6 nat prefix 2001::/86
    % Invalid prefix length
    Router(config)#ipv6 nat prefix 2001::/96
    Router(config)#exit
    Router#
    %SYS-5-CONFIG_I: Configured from console by console
    Cấu hình Router IPv4 như sau:
    Router>enable
    Router#conf t
    Router(config)#hostname V4
    V4(config)#interface f0/0
    V4(config-if)#ip add 192.168.1.10 255.255.255.0
    V4(config-if)#no shut
    V4(config-if)#
    V4(config-if)#exit
    V4(config)#ip route 0.0.0.0 0.0.0.0 192.168.1.1
    V4(config)#interface f0/1
    V4(config-if)#ip add 192.168.2.1 255.255.255.0
    V4(config-if)#exit
    V4(config)#exit
    V4#
    CẤU HÌNH V6 NHƯ SAU:
    Router(config)#
    Router(config)#hostname V6
    V6(config)#ipv6 unicast-routing
    V6(config)#interface f0/0
    V6(config-if)#ipv6 add 2001:A:B:C::3/64
    V6(config-if)#no shut
    V6(config-if)#
    V6(config-if)#exit
    V6(config)#ipv6 route ::/0 2001:A:B:C::4
    V6(config)#int f0/1
    V6(config-if)#ipv6 add 2001:A:B:B::2/64
    V6(config)#exit
    V6#
    Anh chị cho em hỏi là tại sao con PC1_V6 không ping được qua PC2_V4 ạ,
    Trong khi router V6 ping được cho router V4
    Em chân thành cảm ơn ạ!!!!
