Em cau hinh roi nhung khi dielar thi no bao ko "no ip get from pool"
Em gui phan em cau hinh, bac nao xem ho em xem sai o cho nao
Router>en
Router#config t
Router(config)#in
Router(config)#interface f0/0
Router(config-if)#ip add 1.1.1.1 255.0.0.0
Router(config-if)#pp
Router(config-if)#pppoe en
Router(config-if)#pppoe enable
Router(config-if)#exit
Router(config-if)#no shut
%LINK-5-CHANGED: Interface FastEthernet0/0, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to up
Router(config-if)#
Router(config)#interface virtual-Template
Router(config)#interface virtual-Template 1
Router(config-if)#ip unnumbered fastEthernet 0/0
Router(config-if)#peer default ip address pool mypool
Router(config-if)#ppp au
Router(config-if)#ppp authentication cha
Router(config-if)#ppp authentication chap
AAA: Warning, authentication list default is not defined for PPP.
Router(config)#vpdn en
Router(config)#vpdn enable
Router(config)#vpdn-
Router(config)#vpdn-group ?
WORD VPDN Group name
Router(config)#vpdn-group mygroup
Router(config-vpdn)#accept-dialin
Router(config-vpdn-acc-in)#virtual-template 1
% PPPoE config from vpdn-group is converted to pppoe-profile based config.
% Continue PPPoE configuration under 'bba-group pppoe global'
Router(config-vpdn-acc-in)#exit
Router(config-vpdn)#exit
Router(config)#ip loc
Router(config)#ip local p
Router(config)#ip local pool mypool 1.1.1.10 1.1.1.20
Router(config)#user
Router(config)#username cisco pas
Router(config)#username cisco password cisco
Router(config)#exit
